    CNC Firmware for the PanelDue
    CNC
    1.2k
    • Adamfilipundefined
      Adamfilip
      Re: CNC Firmware for the PanelDue
      I would love to see a CNC Interface available as an option on panel Due, if there was s toggle setting between 3d print & cnc config.
      • Catalin_ROundefined
        Catalin_RO
        Can I raise two fingers as well? 😉
        P.S. Same hand! Please do not try to think otherwise! 😄
          What would you want removed from the standard interface (temperatures perhaps?), and what would you want added?
            Catalin_RO
            Yes! Temperatures must go away. And it would be great to have spindle control buttons, including some percentage "override" for the spindle speed.
              Is spindle speed override a generally-useful feature, that should be implemented in DWC too?
              What other spindle control buttons would you like: just on-off, or something else?
              • timcurtis67undefined
                timcurtis67
                Spindle on (M3) and on Reverse (M4) along with spindle off (M5) would be handy.
                Also Spindle RPM override and feed override would be great.
                Just my opinions.
                  dc42 administrators @timcurtis67
                  @timcurtis67 said in CNC Firmware for the PanelDue:
                  Just my opinions.
                  Please specify how these functions should interact with the GCode commands to control the spindle. Should a new spindle on/off/reverse command read from the GCode file override the latest command from PanelDue? Should the Spindle RPM override be a scaling factor? The devil is in the specification.
                  There is already a feed rate override, it's the Speed button.
                  • fotomasundefined
                    fotomas
                    I would like to see:
                    • Current coordinates in the move screen (pretty useful for 3D printers too)
                    • Heaters go away, perhaps two columns of macro buttons since a lot can be accomplished with macros
                    • Toggle buttons for macros => two macros or two sections the the same macro for on/off functionality.
                      dc42 administrators @fotomas
                      Added to the wish list. But there is so much on the list for ReprapFirmware that I can't say when I will be working on PanelDueFirmware again.
