Error: Cannot read file, error code 1. Cancelled printing...
  • Error: Cannot read file, error code 1.
    Cancelled printing file 0:/gcodes/CFFFP_foot.gcode, print time was 6h 21m
    The gcode file was pretty large, around 80MB.
    Something went wrong after over 6 hours. This is one of those random errors you do not want to get.
    The SD card was dismounted, a reboot got it back again. A quick check of the SD card on my PC said all was fine.
    What can I do to avoid this in the future?
    Junk that SD card? Deep format?
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917NK-F23T0-6JKF6-3S46Q-1GA8D
    Used output buffers: 3 of 20 (18 max)
    Static ram: 25524
    Dynamic ram: 98560 of which 0 recycled
    Exception stack ram used: 600
    Never used ram: 6388
    Tasks: NETWORK(ready,544) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)
    Owned mutexes: WiFi(NETWORK)
    Last reset 52:18:21 ago, cause: software
    Last software reset at 2019-01-01 17:56, reason: User, spinning module GCodes, available RAM 6500 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 16
    Free file entries: 10
    SD card longest block write time: 39.7ms, max retries 0
    MCU temperature: min 29.7, current 30.4, max 32.7
    Supply voltage: min 23.9, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/1023
    Driver 1: standstill, SG min/max 0/1023
    Driver 2: standstill, SG min/max 0/295
    Driver 4: standstill, SG min/max 0/1023
    Date/time: 2019-01-03 22:14:28
    Slowest loop: 233.60ms; fastest: 0.08ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 125, MaxWait: 885916ms, Underruns: 0, 2
    Scheduled moves: 1, completed moves: 26
    Bed compensation in use: mesh
    Heater 0 is on, I-accum = 0.0
    Heater 1 is on, I-accum = 0.4
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 181.60ms; fastest: 0.08ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.21
      WiFi MAC address bc:dd:c2:89:a1:c5
      WiFi Vcc 3.36, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 15344
      WiFi IP address 192.168.0.27
      WiFi signal strength -52dBm, reconnections 0, sleep mode modem
    1. Was that the first M122 report you got after the error occurred? I'm surprised that the SD card max retry count is zero.
    2. Was there an "SD card removed" message on the GCode Console or the PanelDue console? If so then a bad solder joint on the SD card socket may be to blame.
  • sigh got another one now. It has been stable for many 10h+ prints since the last time.
    Just like the last time the SD card has been dismounted. I got it back again by removing it and putting it back in.
    I wonder what is wrong. Bad board? Bad PSU? Bad SD?
    I will swap out that SD card for sure.
    7:48:59 PM
    Cancelled printing file 0:/gcodes/CFFFP_BotCenter.gcode, print time was 7h 47m
    8:46:37 PM
    M122
    Used output buffers: 7 of 20 (16 max)
    Static ram: 25524
    Exception stack ram used: 624
    Never used ram: 6364
    Last reset 277:10:30 ago, cause: software
    Last software reset at 2019-01-29 07:35, reason: User, spinning module GCodes, available RAM 6476 bytes (slot 1)
    Error status: 16
    SD card longest block write time: 380.1ms, max retries 0
    MCU temperature: min 26.9, current 29.4, max 33.6
    Supply voltage: min 23.8, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 2: standstill, SG min/max 0/1023
    Driver 3: standstill, SG min/max 0/1023
    Date/time: 2019-02-09 20:45:45
    Slowest loop: 354.78ms; fastest: 0.07ms
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 120, MaxWait: 219817086ms, Underruns: 0, 2
    Scheduled moves: 0, completed moves: 23
    Heater 1 is on, I-accum = 0.5
    Segments left: 0
    === Network ===
    Slowest loop: 555.54ms; fastest: 0.00ms
    • WiFi -
      WiFi flash size 4194304, free heap 14304
      WiFi signal strength -51dBm, reconnections 0, sleep mode modem
  • Guess I could reflow the pins on that SD holder too, should be easy enough. But they look alright.
  • Actually, the soldering looks a bit shady on the right side. I am no professional SMD solderer though.
  • I'm not sure, but it looks like the shield grounds, but nothing I haven't seen before.
    If it makes you feel better put down some flux and kiss those connections with an iron.
    Sounds like an SD issue though.
    Try to get the identical SD card, just so there are no compatibility issues.
  • I possibly have the same issue, was there any resolution to this?
    Same Error: "Error: Cannot read file, error code 1. Cancelling printing"
    I am printing 10 x 24 hour prints I have not changed the file, 7 times it has worked no problem, on 3 prints this error has happened but not in the same place, i.e. it could be anywhere in the print process.
    I do need to resolve this, so some help would be great.
    Below is the diagnostics:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
    Board ID: 08DDM-9FAM2-LW4SD-6J9F6-3S46K-12XMW
    Used output buffers: 1 of 20 (15 max)
    Static ram: 28380
    Dynamic ram: 95872 of which 0 recycled
    Exception stack ram used: 420
    Never used ram: 6400
    Task NETWORK ready, free stack 324
    Task HEAT blocked, free stack 1200
    Task MAIN running, free stack 3592
    Last reset 10:45:36 ago, cause: software
    Last software reset time unknown, reason: User, spinning module GCodes, available RAM 6344 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    MCU temperature: min 40.9, current 41.1, max 41.8
    Supply voltage: min 23.8, current 24.1, max 25.4, under voltage events: 0, over voltage events: 0
    Driver 0: standstill, SG min/max 0/0
    Driver 1: standstill, SG min/max 0/0
    Driver 2: standstill, SG min/max 0/0
    Date/time: 2019-03-27 08:23:58
    Slowest loop: 160.89ms; fastest: 0.08ms
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 236, MaxWait: 317525ms, Underruns: 0, 0
    Scheduled moves: 15, completed moves: 29
    Bed compensation in use: none
    Segments left: 0
    === Network ===
    Slowest loop: 7.73ms; fastest: 0.01ms
    HTTP sessions: 2 of 8
    • WiFi -
      Failed messages: pending 152, notready 0, noresp 0
      WiFi firmware version 1.21RC3(28b1)
      WiFi MAC address 60:01:94:30:06:48
      WiFi flash size 4194304, free heap 14584
      WiFi IP address 192.168.20.30
      WiFi signal strength -56dBm, reconnections 0, sleep mode modem
      === Filament sensors ===
      Extruder 0 sensor: position 0.00, ok, measured sensitivity 2.769mm/pulse +221% --123%
      === Expansion ===
    @nz_andy, upgrade your firmware to 2.02. It includes retry code for when SD card errors occur.
    Both of you, I suggest you replace the SD card.
  • I replaced the SD card. It has worked perfectly since.
    I tested the "bad" SD card on my PC using some SD card testing software. It ran flawlessly for a week (I forgot I had started it).
    But I still threw it away.
  • I have the same problem, I have already burned a lot of plastic for this problem and I don't know what else to do, change SD, install and reinstall to 2.04, the welds are fine ... what can I do?
    I also read this post
    https://forum.duet3d.com/topic/6788/cannot-read-file-error-code-1
    @domingo said in Error: Cannot read file, error code 1. Cancelled printing...:
    Are you saying that you get this error even when using firmware 2.04 and a new SD card?
  • @dc42 unfortunately, the prints always stop at the same point, replace the SD card with a newly purchased one and reinstall all the software, check the connector welds, reconnect and check all the wiring, I don't know what else to try
    Does it give the same error if you run the print in simulation mode?
  • @dc42 if I just tried several models and in simulation they end well,I've tried again in normal mode and I have another half piece Now I have a horde of turtles15741961581151994432976420953033.jpg
    @domingo, which firmware version are you using?
    @domingo, is this still a problem? if so, please report which firmware version you are using.
  • @dc42 RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
    Thanks. There a chance (although not a large one I admit!) that changes to DMA handling in firmware 2.05RC1 may have fixed this, so please try that version.
    I have this issue on my list to resolve in the 2.05 firmware release.
  • @dc42 ok, I update now to 2.05rc1 and I am telling you the progress, thank you very much for the great work and support
    Thanks for that information. Please let me know immediately if the problem returns. For now I will treat it as fixed.
  • @dc42 of course I would let you know, for now, after the last update, the two pieces went well
  • Hello @dc42 , upgrade from Release 2.05RC1 to Release 2.05RC2 and I have the same problems again.
    This is possible?
    any solution?
  • @dc42 ohh the bug has returned in Release 2.05 final
    @domingo, is this still a problem? Are you running firmware 2.05.1 now?
