Issues with M106 and naming of Fan with C option
  • Hi,
    I recently updated the firmware from 2.01 to 2.02
    on a Duet wifi 1.04 board
    • Firmware: 2.02(RTOS) (2018-12-24b1)
    • WiFi Server Version: 1.21
    • Web Interface Version: 1.22.6
    I noticed that my hotend fan wasn't running
    it turns out there may be a bug when using the C option to name a fan with the M106 command
    It used to be like this in the config
    M106 P0 S0 I0 F31 H-1 B1 CPartFan1                             ; Used to cool the part
    M106 P2 S0 I0 F31 H1 L1 T60 CHotendFan1                          ; Used to cool the hotend
    However I noticed when running this at the console I'd get spurious errors like this
    Error: M106: Logical pin H0 is not available to use for fan 2
    It was almost as if the name of the fan couldn't exceed 7 characters for fan 2, or 1 character for fan 0
    Removing the Fan naming fixed the problem
    M106 P0 S0 I0 F31 H-1 B1                             ; Used to cool the part
    M106 P2 S0 I0 F31 H1 L1 T60                          ; Used to cool the hotend
    Sorry for raising this on github originally btw (I should have read the Readme).
  • I belive the format for name is C"name", so you should try : M106 P0 S0 I0 F31 H-1 B1 C"PartFan1"
    @aidar said in Issues with M106 and naming of Fan with C option:
    That's correct. In general, string parameters in GCode commands must always be quoted, except for a few older commands that accept filename parameters, where the quotation marks are optional.
