TEVO Little Monster + DuetWifi + BLTouch
  • Hello community,
    I have encountered a problem that i simply can not get my head around. I have tried multiple solutions and the step by step guide; https://betrue3d.dk/bltouch-on-duet-wifi-duetreprapfirmware/.
    The BLTouch i acting strange. I can perform a G29, a probe-test; M280 P3 S120 I1 and the BLT works as intended. However, when I want to print a part, with the following start g-code (after successfully doing the Auto Delta Calibration);
    G28 ; Home
    G29 S1 ; Load mesh from previous
    I does not work. The effector moves towards the bed followed by a BLTouch that "clicks" (needle touches the bed). The probe does not retract and ends up going into alarm mode. I have checked the wiring twice and everything is fine. I do not know what is wrong i have tried different modes (Mode/Type of probe) P3, P5 and P9. White the same problem.
    I have cleaned the pin in the BLT.
    I have attached the following settings:
    Config:
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M555 P1 ; Set firmware compatibility to look like RepRapFirmare
    M665 R157 L397.1073 B175 H517.82 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M208 Z0 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Define active high microswitches
    M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
    M557 R130 S20 ; Define mesh grid
    ; BL-Touch
    M307 H3 A-1 C-1 D-1 ; reserve pin 21 for M42 or servo use
    M558 P9 X0 Y20 Z0 H5 F100 R0.2 T6000
    G31 P25 X0 Y0 Z0.733; Set Z probe trigger value, offset and trigger height
    M350 E16 I1 ; Configure microstepping without interpolation
    M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
    M92 X160 Y160 Z160 E892 ; Set steps per mm
    M566 X1500 Y1500 Z1500 E1500 ; Set maximum instantaneous speed changes (mm/min)
    M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
    M906 X1100 Y1100 Z1100 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S298 ; Set maximum heater temperature to 285C
    M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
    M305 P0 T100000 B4607 C8.950070e-8 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M563 P0 D0 H1 F0:2 ; Define tool 0
    M550 PTEVO LM ; Set machine name
    M552 S1
    M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
    M552 P192.168.1.149 S1 ; Enable network and acquire dynamic address via DHCP
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P0 S0 I0 F255 H-1; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F255 H1 T60; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S0 I0 F255 H-1; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    bed.g
    ; bed.g
    ; called to perform automatic delta calibration via G32
    ; generated by RepRapFirmware Configuration Tool on Sat Jul 07 2018 15:37:48 GMT-0700 (Pacific Daylight Time)
    G28 ; home all towers
    M401 ; deploy mechanical Z probe
    ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
    ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
    G30 P0 X0 Y132.28 H0 Z-99999
    G30 P1 X121 Y69.86 H0 Z-99999
    G30 P2 X129.9 Y-75 H0 Z-99999
    G30 P3 X0 Y-150 H0 Z-99999
    G30 P4 X-129.9 Y-75 H0 Z-99999
    G30 P5 X-121 Y69.86 H0 Z-99999
    G30 P6 X0 Y59.15 H0 Z-99999
    G30 P7 X56.09 Y32.38 H0 Z-99999
    G30 P8 X64.95 Y-37.5 H0 Z-99999
    G30 P9 X0 Y-75 H0 Z-99999
    G30 P10 X-64.95 Y-37.5 H0 Z-99999
    G30 P11 X-56.09 Y32.38 H0 Z-99999
    G30 P12 X0 Y0 H0 Z-99999 S6
    ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
    ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
    M402 ; retract mechanical Z probe
    G29
    deployprobe.g
    M280 P3 S160 I1
    M280 P3 S10 I1
    retractprobe.g
    M280 P3 S90 I1
    homedelta.g
    ; homedelta.g
    ; generated by RepRapFirmware Configuration Tool on Mon May 22 2017 22:56:20 GMT-0400 (Eastern Daylight Time)
    ; Use relative positioning
    G91
    ; Move all towers to the high end stopping at the endstops (first pass)
    G1 X550 Y550 Z550 F4800 S1
    ; Go down a few mm
    G1 X-5 Y-5 Z-5 F1800 S2
    ; Move all towers up once more (second pass)
    G1 X10 Y10 Z10 F360 S1
    ; Move down a few mm so that the nozzle can be centred
    G1 Z-5 F6000
    ; Switch back to absolute positioning and go to the centre
    G90
    G1 X0 Y0 F6000
    M280 P3 S10 I1
    Thanks for reading 🙂
    @yeoman91 said in TEVO Little Monster + DuetWifi + BLTouch:
    G28 ; Home
    1. Do those commands work without deploying the BLTouch if you run them by themselves?
    2. Delete the M401 and M402 commands from your bed.g file. They are not needed when using BLTouch and they could be causing probems.
  • @dc42 said in TEVO Little Monster + DuetWifi + BLTouch:
    G29 S1
    1. I have tested G28 and G29 S1 in the G-code console individually without problems.
    2. I have now deleted the M401 and M402, setting the probe to mode P9, however the problemt stays the same.
    I have tried a new Auto Delta Calibration, followed by a new print with the start g-code G28 and G29 S1, resulting in the same issue.
    bed.g
    ; bed.g
    ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights andight only. Use S6 for full 6 factors
    G29
    Please post the first 50 or so lines (excluding any comment lines at the start) of the file you are trying to print. I think something else in that file must be commanding the BLTouch to deploy.
  • Moderator
    Remove the X0 Y20 Z0 from M558, it doesn't belong there.
    And your G31 doesn't have an X and Y offset. That's probably where the Y20 belongs.
    M280 P3 S10 I1
    You've got a deploy probe command at the end of your homedelta.g. I don't think it should be there?
    deployprobe.g
    M280 P3 S160 I1
    M280 P3 S10 I1
    You may need to add a brief dwell command between the two servo commands, but really you shouldn't need to clear an error before deploying the probe when things are working correctly, so maybe try removing the S160 command. If you want to ensure error states are cleared first, add that S160 command to your config.g for startup, and the start of the homing files.
  • @dc42
    ;FLAVOR:RepRap
    ;TIME:1290
    ;Filament used: 2.18283m
    ;Layer height: 0.3236
    ;Generated with Cura_SteamEngine 3.6.0
    T0
    M190 S80
    M104 S200
    M109 S200
    M82 ;absolute extrusion mode
    G28 ; Home
    M83 ;relative extrusion mode
    G1 F2700 E-0.2
    ;LAYER_COUNT:56
    ;LAYER:0
    M107
    G0 F2520 X17.823 Y-12.036 Z0.324
    ;TYPE:SKIRT
    G1 F600 E0.2
    G1 F1470 X18.095 Y-11.757 E0.02992
    G1 X18.611 Y-11.173 E0.05984
    G1 X19.598 Y-9.945 E0.12097
    G1 F1470 X13.387 Y7.825 E0.08014
    ;TIME_ELAPSED:1290.290412
    G1 F2700 E-0.2
    M140 S0
    M107
    G92 E0 ; Set EXT to zero
    G1 E-12 F9000 ; Retract x mm filament
    M104 S0 ; turn off extruder
    M140 S0 ; turn off bed
    G28 ; home all axes
    M104 S0
    ;End of Gcode
    ;SETTING_3 {"extruder_quality": ["[general]\nversion = 4\nname = 0.3236 - TLM
    ;SETTING_3 \ndefinition = fdmprinter\n\n[metadata]\nposition = 0\nsetting_ve
    ;SETTING_3 rsion = 5\nquality_type = normal\ntype = quality_changes\n\n[valu
    ;SETTING_3 es]\ncool_fan_speed = 30\nmaterial_flow = 95\nretraction_amount =
    ;SETTING_3 0.2\nretraction_retract_speed = 45\nspeed_print = 35\nspeed_travel
    ;SETTING_3 = 60\n\n"], "global_quality": "[general]\nversion = 4\nname = 0.
    ;SETTING_3 3236 - TLM\ndefinition = fdmprinter\n\n[metadata]\nsetting_versio
    ;SETTING_3 n = 5\nquality_type = normal\ntype = quality_changes\n\n[values]
    ;SETTING_3 \nlayer_height = 0.3236\nlayer_height_0 = 0.3236\nmaterial_bed_temp
    ;SETTING_3 erature = 80\n\n"}
    @Phaedrux
    I have cleanet my M558, G31 and deployprobe.
    Furthermore, I changed the M558 F100 to F120 and G31 P25 to P500.
    I have finally got it to work! Thank you both, what a struggle. 🙂
  • Moderator
    G31 P25 to P500
    G31 P25 should work and provide quicker response time to a trigger, but if it works, it works. Glad it's sorted.
