    Wifi Signal strength
    • Torroundefined
      Torro
      The printer is back in the enclosure. A s long as it was on the work bench, i had no Problems with connectivity.
      But now, there are often Problems. Is there a way to check, if the wifi Connection is strong enough? I have a wlan repeater on the way, but maybe, it's something else, that causes Problems.
      The enclosure is just wood and a few screws.
        https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
        • Torroundefined
          Torro
          Thanks! A wifi range extender did the Job. Signal strength before - 77, now - 36.
          But the fix IP changed... Don't know why, but as long as i know the IP, it's ok...
            dc42 administrators @Torro
            @torro said in Wifi Signal strength:
            That will be because the IP address assigned by the router is associated with the MAC address, and it's probably seeing the MAC address of the range extender instead of the MAC address of the Duet.
