    PEI coated flex-plate system
    3D Printing General Chat
    13
    50
    3656
    • klcjr89
      klcjr89 last edited by
      I'm not sure if this is allowed here, but I wanted to post a link to my Kickstarter that I just launched for my PEI coated flex-plate system for all 3D printers.
      I have been working on this for over a year now and just wanted to share it with the world finally.
      Here is the link: https://www.kickstarter.com/projects/1536120962/pei-coated-flex-plate-system-for-3d-printers
      Thank you โ˜บ
      keyz182 1 Reply Last reply Reply Quote 0
      • keyz182
        keyz182 @klcjr89 last edited by
        @klcjr89 You say 310mm diagonal max, just to confirm, that excludes the tabs at the front right? My bed is exactly 310x310mm.
        klcjr89 1 Reply Last reply Reply Quote 0
        • klcjr89
          klcjr89 @keyz182 last edited by
          @keyz182 Do you mean diameter? I'm not sure what you mean by diagonal, but yes, it excludes the tab sizes. So, the sheet would be about 310x310mm printing area and the tabs are about 20mm in length.
          Thank you!
          • gregspruce
            gregspruce last edited by
            I backed it - I'm using the IR sensor with my current PEI stuck to a buildtak flex plate and the transparency is a pain to deal with. I like the texture and opacity of this plate.
            • klcjr89
              klcjr89 @gregspruce last edited by
              @gregspruce Greg, I sincerely appreciate it. I messaged you in my Kickstarter dashboard.
              I am not sure how to deal with the problem of people wanting to order just the sheet if they already have a magnet system, so I made a FAQ on the Kickstarter.
              The problem is, if I sold 500 coated sheets without the magnet and 100 with the magnet, I wouldn't meet the minimum order quantity from my supplier to order the magnet material.
              gregspruce 1 Reply Last reply Reply Quote 0
              • gregspruce
                gregspruce @klcjr89 last edited by
                @klcjr89 I'm sure I can find a creative use for an extra magnet.
                Or just use it as an excuse to pull together all of my other spare parts and build yet another printer. ๐Ÿ˜„
                • klcjr89
                  @gregspruce
                  Thatโ€™s very true. It could be used for lots of things due to the high temp rating and adhesive backing! โ˜บ
                  • gavatron3000
                    gavatron3000 last edited by
                    Ill back it also, I've got a custom size one from thekiinnng in Canada as I've set magnets in my cast aluminium bed. Works great but the issue I've faced already with the textured sheet was the pores went through to the steel sheet in some places and began to rust underneath the pei resulting in it lifting off within 2 months .
                    I hope you can achieve a reliable quality
                    • klcjr89
                      klcjr89 @gavatron3000 last edited by
                      @gavatron3000
                      Thank you for being a backer. I noticed with the amazon sheets and Prusas is that the texture is pretty coarse; maybe that is part of the issue. I've had people using them since July without issue.
                      • gavatron3000
                        Is it possible to specify no magnets?
                        • klcjr89
                          @gavatron3000 said in PEI coated flex-plate system:
                          Technically, yes, but if you don't need the magnet couldn't you use it for something else? Otherwise you would be paying for something you're not receiving.
                          • gavatron3000
                            Yep fair enough, I'm sure I could find something to use it on
                            • timcurtis67
                              timcurtis67 last edited by
                              Is 310mm the limit in size?
                              I'm looking for one around 460mm square, 450mm minimum.
                              • klcjr89
                                klcjr89 @timcurtis67 last edited by klcjr89
                                @timcurtis67 said in PEI coated flex-plate system:
                                The size limit is stated on the Kickstarter. We also have a FAQ section over there as to the current limitations. The future is bright however for making any size if the Kickstarter is successfully funded.
                                Thank you!
                                • klcjr89
                                  We have just published an update to the Kickstarter. We are now offering flex-plates without the magnet based off of feedback.
                                  • gavatron3000
                                    I shared your Kickstarter with 3d printing Australia group also. A few people interested there
                                    • klcjr89
                                      You have no idea how much that means to me. I am very humbled โ˜บ
                                      Thank you!
                                      Dougal1957 1 Reply Last reply Reply Quote 0
                                      • Dougal1957
                                        Dougal1957 @klcjr89 last edited by
                                        @klcjr89 I have also shared it on the 3D-Printers Discord server
                                        3Dprinting
                                        • klcjr89
                                          klcjr89 @Dougal1957 last edited by
                                          @dougal1957 Doug, thank you for that!
                                          Are you still enjoying your Nimble?
                                          • Dougal1957
                                            Dougal1957 @klcjr89 last edited by Dougal1957
                                            @klcjr89 Oh yes best upgrade I ever made in fact I have a sidewinder waiting for me to finish my CoreXY Build.
                                            Any chance you could do your bed plates any larger my delta is 370 diamater and my CoreXY will be 450x450
                                            • klcjr89
                                              @dougal1957 said in PEI coated flex-plate system:
                                              Doug, we can make any size in the future if the campaign is funded. To make sizes greater than 310mm requires the purchase of 10 tons of steel in larger widths, as that is the minimum order quantity unfortunately.
                                              • Dougal1957
                                                @klcjr89 Yeah I can see why that would be prohibitive. Have seen your comments on the discord as well (I'm lil doug on there)
                                                • klcjr89
                                                  Update: we are now offering double sided coated options to satisfy as many people as possible. ๐Ÿ™‚
                                                  • klcjr89
                                                    klcjr89 last edited by klcjr89
                                                    Update: we are now offering sizes up to 350mm and have lowered the costs of rewards! We have streamlined the reward tiers to make it less cluttered. You can also buy just a flex-plate now, whereas before we required the purchase of two at a time. โ˜บ
                                                    Martin1454 1 Reply Last reply Reply Quote 1
                                                    • Martin1454
                                                      Martin1454 @klcjr89 last edited by Martin1454
                                                      @klcjr89 hope it will succeed ๐Ÿ™‚
                                                      Also - Can you share an image of how the underside of a print looks when it is printed on the surface? ๐Ÿ™‚
                                                      klcjr89 2 Replies Last reply Reply Quote 0
