    Broken SD slot - any options?
    • banolkaundefined
      banolka
      I have a Duet 2 Wifi 1.03 with not working sd slot. Is there a way to run without fixing it ? from USB drive or any other solution that will allow operation in this condition?
        The duet is expecting to find config files on the SD card, so unfortunately, I don't think there is much you can do other than to repair the SD card slot.
        • T3P3Tonyundefined
          T3P3Tony administrators @banolka
          @banolka as @Phaedrux said you do need a working SD card slot. how did it break?
          www.duet3d.com
