    DuetWifi [back in] stock
    Order discussion
    1678
    • T3P3Tony
      We are expecting to be back in stock by 13 Feb.
      www.duet3d.com
      • iDevelo
        iDevelo last edited by
        Sod's law. Waiting for some parts to finish the sigma so I thought I'd start putting an FT5 together and bang a duet in it!
        I'll build it stock first.
        • Sethipus
          Sethipus last edited by
          I ordered one from Filastruder in the US about an hour ago.
          ps: it'll be my 2nd Duet Wifi, this time for a D-bot which I'm almost finished building. The Duet Wifi on my Monoprice Maker Select v2 has been running like a boss.
          • Raphael
            Raphael last edited by
            May I kindly ask when the Duet Wifi will be back in stock?
            • Cata
              Cata last edited by
              I rebuy last week a duet in filastruder after the RMA refund. Fingers creossed
              • T3P3Tony
                We have received the new stock so should be in a position to restock the website tomorrow.
                www.duet3d.com
                • T3P3Tony
                  DuetWifis are back in stock!, thanks for your patience
                  www.duet3d.com
                  • Fickert
                    Fickert last edited by
                    Can't wait to get my duet in! Also on the FT-5 Train and will later be doing a build log for the whole thing 🙂
                    https://drive.google.com/file/d/0Bxi0uBhn1toSUXJFYTl4d0g0QjQ/view?usp=sharing
                    • iDevelo
                      @Fickert:
                      Awesome. Just for reference:
                      [c]
                      ;; Folgertech FT5 Configuration
                      M111 S0 ; Debugging off
                      G21 ; Work in millimetres
                      M208 X308 Y308 Z360 S0 ; Set axis maxima
                      M574 Y2 X2 Z0 S0 ; Define active high microswitches
                      M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                      G31 P500 X0 Y0 Z2.56 ; Set Z probe trigger value, offset and trigger height
                      M584 X0 Y1:4 Z2 E3 ; Map to specific drives
                      M569 P0 S0 ; Drive 0 goes forwards - X
                      M569 P1 S0 ; Drive 1 goes forwards - Y
                      M569 P2 S1 ; Drive 2 goes forwards - Z
                      M569 P3 S1 ; Drive 3 goes forwards - E0
                      M569 P4 S1 ; Drive 3 goes forwards - Y
                      M92 X80 Y80 Z399 E492.45 ; Set steps per mm
                      M566 X1200 Y1200 Z60 E120 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X8000 Y8000 Z600 E1200 ; Set maximum speeds (mm/min)
                      M201 X1500 Y1500 Z500 E250 ; Set accelerations (mm/s^2)
                      M906 X1000 Y1000 Z1200 E900 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M143 S260 ; Set maximum heater temperature to 260C
                      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heated bed (Heater 0)
                      M305 P1 T100000 B4388 C0 R4700 ; Set thermistor + ADC parameters for E0 (Heater 1)
                      M307 H0 A281.7 C430.4 D4.4 B0 ; Bed PID
                      M307 H1 A344.7 C122.8 D5.5 B0 ; Hotend PID
                      M563 P0 D0 H1 ; Define tool 0
                      G10 P0 X0 Y0 ; Set tool 0 axis offsets
                      M550 PFT5 ; Set machine name
                      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                      M106 P1 S255 I0 F500 H1 T50 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M106 P2 S255 I0 F500 H1 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      T0 ; Select first tool
                      [/c]
