    Detachable Casing with RJ45 Connectors
    PanelDue
    • fotomas
      fotomas last edited by
      I want to share may latest project, a detachable Panel Due caring using RJ45 connectors.
      I am building a Duet controlled MPCNC and to be able to move my panel due between my printer and the upcoming CNC. I used RJ45 connectors from a server room patch panel.
      I have tested with different LAN cable lengths, 3 m works but not 10 m 🙂 , it communicated but the touch control did not respond. 3 m will be more than enough.
      The hole is for an emergency stop button to be used with the CNC. This is a prototype printed printed with a 0.6 nozzle and 0.4 layer height so it is not the prettiest print.
      Happy with the solution so far.
      richardmckenna 1 Reply Last reply Reply Quote 1
      • richardmckenna
        richardmckenna @fotomas last edited by
        @fotomas nice, which version of the PanelDue is this?
        • fotomas
          It is probably the first version with a 5" screen.
