    Z height when homed is always 206.18
    1193
    • DustinDep
      DustinDep last edited by
      No matter what i do, i can't figure out how to fix this issue. I have built a Kossel Mini and i know my homed height it actually 259mm. I bring the head down to within a piece of paper of the bed and set that as Z0. then when i hit home it doesn't go all the way up only part of the way. If i then hit home a second time it completely ruins my calibration. Please help! i have the homed height in my config.g file set to 259 currently
      • T3P3Tony
        Can you post your config.g and homedelta.g
        www.duet3d.com
        • DustinDep
          ; Configuration file for Duet 0.8.5 (firmware version 1.16)
          ; generated by RepRapFirmware Configuration Tool on Fri Feb 03 2017 10:52:12 GMT-0800 (PST)
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
          M665 R105.6 L215 B85 H259 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
          M574 X2 Y2 Z2 S1 ; Define active high microswitches
          M558 P1 X0 Y0 Z0 H10 F120 T2400 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
          G31 P500 X-18 Y-6 Z1 ; Set Z probe trigger value, offset and trigger height
          M92 X80 Y80 Z80 E663 ; Set steps per mm
          M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
          M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
          M906 X700 Y700 Z700 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M143 S285 ; Set maximum heater temperature to 285C
          M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4388 R4700 ; Set thermistor + ADC parameters for heater 1
          M563 P0 D0 H1 ; Define tool 0
          G10 P0 X0 Y0 ; Set tool 0 axis offsets
          M550 PMiniKossel ; Set machine name
          M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
          M552 P192.168.1.14 S1 ; Enable network and set IP address
          M553 P255.255.255.0 ; Set netmask
          M554 P192.168.1.254 ; Set gateway
          M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          ; Custom settings
          M208 S1 Z-20 ; Set minimum Z
          T0 ; Select first tool
          • DustinDep
            ; homedelta.g
            ; Use relative positioning
            G91
            ; Move all towers to the high end stopping at the endstops (first pass)
            ;*** Slow homing has been configured. Change F240 to F2400 below when your configuration is working
            G1 X210 Y210 Z210 F2400 S1
            ; Go down a few mm
            G1 X-5 Y-5 Z-5 F2400 S2
            ; Move all towers up once more (second pass)
            G1 X10 Y10 Z10 F2400 S1
            ; Move down a few mm so that the nozzle can be centred
            G1 Z-5 F2400
            ; Switch back to absolute positioning and go to the centre
            G90
            G1 X0 Y0 F2400
            • DustinDep
              i just noticed it says Duet firmware 0.8.5 but I'm on duet wifi does that matter?
              Also im using the 1.17 firmware for the wifi
              • T3P3Tony
                You need to change the line in homedelta.g
                To a value larger than the 259 your Z height is.
                Try
                G1 X265 Y265 Z265 F2400 S1
                www.duet3d.com
                • DustinDep
                  Okay now it goes all the way up with the first time hitting Home, but same issue it says my Z height is 206.18.
                  • T3P3Tony
                    How are you probing the bed?
                    www.duet3d.com
                    • DustinDep
                      i have the escher3D IR sensor but i am not even to the point of auto calibration yet
                        If you run M665 with no parameters, what does it report?
