    DueUI 1.1.0 is released!
    DueUI
    8
    36
    7.3k
    • gtj0undefined
      gtj0
      Scroll down for the latest release
      https://forum.duet3d.com/topic/9257/dueui-1-1-0-is-released/29
      Last week I announced plans to release an alternate user interface for the Duet.
      https://forum.duet3d.com/topic/9169/preview-dueui-an-alternate-web-interface
      Well, it's ready for testing!
      https://github.com/gtjoseph/DueUI
      Please read the README completely before installing DueUI. The "Known Issues" section has some info that explains why I'm not thrilled with some of the widgets yet.
      Remember, this is test software and meant to be customized by you. WORK IT OUT! I really want feedback (good, bad or ugly) and let's keep the feedback to this thread for now rather than issues filed on GitHub.
      1 Reply Last reply Reply Quote 6
      • gtj0undefined
        gtj0
        I've already got a punch list...
        • Need an option to be able to extrude without a tool selected.
        • Need an option to be able to move without having homed.
        • It isn't clear what the movement speeds units are (mm/min).
        • Need option to specify speeds in mm/sec.
        • The print time seconds aren't being truncated to 0 decimal places.
        • gtj0undefined
          gtj0
          DueUI Release 1.0.0-alpha2 is now available:
          https://github.com/gtjoseph/DueUI/releases/tag/1.0.0-alpha2
          Punch list 2019-02-24
          Code changes:
          • Added ability for jog controls to ignore endstop and homing status.
          • Exposed the jog_command string to the config file so it can be
            customized.
          • Fixed issue where print times weren't truncated to integer seconds.
          • build.sh now appends the version to the zip file name.
          Default config changes (All in the Movement tab):
          • Changed the jog speed dropdowns to display speeds in mm/sec
            but still send speeds in mm/min to the jog controls.
          • Added dropdown to select whether to ignore endstop and/or
            homing status.
          • Added an example jog_command string to the jog_x widget.
          • Changed the E axis jog command string to use M83 for relative
            extrude distances and added a "T0" to automatically select
            a tool.
          • Moved the "Level Bed" button between the "Home All" and
            "Probe" buttons.
          • Reordered the widgets definitions to better match the layout.
          • wilrikerundefined
            wilriker
            Besides that I already created the first pull request I found another issue either with the installation or with the documentation. It says
            When DueUI installs, it creates a default configuration file at /sys/dueui_config_default.json [...]
            but actually the default configuration file is created inside /www/ where the other files are also installed but currently neither DWC1 nor DWC2 show you the contents of this directory and therefore it cannot be copied/edited. Or has something went wrong with my installation?
            P.S.: I started with alpha2
            P.P.S.: It's in your ncftp_push.sh where it additionally uploads dueui_config_default.json to /sys/.
            Manuel
            My Tool Collection
            gtj0undefined 1 Reply Last reply Reply Quote 0
            • gtj0undefined
              gtj0 @wilriker
              @wilriker said in DueUI 1.0.0-alpha is available for testing:
              That's weird. When I upload with DWC (1.22.6) It places the json files in /sys automatically. What version of DWC are you running?
              • wilrikerundefined
                wilriker @gtj0
                @gtj0 said in DueUI 1.0.0-alpha is available for testing:
                I uploaded through DWC2.0.0-RC3. Retried in DWC 1.22.6 and that placed it correctly.
                Manuel
                My Tool Collection
                • gtj0undefined
                  gtj0 @wilriker
                  OK, let me test with DWC 2.0.0.
                  • gtj0undefined
                    gtj0
                    Yeah DWC 2.0.0 places all json files in /www but @chrishamm is going to change it back again.
                    https://forum.duet3d.com/topic/9319/duet-web-control-2-0-0-rc4/4
                    • gtj0undefined
                      gtj0
                      DueUI Release 1.0.0-alpha3 is available
                      • Allow labels to have dynamic values
                        You can now have "label" widgets track dynamic values.
                        The default config file's Fan and LED labels now show the
                        numeric fan and led percentages.
                      • Add capability for "toggle" type buttons.
                      • A new attribute "actions_type" has been added to the widgets.
                        When set to "state", the action in the "actions" array
                        corresponding to the current state will be run.
                      • You can now add the "content" attribute to any widget's "state_style"
                        entries which will actually change the content of the widget
                        depending on the state.
                        A good example of using both capabilities is an ATX Power toggle
                        button where clicking it turns the power on or off depnding on
                        it's current state. The default config file has a new button for
                        just that.
                        If you have multiple actions in a widget and want a dialog to pop
                        up asking which to run, set "actions_type" to "choose".
                        If you have multiple actions and set "actions_type" to "all" or
                        don't specify it at all, all actions will run in sequence.
                      • The settings toggle buttons have been updated to use the new
                        "actions_type" and this changed the values stored in the settings
                        cookie. You'll probably be prompted to turn polling on again
                        the next time you run DueUI.
                      • The browser title is now automatically set to "DueUI" and the
                        hostname of your Duet.
                      • Don't display GCode replies if blank
                      • Add entry for 'O' status to status_map
                      Thanks to @wilriker :
                      • Fix order of loading config in /DueUI/
                        Order of dueui_config.json and dueui_config_default.json in /DueUI/ was switched.
                      • Use document.location.host instead ...hostname
                        This will also capture a non-standard port if one is used. Hostname does not
                        contain the port and makes it necessary to enter the port manually.
                      • gtj0undefined
                        gtj0
                        DueUI Release 1.0.0-alpha4 is available
                        https://github.com/gtjoseph/DueUI/releases/tag/1.0.0-alpha4
                        Add ability to trigger multiple actions on a state or choice type
                        • You can now specify that multiple actions should occur for
                          action_types "state" and "choose" by creating a sub-array
                          as demonstrated in the default config file's ATX Power
                          button.
                        • There's a new action type "log" which can post a log message
                          when triggered. See the ATX Power button example.
                        Fix issue with "actions_type" = "choose"
                        • When action_type is choose and the actions didn't have labels,
                          the pop-up dialog was trying to calculate the button width
                          based on the non-existent label, and failing.
                        • gtj0undefined
                          gtj0
                          DueUI Release 1.0.0-beta1 is now available
                          This release contains an Android App that makes the DueUI experience a little cleaner when used on a tablet. If you're using a tablet running Android 5.1 (Lollipop) or better, or an Amazon Fire tablet 7th generation or better, try it out. You'll have to set "Allow Apps from Unknown Sources" in Settings, Security before installing. Then you should just be able to browse to the APK file in Releases and click it.
                          CHANGES:
                          Update README for the DueUI Android App
                          Add Refresh button to settings
                          • Added a "Refresh" button to the Settings page to assist users
                            of the Android app since there's no browser button in that case.
                          Minor default formatting changes
                          • The current temperatures now always display 1 decimal place.
                          • A 5px margin is now applied to the Main axis position buttons.
                          Initial version of Android WebView App
                          • gtj0undefined
                            gtj0
                            DueUI Release 1.0.0-beta2 is now available
                            Bootstrap
                            • Replaced jQuery-UI backend with Bootstrap.
                            • Now self-hosting all third-party Javascript and CSS.
                              jQuery
                              Bootstrap
                              Bootstrap themes
                              Material Icons
                            • Dropped need for js-cookie.js. Now using standard browser
                              localStorage for saving settings.
                            • Reimplemented the "choose" dialogs with bootstrap popups.
                            • Reimplemented the "state_style" options in the config file.
                              !!! CHANGES ARE REQUIRED TO YOUR DUEUI_CONFIG.JSON FILE !!!
                              !!! See CHANGES.md for more information !!!
                            • Updated dueui_config_default.json.
                            You can test this release before installing it by visiting:
                            http://dueui.org/test/index.html
                            Forgot to mention...
                            If you use the Android app, you need to update it: http://dueui.org/test/DueUI.apk
                            devleonundefined 1 Reply Last reply Reply Quote 2
                            • devleonundefined
                              devleon @gtj0
                              @gtj0 Awesome! Thanks very much for your hard work, much appreciated. Will give it a try once I'm home.
                              • gtj0undefined
                                gtj0
                                Looks like the Print Progress bar is messed up. There'll be a new release shortly to fix that.
                                • gtj0undefined
                                  gtj0
                                  DueUI Release 1.0.0-beta3 is now available
                                  Polling updates
                                  • Refactored polling to be more friendly to the Duet by not sending requests for multiple response levels in quick succession.
                                  • Updated the default intervals to 1000ms for level 1, 0 (disabled) for level 2 and 5000ms for level 3.
                                  Fix Print Progress bar and paths in ncftp_push.sh
                                  • The print progress bar was using the wrong method to set the current percentage.
                                  • ncftp_push.sh needed to have the source path updated.
                                  Enable localStorage in WebView
                                  • The Android app's WebView settings didn't enable localStorage which is now needed to store DueUI settings since we stopped using cookies.
                                  NOTE: You do NOT need to reinstall the Android app for new releases unless specifically instructed. The app automatically picks up any changes you make to your DueUI installation.
                                  • gtj0undefined
                                    gtj0
                                    DueUI 1.0.0-beta4 is available for testing.
                                    https://github.com/gtjoseph/DueUI/releases/tag/1.0.0-beta4
                                    http://dueui.org/
                                    Added a Heightmap Heatmap display
                                    • A new widget "heightmap" has been added that grabs /sys/heightmap.csv
                                      from the Duet and creates a simple 2D heat map and statistics.
                                    • dueui_config_default.json was updated with a new "HeightMap" page
                                      inserted between Movement and Console.
                                      I'm somewhat embarassed by the implementation but it does work
                                      and it doesn't require any new third-party libraries.
                                    Fixed issue where GCode responses weren't being shown
                                    • GCode responses for long running commands (like bed levelling)
                                      are now being displayed correctly.
                                    • The "get_reply" parameter of the "gcode" action is now ignored
                                      since all gcode replies are automatically displayed.
                                    Here's a sample of the HeightMap:
                                    Stephen6309undefined 1 Reply Last reply Reply Quote 1
                                    • Stephen6309undefined
                                      Stephen6309 @gtj0
                                      @gtj0 said in DueUI 1.0.0-beta4 is available for testing:
                                      Nice, but there is a speeling error 🙂
                                      • gtj0undefined
                                        gtj0 @Stephen6309
                                        @stephen6309 said in DueUI 1.0.0-beta4 is available for testing:
                                        It was an April Fool's joke. 🙂
                                        • BearcatTDundefined
                                          BearcatTD
                                          So if we choose the option of having the software on the DueUI website, it will automagically be updated as changes are pushed out?!
                                          Thanks for your work on this, as a chronic early adopter I look forward to taking a run at it!
                                          Pat
                                          Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
                                          Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
                                          • gtj0undefined
                                            gtj0 @BearcatTD
                                            @bearcattd said in DueUI 1.0.0-beta4 is available for testing:
                                            Pat
                                            Yep. A new version will be up tomorrow in fact.
