    Heater Fault oscillating curve
    • jaydevdave
      jaydevdave last edited by
      can any one help me control the temperature
      M307 H6 A200 C302.1 D25 S1.00 B0
      M570 H6 P10 T20 S120
      0_1544267619213_01.png ![alt text](image url)
      • deckingman
        deckingman @jaydevdave last edited by deckingman
        @jaydevdave From the Wiki https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        "................... If the temperature is not stable but oscillates around the target temperature even when the print head is stationary, increase the D parameter".
        Edit. That's assuming that the temperature is not being influenced by some external factor such as a part cooling fan switching on and off.
        • jaydevdave
          1. Print head is not stationary, Print is running
          2. and Print head is not affected by Cooling fan
          Please suggest Parameter change.
          • deckingman
            @jaydevdave said in Heater Fault oscillating curve:
            I already have - increase the "D" parameter. That's in your M307.
            • mrehorstdmd
              mrehorstdmd last edited by
              Was it working OK and then starting doing this, or is this a new hot-end set-up problem?
