Motors will not spin on Z and E
We are using two different kinds of motors, but for the Z and E we are using we are using Nema 23 bipolar 2.8 amps (JK57HS56-2804) with gear boxes for extra power. On the X and Y we are using iHSS57-36-10 closed loop.
On other models of our printers we use iHSS57-36-10 for all motors which is working fine coming off of the expansion connector pins. They work Fine.
We are now trying to use the main drives. (Drive 2 and Drive 3).
Motors don't spin please help.
Here is our config file:
;7 2/27/2019 3D Potter
M111 S0 ; Debug off
M550 Potterbot 7 ; Machine name and Netbios name (can be anything you like)
M551 Preprap ; Machine password (used for FTP);*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
;networking
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
M552 S1 ; start wifi S2 OR S1 networkM555 P2 ; Set output to look like Marlin
G21 ; Work in mm
M83 ; ...but relative extruder movesM584 X5 Y6 Z7 E9 ; Set drive mapping Axis and motor configuration
M569 P5 S1 R0 T4 ; Drive 0 goes forwards X
M569 P6 S1 R0 T4 ; Drive 1 goes forwards Y
M569 P2 S0 R0 T4 D2 ; Drive 2 goes forwards Z
M569 P3 S0 R0 T4 D2 ; Drive 6 goes forwards EM574 X1 Y2 Z2 S0 ; Endstop configuration
M208 X420 Y370 Z550 ; set axis maxima and high homing switch positions (adjust to suit your machine)
M208 X0 Y0 Z0 S1 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
M92 X72.70 Y72.70 ; Set axis steps per unitX72.70 Y70.85
M350 X16 Y16 Z16 E16 I1 ; Set 1x microstepping with interpolation
M92 Z6359.75 E150 ; Steps/mm for Z and E WAS 8
M906 X0 Y0 Z2000 E2000 I30 ; Set motor currents (mA) and increase idle current to 60%
M201 X5000 Y5000 Z2000 E3000 ; Accelerations (mm/s^2)
M203 X5000 Y5000 Z8000 E5000 ; Maximum speeds (mm/min)
M566 X5000 Y5000 Z800 E5000 ; Maximum instant speed changes mm/minuteM581 Z1 S1 C1 ;Configure external trigger
; Tool definitions
M563 P0 D0 ;enable cold extrusion.M563 P0 D0 H1
;G10 P0 X0 Y0 Z0 ;Set tool 0 axis offsets
G10 P1 ;Set initial tool 0 active and standby temperatures to 0C G10 P0 R00 S00
T0
M302 P1 ; cold extruder
M140H-1 ; BED OFF;*** If you are using axis compensation, put the figures in the following command
;M556 S78 X0 Y0 Z0 ; Axis compensation here; Misc
M83
M302 P1; Heaters
;M143 H1 S260 ; Maximum heater temperature
;M140 H-1 ; No bed heater
;M305 P1 T100000 B4138 C0 R4700 ; Thermistor parameters for heater 1
;M307 H1 A577.0 C199.0 D9.8 S1.00 B0
Our heaters are turned off as we 3D print clay, there is no heater.
@3dpotter said in Motors will not spin on Z and E:
M569 P3 S0 R0 T4 D2 ; Drive 6 goes forwards EHo do you have the motors connected? the M584 command has them connected to Drive 7 (Z) and Drive 9 (E) so on the expansion header or Duex5. The M569 command imples you have them connected to Drive 2 and Drive 3...
That was it. Thank you.
Staring me right in the face.
