    Printing stops after a few hours
    • buetuserundefined
      buetuser
      Hi
      I was printing a file and my printer stopped part way through and showed the fault :-
      Error: Cannot read file, error code 1.
      Cancelled printing file ShortABS_Lion_Head.gcode, print time was 3h 22m
      This is the second time it has stopped after printing for a few hours, this is with 2 different files and the time was not exactly the same but perhaps about 3 hours the first time and as you can see 3h 22m the second time.
      What does error code 1 mean and what are some reasons why it would just stop reading the file.
      Thanks for any help.
      • deckingmanundefined
        deckingman
        Please read this
        https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
        • buetuserundefined
          buetuser
          Hi
          Sorry for not including this info in the first post.
          My printer is a diy corexy the controller is Duet 2 Ethernet
          Firmware Electronics: Duet Ethernet 1.02 or later
          Firmware Version: 2.02RC1(RTOS) (2018-08-31b4)
          Web Interface Version: 1.22.3
          My config 0_1550956108785_config.g
          I have checked and read all the posts I could find on this subject but I could not find any answers.
          Thanks
            deckingman @buetuser
            @buetuser If the firmware can't read the file, then it might be a corrupt SD card? Someone else might have a better idea but I suggest you try another SD card. If it happens again, run M122 and post the results - that might provide some information.
            Oh, and it might be worth upgrading your firmware from RC1 to 2.02 stable but I doubt that's the cause of your problem.
              Upgrade to the 2.02 release, and if it happens again (or you don't want to risk another print), replace the SD card.
              • buetuserundefined
                buetuser
                Thank you for responding. I have now upgraded to 2.02 release and I will order a new SD card. I hope this solves the problem.
                Is there a particular SD card that is recommended for use with the Duet 2?
                Thank you for any advice.
                  dc42 administrators @buetuser
                  Any good brand SD card should do, speed class 4 or higher. Format it with the highest cluster size possible, which is normally 64kb or 32kb.
