    Web interface, T0 and T1 disappeared!
    599
    • RajaaKahel
      RajaaKahel last edited by RajaaKahel
      After I changed steps/mm, current, accelerations and jerk settings for my two extruders, the web interface is only showing the bed (it was bed, T0 and T1).
      If I refresh the browser they appear for less than a second then they disappear again.
      What's going on? how can I fix this? Thanks!
      • NOVAprint
        NOVAprint last edited by
        I think that you need to select tools somehow or perhaps there is a problem with the labeling of your hotends in the firmware. I have had hardware disappear before and it was usually connected to the listing and naming in tegh config files. Sorry I cannot be more definitive.
        • RajaaKahel
          Thank you, but I didn't understand where to look.
          I haven't changed any other settings other than the ones I mentioned. Everything were fine before the change.
          • RajaaKahel
            @dc42 any way to fix this please? I'm not able to use the printer.
            • deckingman
              deckingman @RajaaKahel last edited by
              @rajaakahel It looks like you've messed something up when you made the changes, so can you post your config.g file then we might be able to see what the problem is.
              RajaaKahel 1 Reply Last reply Reply Quote 0
              • RajaaKahel
                I added them from the "Tools" section. But still don't know what caused that. I hope they stay there now.
                • RajaaKahel
                  RajaaKahel @deckingman last edited by
                  @deckingman I believe it's a bug, I changed only a few things that I know what they do. Will see if this happens again.
                  • RajaaKahel
                    After I added them manually, they stayed for a few minutes, then when I edited the current value for T1, they disappeared again...
                    Here's the settings file:
                    ; generated by RepRapFirmware Configuration Tool on Tue Jun 05 2018 01:10:26 GMT+0200 (CEST)
                    M667 S1 ; Select CoreXY mode
                    M550 PMy printer ; Set machine name
                    M552 S1 ; Enable network
                    M587 S"Xiaomi5772" P"Kahel2000" I192.168.31.206 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                    M586 P0 S1 ; Enable HTTP
                    M586 P1 S0 ; Disable FTP
                    M586 P2 S0 ; Disable Telnet
                    M569 P4 S0 ; Drive 4 goes forwards
                    M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
                    M92 X80 Y80 Z800 E2700:2700 ; Set steps per mm
                    M566 X900 Y900 Z100 E40:40 ; Set maximum instantaneous speed changes (mm/min)
                    M203 X18000 Y18000 Z1000 E5000:5000 ; Set maximum speeds (mm/min)
                    M201 X5000 Y5000 Z100 E120:120 ; Set accelerations (mm/s^2)
                    M906 X1100 Y1100 Z1000 E400:400 I30 ; Set motor currents (mA) and motor idle factor in per cent
                    M84 S60 ; Set idle timeout
                    M208 X430 Y350 Z400 S0 ; Set axis maxima
                    M574 X1 Y1 Z1 S1 ; Set active high endstops
                    ;M574 Z1 S3 ; Set endstops controlled by motor load detection
                    ;M558 P0 H5 F120 T18000 ; Set Z probe type to switch and the dive height + speeds
                    ;G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                    ;M557 X15:385 Y15:335 S20 ; Define mesh grid
                    M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                    M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                    M305 P2 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 2
                    M143 H2 S280 ; Set temperature limit for heater 2 to 280C
                    M106 P0 S0.3 I0 F500 H-1 ; Set fan 0
                    • aidar
                      aidar last edited by
                      Thats it? Or something happened to copy-paste?
                      • RajaaKahel
                        RajaaKahel @aidar last edited by
                        @aidar Sorry? That's my settings in case something is causing the problem.
                        • aidar
                          This config seems to me like not finished, thats why i asked if the end is lost in copy-paste. Anyway, you havent define any tools in your config as i see. Look at https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
                          RajaaKahel 1 Reply Last reply Reply Quote 1
                          • RajaaKahel
                            @aidar Oh, didn't notice that, thank you!
                            I had a back-up and I'v put what was missing, now it seems ok again. Strange, usually I'm very careful when I change something, don't know how that happened.
                            Here are the rest:
                            M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M563 P0 D0 H1 ; Define tool 0
                            M563 P1 D1 H2 ; Define tool 1
                            G10 P1 X0.1 Y0.2 Z-1 ; Set tool 1 axis offsets
                            G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                            • aidar
                              You welcome, i am glad you got it sorted.
