    Duet Wifi upgrade to 1.19 failed and I cannot access my printer.
    4.7k
      You could send M122 then look for the WiFi firmware version in the response. It should be 1.22.
      Condensedcloudundefined 1 Reply Last reply Reply Quote 0
        Phaedrux Moderator @Dougal1957
        @dougal1957 said in Duet Wifi upgrade to 1.19 failed and I cannot access my printer.:
        Is it supposed to open a guy or does it just enable boss command line?
        For me Bossa 1.8 in the applications folder opens a full GUI. Though there appears to be some compatibility issues. For me 1.9 behaves as you describe.
        • Condensedcloudundefined
          Condensedcloud @dc42
          @dc42 Sending M122 from pronterface (w/o getting connected in terminal) :
          M122
          SENDING:M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.0 or 1.01
          Board ID: 08D6M-91AST-L23S4-7J1DG-3S86K-TPXFK
          Used output buffers: 1 of 20 (1 max)
          Static ram: 25524
          Dynamic ram: 98588 of which 0 recycled
          Exception stack ram used: 304
          Never used ram: 6656
          Tasks: NETWORK(ready,1872) HEAT(blocked,1324) MAIN(running,3868) IDLE(ready,200)
          Owned mutexes:
          Last reset 00:00:24 ago, cause: power up
          Last software reset details not available
          Error status: 0
          [ERROR] Error status: 0
          Free file entries: 10
          MCU temperature: min 16.1, current 19.7, max 19.9
          Supply voltage: min 0.0, current 0.6, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: ok, SG min/max not available
          Driver 1: ok, SG min/max not available
          Driver 2: ok, SG min/max not available
          Driver 3: ok, SG min/max not available
          Driver 4: ok, SG min/max not available
          Cache data hit count 41978028
          Slowest loop: 0.28ms; fastest: 0.06ms
          I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
          Scheduled moves: 0, completed moves: 0
          Bed compensation in use: none
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is ready with "M122" in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 0.18ms; fastest: 0.00ms
          HTTP sessions: 0 of 8
          • WiFi -
            Network state is disabled
            WiFi module is disabled
            Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
            Send M552 S0 to enable the WiFi module, then repeat the M122. Then send M552 S1 to try to connect to the AP, give it half a minute to connect, and run M552 again.
            I think your browser may have cached the error message page and not be connecting to the Duet.
              Condensedcloud
              @dc42 Tried clearing cached data in browser (EDIT: also tried a different browser), same result, wall of text:
              Connecting...
              Printer is now online.
              M552 S0
              SENDING:M552 S0
              WiFi module started
              M122
              SENDING:M122
              Static ram: 25524
              Exception stack ram used: 256
              Never used ram: 6704
              Tasks: NETWORK(ready,1492) HEAT(blocked,1296) MAIN(running,3868) IDLE(ready,200)
              Owned mutexes:
              Last reset 00:00:48 ago, cause: power up
              Error status: 0
              MCU temperature: min 16.0, current 21.2, max 21.4
              Supply voltage: min 0.0, current 0.5, max 0.8, under voltage events: 0, over voltage events: 0, power good: no
              Cache data hit count 86005194
              Slowest loop: 99.20ms; fastest: 0.06ms
              Segments left: 0
              === Network ===
              Slowest loop: 1.28ms; fastest: 0.00ms
              • WiFi -
                Network state is running
                WiFi module is idle
                WiFi firmware version 1.22
                WiFi MAC address a0:20:a6:19:45:f5
                WiFi Vcc 3.38, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 33632
              M552 S1
              SENDING:M552 S1
              WiFi module is connected to access point interwebs, IP address 10.0.0.28
              M552
              SENDING:M552
                Please confirm, you have a folder called www in the root of the SD card (not inside /sys), and in that folder is a file called reprap.htm or reprap.htm.gz ?
                  Condensedcloud
                  confirmed: https://imgur.com/a/30g8QEV
                    dc42 administrators @Condensedcloud
                    @condensedcloud, thanks for the image. I can now see the problem. Instead of copying the DuetWebControl-xxx.zip file into /www you need to extract the contents of it into /www.
                      @dc42 I dropped the .zip file into the /www folder I then double clicked it to extract it into the folder. I then followed the Getting Connected to Your Duet Steps into the Terminal. Same result (EDIT: left the .zip file in the /www folder)
                      Dougal1957undefined 1 Reply Last reply Reply Quote 0
                      • Dougal1957undefined
                        Dougal1957 @Condensedcloud
                        @condensedcloud you have 1 level of directories to many in the /www folder. You need to extract the file into /WWW from outside of it and not within it if that makes sense
                        You need to remove the DuetWebControl-1.22.6 folder
                          The image you posted doesn't show reprap.htm.gz or the js and css folders as being directly contained on /www. It only shows them as being contained in /www/DuetWebControl-1.22.6. I guess when you extracted the zip, it created a new folder.
                          Edit: Dougal beat me to it.
                            Condensedcloud
                            YASSSSS, Thank You. Thank You. Thank you Gentleman. I was losing hope and we are online. I thought I had a dead printer on my hand. I've heard you are the best in the business and your customer support has proven it to be so. (not to mention the quietest and smoothest delta I've ever worked with due to your handiwork) I plan on building a few more printers in the near future with some friends and I hope to not be such a pain in the arse for you guys soon. You get my standing ovation for your diligence standing behind your product.
                              Condensedcloud
                              Can I buy you guys a beer?(EDIT where/who do I donate/paypal) I do plan to support the project with future builds utilizing the chip but I do appreciate the above and beyond support you've provided.
                                @condensedcloud said in Duet Wifi upgrade to 1.19 failed and I cannot access my printer.:
                                If you bought a genuine Duet from Duet3d or one of our distributors, then no need to donate because support is part of what you paid for. But beers are always welcome, so if you are at MRRF or 3D meetup Sweden or 3d meetup UK or TCT this year, say hello to Duet3d staff there!
