    DueUI 1.1.0 is released!
    DueUI
    8
    36
    7.2k
    • wilrikerundefined
      wilriker @gtj0
      @gtj0 said in DueUI 1.0.0-alpha is available for testing:
      That's weird. When I upload with DWC (1.22.6) It places the json files in /sys automatically. What version of DWC are you running?
      I uploaded through DWC2.0.0-RC3. Retried in DWC 1.22.6 and that placed it correctly.
      Manuel
      My Tool Collection
      • gtj0undefined
        gtj0 @wilriker
        @wilriker said in DueUI 1.0.0-alpha is available for testing:
        OK, let me test with DWC 2.0.0.
        • gtj0undefined
          gtj0
          Yeah DWC 2.0.0 places all json files in /www but @chrishamm is going to change it back again.
          https://forum.duet3d.com/topic/9319/duet-web-control-2-0-0-rc4/4
          • gtj0undefined
            gtj0
            DueUI Release 1.0.0-alpha3 is available
            • Allow labels to have dynamic values
              You can now have "label" widgets track dynamic values.
              The default config file's Fan and LED labels now show the
              numeric fan and led percentages.
            • Add capability for "toggle" type buttons.
            • A new attribute "actions_type" has been added to the widgets.
              When set to "state", the action in the "actions" array
              corresponding to the current state will be run.
            • You can now add the "content" attribute to any widget's "state_style"
              entries which will actually change the content of the widget
              depending on the state.
              A good example of using both capabilities is an ATX Power toggle
              button where clicking it turns the power on or off depnding on
              it's current state. The default config file has a new button for
              just that.
              If you have multiple actions in a widget and want a dialog to pop
              up asking which to run, set "actions_type" to "choose".
              If you have multiple actions and set "actions_type" to "all" or
              don't specify it at all, all actions will run in sequence.
            • The settings toggle buttons have been updated to use the new
              "actions_type" and this changed the values stored in the settings
              cookie. You'll probably be prompted to turn polling on again
              the next time you run DueUI.
            • The browser title is now automatically set to "DueUI" and the
              hostname of your Duet.
            • Don't display GCode replies if blank
            • Add entry for 'O' status to status_map
            Thanks to @wilriker :
            • Fix order of loading config in /DueUI/
              Order of dueui_config.json and dueui_config_default.json in /DueUI/ was switched.
            • Use document.location.host instead ...hostname
              This will also capture a non-standard port if one is used. Hostname does not
              contain the port and makes it necessary to enter the port manually.
            • gtj0undefined
              gtj0
              DueUI Release 1.0.0-alpha4 is available
              https://github.com/gtjoseph/DueUI/releases/tag/1.0.0-alpha4
              Add ability to trigger multiple actions on a state or choice type
              • You can now specify that multiple actions should occur for
                action_types "state" and "choose" by creating a sub-array
                as demonstrated in the default config file's ATX Power
                button.
              • There's a new action type "log" which can post a log message
                when triggered. See the ATX Power button example.
              Fix issue with "actions_type" = "choose"
              • When action_type is choose and the actions didn't have labels,
                the pop-up dialog was trying to calculate the button width
                based on the non-existent label, and failing.
              • gtj0undefined
                gtj0
                DueUI Release 1.0.0-beta1 is now available
                This release contains an Android App that makes the DueUI experience a little cleaner when used on a tablet. If you're using a tablet running Android 5.1 (Lollipop) or better, or an Amazon Fire tablet 7th generation or better, try it out. You'll have to set "Allow Apps from Unknown Sources" in Settings, Security before installing. Then you should just be able to browse to the APK file in Releases and click it.
                CHANGES:
                Update README for the DueUI Android App
                Add Refresh button to settings
                • Added a "Refresh" button to the Settings page to assist users
                  of the Android app since there's no browser button in that case.
                Minor default formatting changes
                • The current temperatures now always display 1 decimal place.
                • A 5px margin is now applied to the Main axis position buttons.
                Initial version of Android WebView App
                • gtj0undefined
                  gtj0
                  DueUI Release 1.0.0-beta2 is now available
                  Bootstrap
                  • Replaced jQuery-UI backend with Bootstrap.
                  • Now self-hosting all third-party Javascript and CSS.
                    jQuery
                    Bootstrap
                    Bootstrap themes
                    Material Icons
                  • Dropped need for js-cookie.js. Now using standard browser
                    localStorage for saving settings.
                  • Reimplemented the "choose" dialogs with bootstrap popups.
                  • Reimplemented the "state_style" options in the config file.
                    !!! CHANGES ARE REQUIRED TO YOUR DUEUI_CONFIG.JSON FILE !!!
                    !!! See CHANGES.md for more information !!!
                  • Updated dueui_config_default.json.
                  You can test this release before installing it by visiting:
                  http://dueui.org/test/index.html
                  Forgot to mention...
                  If you use the Android app, you need to update it: http://dueui.org/test/DueUI.apk
                  devleonundefined 1 Reply Last reply Reply Quote 2
                  • devleonundefined
                    devleon @gtj0
                    @gtj0 Awesome! Thanks very much for your hard work, much appreciated. Will give it a try once I'm home.
                    • gtj0undefined
                      gtj0
                      Looks like the Print Progress bar is messed up. There'll be a new release shortly to fix that.
                      • gtj0undefined
                        gtj0
                        DueUI Release 1.0.0-beta3 is now available
                        Polling updates
                        • Refactored polling to be more friendly to the Duet by not sending requests for multiple response levels in quick succession.
                        • Updated the default intervals to 1000ms for level 1, 0 (disabled) for level 2 and 5000ms for level 3.
                        Fix Print Progress bar and paths in ncftp_push.sh
                        • The print progress bar was using the wrong method to set the current percentage.
                        • ncftp_push.sh needed to have the source path updated.
                        Enable localStorage in WebView
                        • The Android app's WebView settings didn't enable localStorage which is now needed to store DueUI settings since we stopped using cookies.
                        NOTE: You do NOT need to reinstall the Android app for new releases unless specifically instructed. The app automatically picks up any changes you make to your DueUI installation.
                        • gtj0undefined
                          gtj0
                          DueUI 1.0.0-beta4 is available for testing.
                          https://github.com/gtjoseph/DueUI/releases/tag/1.0.0-beta4
                          http://dueui.org/
                          Added a Heightmap Heatmap display
                          • A new widget "heightmap" has been added that grabs /sys/heightmap.csv
                            from the Duet and creates a simple 2D heat map and statistics.
                          • dueui_config_default.json was updated with a new "HeightMap" page
                            inserted between Movement and Console.
                            I'm somewhat embarassed by the implementation but it does work
                            and it doesn't require any new third-party libraries.
                          Fixed issue where GCode responses weren't being shown
                          • GCode responses for long running commands (like bed levelling)
                            are now being displayed correctly.
                          • The "get_reply" parameter of the "gcode" action is now ignored
                            since all gcode replies are automatically displayed.
                          Here's a sample of the HeightMap:
                          Stephen6309undefined 1 Reply Last reply Reply Quote 1
                          • Stephen6309undefined
                            Stephen6309 @gtj0
                            @gtj0 said in DueUI 1.0.0-beta4 is available for testing:
                            Nice, but there is a speeling error 🙂
                            • gtj0undefined
                              gtj0 @Stephen6309
                              @stephen6309 said in DueUI 1.0.0-beta4 is available for testing:
                              It was an April Fool's joke. 🙂
                              • BearcatTDundefined
                                BearcatTD
                                So if we choose the option of having the software on the DueUI website, it will automagically be updated as changes are pushed out?!
                                Thanks for your work on this, as a chronic early adopter I look forward to taking a run at it!
                                Pat
                                Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
                                Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
                                • gtj0undefined
                                  gtj0 @BearcatTD
                                  @bearcattd said in DueUI 1.0.0-beta4 is available for testing:
                                  Pat
                                  Yep. A new version will be up tomorrow in fact.
                                  • gtj0undefined
                                    gtj0
                                    DueUI 1.0.0 is released!
                                    http://dueui.org
                                    Menubar Improvements
                                    • You can now add a "button_defaults" parameter to the "menubar"
                                      widget to set things like common styles.
                                         "menubar": {
                                                 "id": "dueui_menubar",
                                                 "type": "panel",
                                                 "enabled": true,
                                                 "button_defaults": {
                                                         "style": {
        "margin-right": "5px"
                                    • You can now add a "menubar_button" parameter to "tab_panel"
                                      panels to set custom styles for a menubar button.
                                         "id": "dueui_panel_main",
                                         "type": "tab_panel",
                                         "enabled": true,
                                         "menu_button": {
                                                 "value": "Main",
                                                 "style": {
                                                         "background-color": "yellow"
                                    Fix handling of "macro" action
                                    • The macro action was double-prepending macro names with "/macros"
                                    • Now the "macro" action can take EITHER a "file" or "macro"
                                      parameter. If "file", you must supply the full path to the
                                      macro file such as "/macros/mymacro". If "macro", you must
                                      supply a file name relative to the "/macros" directory such as
                                      "mymacro" which will automatically be converted to "/macros/mymacro".
                                    Added "message" parameter to gcode action
                                    • You can now add a "message" parameter to a gcode action
                                      to display a message in the console window when the action
                                      is executed.
                                    Fix heightmap auto-refresh
                                    • The heightmap widget was listening to the wrong event to
                                      detect when a mesh probe was completed.
                                    Add new "cgi" and "http" actions
                                    • You can now use "cgi" as an action to run one of the built-in
                                      Duet CGI programs like rr_delete, rr_move, etc.
                                    • You can now use "http" as an action to execute any HTTP GET
                                      you like.
                                    Examples:
                                      "actions": [
                                            {"type": "cgi", "cgi": "rr_delete",
                                                    "params": "name=/sys/heightmap.csv",
                                                    "message": "Heightmap deleted"},
                                            {"type": "http", "uri": "http://any.url.com?someparam=ZZZ"}
                                    Fix autocomplete results showing all entries
                                    Send M115 after connecting to get firmware info
                                    Correct the description of the 'Simulate GCode' settings button
                                    Fix typo in heightmap legend low character and spacing in stats
                                      T3P3Tony administrators
                                      @gtj0 looking really good in the screen shots. Tried to load it from the http://dueui.org/ but CORB is not allowing connection.
                                      VM21:1 Cross-Origin Read Blocking (CORB) blocked cross-origin response http://192.168.4.20//rr_connect?password=reprap with MIME type text/html. See https://www.chromestatus.com/feature/5629709824032768 for more details.
                                      looks to be a feature of Chromium rather than an issue with DueUI, just wondered if i was missing something obvious?
                                      • gtj0undefined
                                        gtj0 @T3P3Tony
                                        @t3p3tony said in DueUI 1.0.0 is released!:
                                        Hmmm. I tried Chrome, Chromium, Firefox and Vivaldi all without issue. Is it possible that the build of RRF you're running isn't sending the Access-Control-Allow-Origin: * HTTP header?
                                          T3P3Tony administrators @gtj0
                                          @gtj0 thats indeed very possible! I am DWC 1.22.6 & 2.03beta3 on that particular printer - what are you using?
                                          • gtj0undefined
                                            gtj0 @T3P3Tony
                                            That's exactly what I'm using. @gtj0 scratches head.
                                            If you have a few minutes to troubleshoot, could you right click and "Inspect", then select the "Network" tab, then refresh. If you then click on the request. You should see something like the following...
                                            Do the response headers have the Access-Control-Allow-Origin: *?
