    Duet Delta as plotter?
    My Duet controlled machine
    • peirofundefined
      peirof
      For testing purposes I have think to attach a pen to print head... And use printer as plotter....
      The last pieces I have print don't have the measures in stl...
      I have to generate this gcode manual? Or there are some software to generate the gcode, from a Cad drawing?
      Someone have used Duet as plotter?
      Recomendations, please.
      • oliofundefined
        oliof
        If you can generate SVG files, there are multiple online converters that can convert SVG to STL, which you can then slice to gcode using whatever slicer you like.
