    Smart effector: 24v heater & 12v heatsink fan
    • pytundefined
      pyt
      My main VIN on duet is 24v. I have 12v power going into V_FAN (middle pin) of V_FAN JUMPER SELECT, the other 2 remaining (left & right pins) are not connected to anything.
      Wiring setup (INPUT 1):
      (smart effector <- >duet)
      H+ (24v) <-> E0 VIN
      H- <-> E0-
      HF+ (12v) <-> Always On Fans V_FAN
      HF- <-> Always On Fans GND
      PF- <-> No print fan yet
      PF+ <-> No print fan yet
      Also, place a jumper on On for 12V on underside of smart effector
      Is it ok to mix 12v and 24v on the smart effector? Am I missing anything?
      I will eventually switch to all fans to VIN (24v) or 5v for consistency. This is just to get things running first.
      Related references:
      https://forum.duet3d.com/topic/5831/working-with-24v-but-having-a-noctua-as-heatsink-fan-in-12v
      https://forum.duet3d.com/topic/4005/12v-fans-again
        Yes that's OK. The LEDs are powered from the heatsink fan supply, so you will need to fit the 12V jumper on the Smart Effector. Don't forget to remove it when you switch the fan to a 24V one.
        pytundefined 1 Reply Last reply Reply Quote 1
        • pytundefined
          pyt @dc42
          Thank you for the quick response!
