SOLVED Got my paneldue... It says "connecting" and controls nothing...
I just got my brand new paneldue 7i from Filastruder today. I plugged it into my brand new Duet 2 wifi, and it lights up, gives me all of the menus, beeps, but controls nothing... it just says "connecting." I tested the cable with an RC cable tester, and it's got 100% continuity on all 4 leads. I followed your diagram, and the din, gnd, +5v, etc are connected the right way. Is there anywhwere in the firmware where we have to tell it that is using the paneldue or something??? I have read every page mentioning a paneldue, but instructions are sparse. This leads me to believe that it's as simple as hooking it to the cable Filastruder sent me, and it should connect. It does not however. I tried all baud rates, and reset in between... No Joy! Any ideas??? Thanks!
@steve-lynch It should just work.
If you go to the setup page on the PanelDue, what firmware version does it show at the top?
The baudrate should be 57600. Try again. I have the same issue earlier.
Check that the baud rates on both the PanelDue Setup page and in the M575 P1 command in config.g on the Duet are both set to 57600.
@phaedrux 1.21.2 (12b1) is what it says.
@steve-lynch If you've checked the commands as David says above and it's still not working, you can try flashing the latest firmware. Instructions here: https://miscsolutions.wordpress.com/paneldue/
Hello, Thanks for the reply..
There was not an M575P1 command anywhere in my Config.g Perhaps the Paneldue instruction page should include this?
The Paneldue instructions make no mention of this anywhere.
So I searched the M Codes Until I found an explanation.. I set my board using this command: M575 P1 B57600 S1
I reboot the Paneldue and the Duet.. Still nothing. Just "Connecting"
Here's my complete Config.G do you see any problems? I've done everything every youtube tutorial, or forum post has suggested.. Thanks so much!
; generated by RepRapFirmware Configuration Tool v2 on Thu Dec 20 2018 18:06:49 GMT-0500 (Eastern Standard Time); General preferences
M575 P1 B57600 S1 ;Set baud rate Duet Board.
M575 P0 B57600 S1 ;Set baud rate USB
M550 P"My Printer" ; Set machine name
M552 S1 ; Enable network;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet
M564 H0
M569 P1 S1 ; Drive 1 goes backwards
M569 P4 S0 ; Drive 4 goes forwards
M584 X0 Y1:4 Z2 E3 ; Apply custom drive mapping
M92 X80.00 Y80.00 Z400.00 E415.00 ; Set steps per mm
M566 X480 Y480 Z12.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X1200 Y1200 Z250.00 E250.00 ; Set accelerations (mm/s^2)
M906 X1200 Y1200 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X290 Y290 Z360 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z0 S1 ; Set active high endstops; ** BLTouch
M307 H3 A-1 C-1 D-1 ; disable heater 3, BLTouch - servo pulse on heater 3 pin (expansion
M558 P5 X0 Y0 Z1 H5 F200 T5000 ; Type 5 for BLTouch (Normally closed switch on Z-probe inputs)
G31 X33.00 Y0.39 Z2.74 P5 ; Z=trigger height, P=trigger value, not needed for contact probe, X/Y distance from nozzle
;; Heaters
M305 P1 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 I0 S0 F500 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 F500 I0 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
G29 S1 ; load stored bed height map -
@steve-lynch said in Got my paneldue... It says "connecting" and controls nothing...:
I think it's not mentioned because it's already the default.
Did you try updating the PanelDue firmware?
What firmware are you running on the Duet?
Double check the cable continuity and that the pins are going to the right places? It's oftentimes a cabling issue of some sort.
Otherwise I'm not sure what else to do or check.
This post is deleted! -
Firmware on board is updated to 2.02 from 8 days ago.. Paneldue is updated to the latest firmware 1.22.1(28b1) The screen showed the firmware update progress, and said when it was rebooting and all, but it still says "connecting" after re-boot, and no control..
Continuity confirmed... It's only 4 conductors.. not hard to keep straight.
Hmmmm.
WiFi Server Version: 1.21
Web Interface Version: 1.22.6
Web Interface by Christian Hammacher
Licensed under the terms of the GPL v3 -
Tried it with the ribbon cable interface as well.. it powers it, it shows firmware upgrade status, but it does not "connect".
Everyone said "dude, they're more trouble than they're worth"... But I see a lot of folks using them successfully..
I'm at a loss here.
@Steve-Lynch does the PanelDue tell you anything on the console tab?
I used to see a few error messages when I set the wrong baud rate...Can you inspect the PCB, and verify that the connection headers are good? Maybe there is a bad solder joint or crack in the PCB? (high-def pictures maybe?)
overall
view -
connector closeup top
I don't see obvious problems on the PCB - but maybe @dc42 spots something...
If you use the 4-pin connector, try switching the wires of the two data pins (DIN, DOUT).
I do PCB Repair, and under my scope, there is no break, or bad solder joint... Aside from that, both interfaces do not work.. (ribbon cable, or 4 pin) I have several of each, so it's not the cable, and I have continuity from the solder joint on the duet to the solder joint on the paneldue..
@Steve-Lynch whats the story with the lifted pad / pin in the top left corner, close to RA2/RA7?
Since you seem to be familiar with the topic: do you have a scope? Can you probe the UART pins of the SAM4S directly? just to make sure the traces are all fine.
That connector, the (X4 connector) was broken off in shipping. While I did email filastruder, I've been told by others that the connector isn't used, so It should not be an issue. The traces leading to the pads are fine, but the pads themselves were ripped off it seems.
I have a Microscope, not oscilloscope.. lol. I replace blown capacitors and power supplies and repair traces and stuff, I'm wasn't trying to be "mr. know it all", I just was establishing that I had checked beyond the obvious...
And I tried swapping din dout, that didn't do anything as expected (rx to rx - Tx to Tx)
Do you mean it shows a progress bar when you upgrade the DuetWifi firmware?
This would mean the connection DOES work... -
With all the troubleshooting you have done so far, I would open a warranty claim & ask for a replacement, due to damaged during shipping.
One last thing maybe:
how long are your wires? I suppose you are not trying to run a 10feet long cable...?
Maybe try a really short one / newly crimped just to make sure. -
yes... When I upgrade firmware, it is showing me the progress on the screen...
@resam both wires are about 330mm long. (ribbon and 4 pin)
I'll try some of the Jumpers out of my Arduino kits real quick..
Yeah, same deal.. no luck... I'll start a replacement... If it was that badly handled prior to shipping, then god only knows what could have happened to it.. Without probing the entire board, I cannot be positive that there isn't a crack, or open.
Luckily filastruder is 20 min. from me here in Ga. hopefully they'll just let me swing out and swap it.
Thanks for the help!
The stuff I repair is mostly guitar and pro audio amps that get the smoke let out of them because people short the output stage, or cook a power supply. If I can't troubleshoot it with my fluke and a magnifying glass, it goes off to the Ham Radio repair guys down the road..
