    Trying to avoid running levelling before every print
    882
    • totalitarian
      totalitarian last edited by
      What would be the best strategy of running mesh levelling only when I think I need it?
      I'd like to save the mesh and reuse it on subsequent prints, only needing to probe Z height each time
        It's covered at https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation. Let us know if it isn't clear.
        • totalitarian
          Thanks!
          So just to comfirm,
          G28; home
          G29; level and save mesh
          Then in my gcode I can just run
          G28
          G29 S1; recall
          No need to home after the G29 S1?
            dc42 administrators @totalitarian last edited by
            @totalitarian said in Trying to avoid running levelling before every print:
            Thanks!
            So just to comfirm,
            G28; home
            G28
            G29 S1; recall
            That's correct. You can do a single G30 probe at the centre of the bed after the G29 S1 if you want.
            • totalitarian
              Thanks again, what is the advantage of adding in the extra G30?
                If you home Z using the Z probe by doing a G30 at or near bed centre, then probably none. If you home Z using an endstop switch, then you may get a more precise Z=0 height by doing the extra G30.
                • totalitarian
                  @dc42 said in Trying to avoid running levelling before every print:
                  G28; home
                  I am homing using my probe but use G28 rather than G30.
                    Phaedrux Moderator @totalitarian last edited by
                    @totalitarian G30 would be used in your homeall.g file to probe the Z axis height. G28 calls homeall.g
                    totalitarian 1 Reply Last reply Reply Quote 0
                    • totalitarian
                      totalitarian @Phaedrux last edited by
                      @phaedrux Good point!
                      • IOIIOOO
                        IOIIOOO last edited by
                        If I put G29 S1 in my config.g, do I still need to run it before each print as well or will the mesh stay in memory between prints?
                        Phaedrux dc42 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @IOIIOOO last edited by
                          @ioiiooo https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Using_mesh_bed_compensation_before_printing
                            dc42 administrators @IOIIOOO last edited by
                            @ioiiooo said in Trying to avoid running levelling before every print:
                            It stays in memory, unless you cancel it with M562 or G29 S2.
