    Nozzle crashes during print start or stops too high
    1336
    • bellus
      bellus last edited by
      Disclaimer; I'm completely new to Reprap firmware, came from an old printrboard running marlin. I'm completely lost, everything seems to work fine, homes like it supposed to, heats, moves expectedly. every time I try to start a print Z homes via BL touch then either stops too high or digs into the bed. I've tried reading other posts, but I believe I'm just missing something obvious
      Heres the config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 05 2019 20:31:22 GMT-0700 (MST)
      M550 P"pain in my Ass!" ; Set machine name
      M552 S1 ; Enable network
      M587 S"Bellus" P"Elb44060" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P4 S1 ; Drive 4 goes forwards
      M350 X128 Y128 Z64 E32:32 I0 ; Configure microstepping without interpolation
      M92 X638.88 Y638.88 Z1600.00 E591.18:591.18 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z600.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E100.00:100.00 ; Set accelerations (mm/s^2)
      M906 X1100.00 Y1100.00 Z1600.00 E1000.00:1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X260 Y220 Z300 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H5 F240 T2400 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z4.0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:220 Y15:210 S15 ; Define mesh grid
      M143 H0 S110 ; Set temperature limit for heater 0 to 110C
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S250 ; Set temperature limit for heater 1 to 250C
      M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S250 ; Set temperature limit for heater 2 to 250C
      M106 P0 S1 I0 F500 H1 T180 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H2 T180 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 S"Right" D0 H1 ; Define tool 0
      M563 P1 S"Left" D1 H2 ; Define tool 1
      G10 P1 X16 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      T0 ; Select first tool
      homeZ
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 05 2019 20:31:23 GMT-0700 (MST)
      G91 ; relative positioning
      G1 Z5 F2400 S2 ; lift Z relative to current position
      G90 ; absolute positioning
      G1 X15 Y15 F2400 ; go to first probe point
      G30 S2 ; home Z by probing the bed
      ;G91 ; relative positioning
      ;G1 S2 Z5 F40 ; lift Z relative to current position
      ;G90 ; absolute positioning
      I have tried to change the probe offset, don't believe it helped.
        @bellus said in Nozzle crashes during print start or stops too high:
        How did you measure your Z probe offset? 4mm would be abnormally large for the BLTouch. The guidelines for BLTouch install says the base of the probe body must be 8mm above the nozzle tip. This leads to a trigger height close to 2mm.
        M558 F240 is a bit fast for probing speed. Try half that for better reliability.
        G31 P500 could be reduced to P25 to make it more responsive.
        I'm also a little concerned that your high microstepping might be causing some missed steps. If you send a M122 in the console, check the diagnostics report for any reported hiccups.
        I would suggest that you use x16 microstepping with interpolation enabled to start with. You'll get the best performance and quietest operation. If you still want to play around with other microstepping once everything is running smoothly it'll be easier if you start with a base steps per mm calculation for x16 anyway because if you change the microstepping after it's already set for x16 the firmware will automatically calculate the new steps per mm for you.
        ex:
        M350 X16 Y16 Z16 E16 I1                           	; Configure microstepping
        M92 X200 Y200 Z6400 E805                           	; Set steps per mm
        M350 E64 I0 ; higher extruder microstepping
        Remove the S2 from that line in your homez
        • bellus
          So I went through and implemented the suggested changes. I also ran M122, no hiccups or errors. It still does the same thing. Homes prior to print start perfectly, raises slightly then lowers to star printing with the nozzle contacting the bed. Enough that it compresses the bed springs.
          I was originally thinking it had something to do with the Zoffset so I tried a bunch of different settings from 0 to 4. It’s back at 2.
          M350 X16 Y16 Z16 E16:16 I0 ; Configure microstepping without interpolation
          M92 X79.86. Y79.86 Z400.0 E295.59:295.59. ; Set steps per mm
          M558 P9 H5 F120 T2400 ; Set Z probe type to bltouch and the dive height + speeds
          G31 P25 X0 Y0 Z2.0 ; Set Z probe trigger value, offset and trigger height
          I really appreciate you taking the time to help me out, like I said I’m kind of lost. I’m sure it’s something simple, I’m just not 100% good with this new board.
          • Hornetrider
            Hornetrider last edited by Hornetrider
            @bellus
            please check if you have a "resurrect" file in the system folder.
            If yes, delete it and try again.
            I had issues when doing an emergency stop during a print. The resurrect file was created and this messed up while starting new prints causing the nozzle to have different heights...even after reboot.
            I know check the system folder for this file and delete it...
            Good luck.
              As a way to eliminate the probe hardware from the equation entirely and to test the Z axis positioning specifically, you can switch over to use M558 P0probe type. That will use manual jogging whenever G30 is called. So you'll have to use the display to drop the nozzle down until it just touches the bed.
              https://duet3d.dozuki.com/Wiki/GCode#Section_M558_Set_Z_probe_type
              bellus 1 Reply Last reply Reply Quote 0
                To find your Z probe trigger height (G31 Z parameter), see https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
                Hint: if your printer digs into the bed when starting the print, your G31 Z parameter is too high.
                • bellus
                  bellus @Phaedrux last edited by
                  @phaedrux said in Nozzle crashes during print start or stops too high:
                  So I tried this first, manually jogging this during homing works as advertised. BUT, when starting a print, X & Y home and then the pop up for Z comes up but it’s un-responsive. Clicking of the Z movements does nothing.
                  • bellus
                    bellus @dc42 last edited by
                    @dc42 said in Nozzle crashes during print start or stops too high:
                    I think I understand the Z offset better now. I followed the calibration. I repeatdably got 2.053 about 6 times. But it still drives into the bed, granted not as bad though.
                      Does this problem only occur when you start a print file, or does it also occur if you try to home the printer manually?
                      If it only occurs when you try to print a file, please post the first 50 or so non-comment lines of the print file.
                      You have your max Z speed set to 600mm/min in M203, which is quite high seeing that your Z steps/mm is 1600 in M92. You may be losing Z steps because of trying to move the Z axis too fast.
                      • bellus
                        Correct, only while starting a print. All axises home correctly, then Z lifts approximately 10mm or so. when the print begins Z descend right into the bed. Every time I have initiated homing and even during mesh bed compensation it works flawlessly.
                        *M107
                        M190 S75 ; set bed temperature and wait for it to be reached
                        M104 S215 ; set temperature
                        G28 ; home all axes
                        G1 Z5 F5000 ; lift nozzle
                        ; Filament gcode
                        M109 S215 ; set temperature and wait for it to be reached
                        G21 ; set units to millimeters
                        G90 ; use absolute coordinates
                        M82 ; use absolute distances for extrusion
                        G92 E0
                        G1 E-2.00000 F120.00000
                        G92 E0
                        G1 Z0.400 F4800.000
                        G1 X92.212 Y89.205 F4800.000
                        G1 E2.00000 F120.00000
                        G1 F1800
                        G1 X92.637 Y88.772 E2.03205
                        G1 X93.334 Y88.124 E2.08232
                        G1 X94.213 Y87.375 E2.14338
                        G1 X94.781 Y86.937 E2.18124
                        G1 X95.550 Y86.380 E2.23146
                        G1 X96.106 Y86.019 E2.26650
                        G1 X96.726 Y85.657 E2.30444
                        G1 X97.515 Y85.234 E2.35171
                        G1 X98.203 Y84.918 E2.39175
                        G1 X98.683 Y84.737 E2.41883
                        G1 X99.722 Y84.395 E2.47665
                        G1 X100.566 Y84.160 E2.52297
                        G1 X101.231 Y83.990 E2.55923
                        G1 X102.131 Y83.819 E2.60765
                        G1 X103.208 Y83.738 E2.66472
                        G1 X115.192 Y83.690 E3.29807
                        G1 X115.923 Y83.724 E3.33670
                        G1 X117.305 Y83.876 E3.41018
                        G1 X118.207 Y84.029 E3.45857
                        G1 X118.740 Y84.140 E3.48733
                        G1 X119.694 Y84.389 E3.53943
                        G1 X120.474 Y84.642 E3.58274
                        G1 X121.308 Y84.964 E3.63003
                        G1 X121.874 Y85.211 E3.66264
                        G1 X122.669 Y85.599 E3.70938
                        G1 X123.829 Y86.239 E3.77942
                        G1 X124.366 Y86.575 E3.81288
                        G1 X125.088 Y87.072 E3.85922
                        G1 X125.606 Y87.463 E3.89348
                        G1 X126.270 Y88.014 E3.93909
                        G1 X127.206 Y88.867 E4.00600
                        G1 X128.109 Y89.792 E4.07437
                        G1 X128.509 Y90.248 E4.10639
                        G1 X129.330 Y91.292 E4.17656
                        I did go ahead and change M203 to 100mm to see if that made a difference and did not.
                          Can you post your homeall file?
                          • bellus
                            @phaedrux
                            ; homeall.g
                            ; called to home all axes
                            M98 Pdeployprobe.g ; deploy mechanical Z probe
                            G1 S1 X-245 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                            G1 X5 Y5 F2400 ; go back a few mm
                            G1 S1 X-245 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
                            G1 X15 Y15 F2400 ; go to first bed probe point and home Z
                            M98 Pretractprobe.g ; retract mechanical Z probe
                              Phaedrux Moderator @bellus last edited by
                              Remove those from your homeall. The G30 command will deploy and retract as needed. This could be causing your issue.
                              • bellus
                                ![alt text](image url)@phaedrux said in Nozzle crashes during print start or stops too high:
                                Removed as suggested, no change. The only thing that seems to help is to Z offset. Running the calibration of the probe I would religiously get right around 2mm. I changed it to .75mm and it wasn’t as bad.
                                • bellus
                                  Here’s a quick video https://youtu.be/Jux1Wyts-B0
                                  • bellus
                                    bellus @bellus last edited by
                                    @bellus
                                    At 0 even it’s not crashing and actually attempting to print. Nozzles about .5mm to high.
                                      So what command was running in that video? It probed once and then dropped the nozzle into the bed. Was that G28? G29? G30? G32?
                                      • bellus
                                        @phaedrux
                                        It’s the G28 command, when it starts a print, probes once, then nose dives. I was actually able to get past that point by changing the Z offset to 0, but like I said it’s a bit high(roughly 1mm). I re-measured the Bl touch base from the nozzle tip, it’s almost exactly 8mms.
                                          Can you post the contents of your config-override.g file?
                                          • bellus
                                            @phaedrux
                                            As requested,
                                            ; Heater model parameters
                                            M307 H0 A66.5 C483.4 D6.2 S1.00 V12.1 B0
                                            M307 H1 A680.2 C325.1 D11.5 S1.00 V12.0 B0
                                            M307 H2 A633.9 C320.4 D13.3 S1.00 V12.0 B0
                                            M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                            M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                            M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                            M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                            I also was to able to set the trigger height to 0.500 with positive results. It’s printing, albeit a blobby mess, just needs a bit of tuning. Honestly don’t know why the trigger height is so low compared the calibration steps, but it’s working.
                                            M92 X79.86. Y79.86 Z400.0 E390.12:390.12. ; Set steps per mm
                                            M566 X2000.00 Y2000.00 Z50.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
                                            M203 X6000.00 Y6000.00 Z100.00 E200.00:200.00 ; Set maximum speeds (mm/min)
                                            M201 X500.00 Y500.00 Z60.00 E100.00:100.00 ; Set accelerations (mm/s^2)
                                            M208 X-130 Y-110 Z0 S1 ; Set axis minima
                                            M208 X130 Y110 Z300 S0 ; Set axis maxima
                                            G31 P25 X0 Y0 Z0.5000 ; Set Z probe trigger value, offset and trigger height
