    Best settings for stepper motors ?
    3589
    • StefaanC
      StefaanC last edited by
      Hello , what are the best stepper setting for duet and delta , the print starts ok lays a nice flat bottom print
      after a few layers it mis steps a pressure see picture :
      this my config.g
      ; Think3DPrint3D configuration file for Mini Kossel for testing Duet WiFi
      ; Communication and general
      M111 S0 ; Debug off
      M550 PMiniKosselWiFiTest ; Machine name and Netbios name (can be anything you like)
      M551 Preprap ; Machine password (used for FTP)
      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
      ;*** Wifi Networking
      M552 S1 ; Enable WiFi. Disabled for setup and testing. Enable once set up on your network.
      M555 P2 ; Set output to look like Marlin
      M575 P1 B57600 S1 ; Comms parameters for PanelDue
      G21 ; Work in millimetres
      ; Axis and motor configuration
      M569 P4 S1 ; Drive 4 goes forwards
      M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
      ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
      M665 R143.903 L370.614 B230 H453.409 ; set delta radius, diagonal rod length, printable radius and homed height
      M666 X-0.908 Y0.383 Z0.100 ; put your endstop adjustments here, or let auto calibration find them
      M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
      M92 X80 Y80 Z80 ; Set axis steps/mm
      M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
      M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
      M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
      M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
      ; Thermistors
      M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
      M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
      M106 P1 H-1 ; disable thermostatic mode for fan 1
      ; Tool definitions
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
      ;*** If you have a single-nozzle build, comment the next 2 lines
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
      M92 E663:663 ; Set extruder steps per mm
      ; Z probe and compensation definition
      ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
      M558 P1 X0 Y0 Z0 ; Z probe is an IR probe and is not used for homing any axes
      G31 X0 Y40 Z2.20 P500 ; Set the zprobe height and threshold (put your own values here)
      ;*** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0 ; Axis compensation here
      M208 S1 Z-0.2 ; set minimum Z
      T0 ; select first hot end
        What stepper motors does your delta use?
        • StefaanC
          this stepper for towers : Nema 17 Schrittmotor Bipolar 2A 59Ncm 48mm Körper 4-Leiter.
          Manufacturer Part Number 17HS19-2004S1
          Step Angle 1.8°
          Step Accuracy 5%
          Holding Torque 59Ncm(83.6oz.in)
          Rated Current/phase 2.0A
          Phase Resistance 1.4ohms
          Voltage 2.8V
          Inductance 3.0mH±20%(1KHz)
          Weight 400g
          This one for extruder : 5:1 Planetary Gearbox High Torque Nema 17 Stepper Motor 1.68A DIY CNC.
          Manufacturer Part Number 17HS19-1684S-PG5
          Motor Type Bipolar Stepper
          Step Angle(W/O Gearbox) 1.8°
          Holding Torque 2Nm
          Rated Current/phase 1.68A
          Phase Resistance 1.65ohms
          Recommended Voltage 12-24V
          Inductance 2.8mH±20%(1KHz)
          Gearbox Type Planetary
          Gear Ratio(Exact Gear Ratio) 5 + 2/11
          Efficiency 90%
          Backlash at No-load <=1°
          Max.Permissible Torque 2Nm(283oz-in)
          Moment Permissible Torque 4Nm(566oz-in)
          Shaft Maximum Axial Load 50N
          Shaft Maximum Radial Load 100N
            And what motor currents have you set in your M906 command in config.g? I suggest between 1300 and 1600mA for those tower motors if you are using the Duet WiFi, and about 1000mA for the extruder.
            EDIT: I see you have 1000mA for the axis motors, so you should increase that.
            • elmoret
              elmoret last edited by
              Looks like quite a bit of over extrusion also, could be catching an edge.
              • StefaanC
                • iDevelo
                  iDevelo last edited by
                  Do you have an E setting for M92 in your config file?
                  • iDevelo
                    Ok I see you do further down. Scrap that!
                    • iDevelo
                      Have you checked your esteps?
                      • Dougal1957
                        Dougal1957 last edited by
                        You don't appear to have set a Microstepping for your Z Axis in the M350 line not sure if this would cause it or not TBH but worth a try?
                        • StefaanC
                          M350 what do i put in this line ? i did make not any changes here .
                            If you don't have a M350 command then it defaults to 16x microstepping with interpolation to 256x, which is what most people use.
                            I think it's a combination of over-extrusion as Tim pointed out, causing the nozzle to snag on the print, and insufficient motor current.
                            You have your extruder steps/mm set to 663, which is about right for the RepRap Mini Geared Extruder (which has a gear ratio of around 5:1) but too high for most other extruders. So I repeat idevelo's question: have you calibrated your extruder steps/mm?
                            Also I suggest you increase the XYZ motor current to 1300mA (M906 command in config.g).
                            • StefaanC
                              ok i give a trie to change motors to 1300 and extruder to 663
                              • StefaanC
                                I am manegd to print the lizard.gcode my tower are on 1000mA extruder 800mA
                                extruder steps/mm set to 500 . printhead E3D volcano 0,8mm
                                only issue i have was the temp. setting in the lizard gcode was set too low , i had continues put it back To 210° els it would not stick to my buildtac heatbed .
                                see video :
                                https://youtu.be/hFBDHyYQpVE
