Laundry List of small Requests
I doubt this will be any help but I don't understand either.
I think the issue is that @rflulling is getting confused by axis min (low end) and axis max (high end) with switch type active low and active high. The terms are being used interchangeably by statements like this " Simply setting the end stop high only flips the axis in the Home functions. " ........which makes no sense at all.
@rflulling To recap. X1 will tell the firmware that the switch is physically positioned at the low end of the axis - i.e at or close to Xmin. X2 will tell the firmware that the switch is physically fitted to the high end of the axis - i.e at or close to X max. The S parameter is used to tell the firmware what type of switch it is as DC42 explained above. If the switch type is normally closed and connected as it should be, then use S1. If the switch type is normally open, the use S0.
The type of switch cannot affect the direction of homing but we are all confused because that is what you seem to be implying happens.
Or to put it another way, the configurator and the files in generates work for everyone else so it's hard for us to believe that there is a bug, which is what you are implying.
EDIt. It seems that I was typing this at the same time as @fcwilt so I didn't see his post.
@deckingman said in Laundry List of small Requests:
Well that's a relief. I read his posts more than once and simply could not fathom exactly what he was thinking.
I think that this statement he made "Then the bit must be set manually to S0 as the end stops are NOT active. Just mechanical termination" is at the root of the problem.
I would hazard a guess that he is thinking that end stop devices that actually generate a logic level are "active" whereas simple micro switches are not. But, again, that is just a guess.
@rflulling said in Laundry List of small Requests:
For the configuration, the Active high switch must be tagged or the X2 will not be generated. If using the configuration. Simply setting the end stop high only flips the axis in the Home functions. So the solution is to remove the S1 and change it to an S0 as it should be for my configuration. -I did not write any of this code, the firmware, or the configurator. I cannot change how it behaved, only customize the results so that they do what I need.
I'm sorry, I can't reproduce that. I just set this endstop config:
The configurator generated this in config.g:
; Endstops M574 X2 Y1 Z1 S0 ; Set active low and disabled endstops Which is correct.
OK so just to clarify on the
M574
code because I think there is confusion about the terminology.The
M574
command has two parts. The firstXn Yn Zn
describes the physical location of the end-stops: whether is it at the min or max travel of the axis (or whether it is not installed).The second part,
Sn
, describes the logic level of the end-stop input pin when triggered and is described by the terminology 'active [low/high]' The terminology can be a bit confusing but here is a breakdown for the function of standard microswitch endstops:For a Normally Closed (NC) switch, the circuit is connected through the switch until it is pressed, so it will work as follows:
- When switch is not pressed, STP pin is shorted to GND through the switch, resulting in a STP pin logic state of LOW.
- When switch is pressed during homing, the STP to GND connection is broken, so STP is pulled hi through the pullup resistor. Thus a NC switch will result in an 'active high' (
S1
)signal on the STP pin.
For a Normally Open (NO) switch, the circuit will not be connected until it is pressed:
- When switch is not pressed, STP pin will be pulled HIGH through the pullup resistor.
- When switch is pressed during homing, STP pin will be shorted to GND through the switch, resulting in a STP pin logic level LOW. this is 'active low' (
S0
So 'active high' and 'active low' do not refer to which end of the axis the switch is installed on, but rather the logic level of the STP pin when triggered.
So an example config lines might look something like this:
M574 X2 S0
'active low' NO switch connected to X endstop input. X switch is physically installed at the max travel point of the X axis.
M574 Y1 S1
'active high' NC switch conneted to Y endstop input. Y switch is physically installed at the min travel point of the Y axis.
M574 Z0 S0
no 'Z' home switch is installed.We may just be getting the logic level high/low confused with the axis position high/low.
@nhof said in Laundry List of small Requests:
..................................We may just be getting the logic level high/low confused with the axis position high/low.
That makes 4 of us who have come to that conclusion.
Ref @rflulling 's quote " I am getting very distinct feeling of you can lead a horse to water, but you cannot make him drink", - I'd be happy to drink if the water was clear, but I'm being led to a muddy puddle
All you posted seems correct but the config tool seems pretty clear to me with the "Endstop Type" and "Endstop Location" headings.
Thank you for every one trying to understand what I am saying, and over and over coming up with very different solutions to issues I did not request, generating a tangent. I will consider all of your solutions and potentially include them with the guide I am putting together ( will double check to see if they are applicable solutions) Never the less the issue with the inverted axis I was working on is resolved and by no solution provided here. The bug, I am still going to call a bug, can be replicated by any one who stops proving their own solutions to, and inputs the code as I pointed out. Is it really so hard to test? I will even post my entire SD card as very nice and organized PDF that you can copy past into your own Config.g and see how it behaves, assuming you have a physical configuration similar enough that you do not need to make any changes to the test sample. Though honestly I think any one need only input this to see the issue M208 X110 Y0 Z0 S1.
That being said I think at least one reply by DC42 did partially identify why the behavior was as described Topic 3) Thank you.
@dc42 I will also attempt to operate the machine with "M574 X2 Y1 Z1 S0" to test. It runs fine with M574 X2 Y0 Z0 S0, and is currently doing so with S3D over USB2 @ 200% speed with PETG @ 255C and 0.05mm layer height, over USB (using files generated for a Wanhao custom version of Marlin on a Melzi board) on an OEM Duet2Maestro.
I will also look to see if the configuration you screen shot output the same code for me, and follow up. -
@rflulling sorry for getting off topic. I think we all just zero'd in on the end stop description and got hung up on it.
Assume you got the inversion working by inverting motor direction and end-stop location along with relevant homing scripts?
I see your point on the unusual M208 behaviour when given unexpected values. There is recent topic from another user who had the XY axis moving when Z moves were commanded because he had the M208 Ymin value set greater than Ymax (or something like that). A check on the M208 command to ensure that the values given are appropriate might be good.
I'm curious to try the M208 along with the M574 commands tomorrow when I have access to my machines to see what happens.
Did a bit of testing this morning on my machines.
I did not see any abnormal motion if the M208 commands are the same value. e.g.
M208 X0:0
. Motion is normal in this case.
I did not see any abnormal motion with M208 command depending on positive or negative values e.g.M208 X-100:-90
,M208 X-500:500
,M208 X-50:-50
. These worked as expected.
I did see abnormal motion with M208 when min value > max value. e.g.M208 X100:0
,M208 X0:-1
,M208 100:-100
etc. Moves after homing in this case will result in hard to predict motion.Motion was not that different with different values for M574 (for me). This could depend on homing scripts but I didn't bother testing any of this.
I also did not see any non-commanded moves on alternate axes (like XY moves when Z move was commanded), but I am using external drivers on drive 5, 6, and 7 for my axes so that may have an impact.
Poking around in the code, it looks like it may be an issue with the end coordinates of a move being re-calculated if the end points of a move fall outside the axis limits, as this will always be the case if the M208 command has been given inverted axis limit values and may result in the end points of moves being offset by the entire axis length in the opposite direction from the expected one.
I still think the best thing to do would be to add input validation on the M208 command. I think it is reasonable to require that the minimum limit is equal or less than the maximum limit.
Here is the file GCodes2.cpp with a little input validation. I don't have the build set up for RRF so I have not compiled or tested this code and it might need refactoring to clean it up, but the idea is there:
case 208: // Set/print maximum axis lengths. If there is an S parameter with value 1 then we set the min value, else we set the max value. { bool setMin = (gb.Seen('S') ? (gb.GetIValue() == 1) : false); bool seen = false; for (size_t axis = 0; axis < numTotalAxes; axis++) { if (gb.Seen(axisLetters[axis])) { float values[2]; size_t numValues = 2; gb.GetFloatArray(values, numValues, false); if (numValues == 2) { if (values[0] > values[1]) { reply.catf("Invalid %c axis limits, min limit cannot be greater than max limit", axisLetters[axis]); result = GCodeResult::error; } else { platform.SetAxisMinimum(axis, values[0], gb.MachineState().runningM501); platform.SetAxisMaximum(axis, values[1], gb.MachineState().runningM501); } } else if (setMin) { if (values[0] > platform.AxisMaximum(axis) { reply.catf("Invalid %c axis limits, min limit cannot be greater than max limit", axisLetters[axis]); result = GCodeResult::error; } else { platform.SetAxisMinimum(axis, values[0], gb.MachineState().runningM501); } } else { if (values[0] < platform.AxisMinimum(axis) { reply.catf("Invalid %c axis limits, min limit cannot be greater than max limit", axisLetters[axis]); result = GCodeResult::error; } else { platform.SetAxisMaximum(axis, values[0], gb.MachineState().runningM501); } } seen = true; } } if (!seen) { reply.copy("Axis limit"); char sep = 's'; for (size_t axis = 0; axis < numTotalAxes; axis++) { reply.catf("%c %c%.1f:%.1f", sep, axisLetters[axis], (double)platform.AxisMinimum(axis), (double)platform.AxisMaximum(axis)); sep = ','; } } } break;
While this sort of sanity check is doable is this a common enough problem to justify the effort?
Are there other values that should be checked?
Good question! While it is a fringe case, I think it's worth implementing a check because of the reports of axis motion on other axes than the commanded ones. (XY motion when Z move commanded, etc.)
It is ultimately the responsibility of the user to validate their config inputs, however it's not bad to prevent inputs that would break the system or cause undefined behavior.
I think unless there is both a use case and a standard for inverting axis limits and how the inversion would interact with the rest of the system, we may just want to eliminate the potential problems at the source.
I think more validation is always better to make the system more resilient against faults, with the caveat that it should not take control away from the user. A good example would be how the newer firmware versions require homing before axis movement to prevent damage from over-travel, however the user still has the ability to turn this check off with the M564 command.
Ultimately it's up to David to make the decisions of what to include/change anyway, this is just my opinion.
I did see abnormal motion with M208 when min value > max value. e.g. M208 X100:0, M208 X0:-1, M208 100:-100 etc. Moves after homing in this case will result in hard to predict motion.
Thank you, for the effort. I feel like every time I responded to reply one or tried to clarify, the rabbit hole only got longer and further off track from the original issue, and from the original post. It felt like every time I explained the explanation was some how attributed to something else, making me want to forget the post all together.
I honestly just wanted to report some bad behavior as well as make a few requests that seemed reasonable additions. Thank you, @nhof , you took the time to see it for yourself and validate that yes it is there and yes it makes the other axis do unpredictable things. -If requested I would be happy to gather more data in the the possible ways it breaks the code. I had observed more than one kind of bad behavior depending on the settings. But at the core was always that same, any time I input Multiple digits on an Axis of the M208 Command. I did not test to see if this was trickle down, meaning it only effected axis listed after. I did not check to see if I only made Z a high value would X or Y be effected if they were declared first.
I will tell you that the strangest thing i saw was telling X to go home and instead it would produce a behavior something like this. G90 G1 X15 Z25. If I pressed it again it would look like this, G90 G1 X-15 Z25. The result was an odd zigzag as if X was constantly reset. This would go on until Z eventually reached the top, if I kept hitting home.
Another odd one was X would go to the end of the line, without slamming into it, then at X115 gently return at a slower speed to X0 and stop.
The worst were of course, when no mater what was pressed, all axis behaved out order, or as if linked, and no one moved in the right direction despite setting being correct.
M208 X115 S1
, orM208 X-115 S1
, orM208 X10 S1
was called out in all instances, where bad behavior was observed.
-Thus the 1 digit on the S flag, or command M208, any time an axis is given a value greater than 9.
M208 X115 S0
, orM208 X-115 S0
, orM208 X10 S0
, orM208 X0 S0
seem to behave as expected and caused no issues that I know of for certain. -
I noticed a bug in the firmware, too! When I misconfigure my delta printer as a corexy, the X, Y, and Z towers do all sorts of crazy things! Nothing like I'd expect from a delta printer!
Another bug I found was that when I sent the hotend to Z-456 it CRASHED the head into the bed! I had set the axis minima to Z-500 because my setup is not correctly configured. BUG!!!!
Now, now - be kind. Folks make mistakes and learn from them - hopefully.
@bot you are absolutely right, thats not a bug, it's a feature! I was doing it wrong, everything works perfect, it's all perfect.
tested M574 X2 Y1 Z1 S0 and observed no change from M574 X2 Y0 Y0 S0.
Since M574 X2 Y1 Z1 S0 is a combination output by RRF and it offer no changes in behavior, I can put this in my guide. Thank you.
How did you test this?
By switching out the code as-is??
I was running my machine on the prior and it is currently running the later. No observable changes in behavior.
I ran and had been running test prints prior, and have made more prints after. No issues.
