    (solved) G28 Error: Bad command
    1038
    • Karim
      Karim last edited by Karim
      I am getting G28 Error: Bad command: ''' Now home Z using the Z probe''' everytime I home my printer, Also if I try home Z axis only I get this below. I am using a mini differential ir height sensor.
      G28 Z
      Error: Bad command: ''' Home Z using the Z probe mounted on the X carriage'''
      Error: G0/G1: insufficient axes homed
      ; generated by RepRapFirmware Configuration Tool v2 on Mon Dec 10 2018 01:47:39 GMT+0000 (GMT)
      M550 P"iDEX" ; Set machine name
      M552 S1 ; Enable network
      M587 S"xx" P"xx" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes reverse
      M569 P1 S0 ; Drive 1 goes reverse
      M569 P3 S0 ; Drive 3 goes reverse
      M569 P4 S1 ; Drive 4 goes reverse
      M569 P5 S0 ; Drive 5 goes reverse
      M584 X0 Y1 Z2 U3 E4:5 ; Drive map X Y Z U E axis
      M350 X16 Y16 Z16 U16 E16:16 I1 ; Configure microstepping with interpolation
      M92 X160 Y160 Z1600 U160 E512.96:512.96 ; Set steps per mm
      M566 X600 Y600 Z12 U600 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z180 U18000 E1500:1500 ; Set maximum speeds (mm/min)
      M201 X3000 Y3000 Z100 U3000 E10000:10000 ; Set accelerations (mm/s^2)
      M906 X950 Y1300 Z1300 U950 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X375 Y390 U422 Z320 S0 ; Set axis maxima
      M208 X-60 Y10 U0 Z0 S1 ; Set axis minima
      M574 X1 Y1 Z0 U2 S0 ; Set active low endstops
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M574 Z0 S2 ; Set endstops controlled by probe
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z1.258 ; Set Z probe trigger value, offset and trigger height
      M557 X30:375 Y50:390 S82 ; Define mesh grid
      M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; Set temperature limit for heater 2 to 280C
      M106 P0 S0 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X0 Y0 U0 Z0 ; Set tool 0 axis offsets
      M563 P1 D1 H2 X3 ; Define tool 1
      G10 P1 X0 Y0 U0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M563 P2 D0:1 H1:2 X0:3 ; Define tool 2 Ditto Printing
      G10 P2 X100 Y0 U-100 Z0 ; Set tool 2 axis Ditto Printing offsets
      G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
      M567 P2 E1:1 ; Set mix rtio 100% on both extruders
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2 on Sat Dec 01 2018 16:55:23 GMT-0800 (Pacific Standard Time)
      G91 ; relative positioning
      G1 S1 X-435 Y-400 U422 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 X5 Y5 F6000 ; go back a few mm
      G1 S1 X-10 Y-10 U10 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 X245 Y200 F2000 S2 ; move to bed centre for probing
      G30 ; probe the bed and set Z height
      ; homex.g
      ; called to home the X axis
      G1 S1 X-435 F3600 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000 ; go back a few mm
      G1 S1 X-10 F360 ; move slowly to X axis endstop once more (second pass)
      G1 Z-5 F6000 S2 ; lower Z again
      G90 ; absolute positioning
      ; homeu.g
      ; called to home the U axis
      G1 S1 U422 F3600 ; move quickly to U axis endstop and stop there (first pass)
      G1 U-5 F6000 ; go back a few mm
      G1 S1 U10 F360 ; move slowly to U axis endstop once more (second pass)
      ; homey.g
      ; called to home the Y axis
      G1 S1 Y-390 F2000 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y5 F6000 ; go back a few mm
      G1 S1 Y-10 F360 ; move slowly to Y axis endstop once more (second pass)
      G91
      G1 Z4 F200 ; raise head 4mm to keep it clear of the bed
      G1 U429 F2000 ; make sure the U carriage is out of the way
      G90
      Solve See in the end of this .
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @Karim last edited by Stephen6309
        @karim said in G28 Error: Bad command: ''' Now home Z using the Z probe''':
        Fix the "Now home Z using the Z probe" line with a ; at the beginning of the line
        Same in the other homing files. The firmware doesn't know what a quoted text line is.
        • Karim
          Hey Stephen Thanks, That fix the first error.
          If I move Z axis down 5mm or 10mm and then try home Z axis only, I get this below. I am using a mini differential IR height sensor. I can home X Y U fine. But Z axis only home when I home all axis. Don't know if this is how it suppose works.
          G28 Z
            You need to add S2 to moves of axis that haven't been homed yet. In your case it might just be easier to always home x and y first.
            • Karim
              Ok, After I home X Y U & Z axis, Everything looks ok, no errors in log, But if I move Z axis down say 10mm and try homing Z axis I get this G28 Z , Error: G0/G1: insufficient axes homed . I am just trying to make sure that Z axis is ok.
              deckingman Stephen6309 2 Replies Last reply Reply Quote 0
                If you compare the example homing files here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_files to what you have you'll see what I mean about missing S2 from your G1 moves that try to move an axis before it's been homed.
                Also take care with G90 and G91 to ensure you're in the right coordinate mode for the moves you want to be doing. Do you want to go to Z5, or just move the bed by 5mm?
                • deckingman
                  deckingman @Karim last edited by
                  @karim Are you saying that if you home all, everything works fine but if you just want to home Z you get the error? It's a long time since I checked but it always used to be the case that you have to home X and Y before you can home Z, which makes sense if you use a probe.
                  • Stephen6309
                    @karim They way I fixed my homing files: In each added S2 to all movements that didn't involve the endstops, the S1 lines.
                    • Karim
                      Here a video explaining what I am trying to say. This might be ok,
                      https://youtu.be/BKMrRjuZcC8
                        Phaedrux Moderator @Karim last edited by
                        @karim So the homeall button turns red when you hit home z to indicate that the machine is no longer fully homed. If the home z were able to complete successfully, the homeall button would turn back to homed state.
                        Can you post the contents of homez.g as it is now?
                        • Karim
                          ; Home Z using the Z probe mounted on the X carriage'''
                          G91
                          G90
                            And if you change it to this, what happens?
                            G91
                            G1 Z4 F200 S2 ; raise head 4mm to keep it clear of the bed
                            G1 U429 F2000 S2 ; make sure the U carriage is out of the way
                            G90
                            • Karim
                              @phaedrux said in G28 Error: Bad command: ''' Now home Z using the Z probe''':
                              S2 Make the U Axis goes into the endstop. Replace S2 to S1 fix that.
                              Now Z axis works but something wired now, look at the video when homing Z axis, X axis move about 20mm then Z home.
                              https://youtu.be/Her4tOeW25w
                              ;Home Z
                              G91
                              G1 U422 F2000 S1 ; make sure the U carriage is out of the way
                              G90
                              ; homeall.g
                              ;Now home Z using the Z probe'''
                                As I said before, you need to pay attention to G90 and G91
                                G90 moves to the absolute position on the bed
                                G91 moves the amount relative to the current location
                                So for your home all it looks like you're still in relative positioning when you should be in absolute positioning to place the print head for probing Z
                                ; homeall.g
                                That should get your print head into the same location for both homeall and homez. Now that may not be the position you expect it to be in, but you can modify that by just changing the coordinates for both.
                                I suspect that your X endstop position is actually a bit off the side of the bed.
                                • Karim
                                  ;Home Z
                                  G91
                                  G90
                                  I think I got now. Machine Status shows X185 Y210
                                  ;Home Z
                                  G91
                                  G90
                                  G1 X185 Y210 F2000 S2 ; move to bed centre for probing
                                  • Karim
                                    Thank you. This was driving me nuts.
