    Firmware wishlist and priorities for Duet WiFi and Duet Ethernet
    Firmware wishlist
    113
    236
    53.0k
      Many of the items in the original firmware priorities list have now been implemented. So i think it's time to revise the list. Here is a list of possible new features, in no particular order. Please use your reply to this thread to vote for up to 5 of them, putting the most important features first
      1. Reworked WiFi server code, including configuration using files on the SD card, automatic retry if the connection is lost, live reporting of signal strength and status, more reliable support of multiple concurrent connections, and optional FTP and Telnet support.
      2. Better network security, including SSL if it can be made to work fast enough. Requires most of #1 in this list as a prerequisite.
      3. Logging of various events, including print start/pause/resume/cancel/end, and error messages.
      4. Independent homing switches for multiple Z motors.
      5. True bed levelling using 2, 3 or possibly 4 independently-driven Z motors and a Z probe.
      6. Live monitoring of TMC2660 driver status and reporting of problems (e.g. overheat warning).
      7. Dynamically-varying microstepping. This will allow you to configure 256x microstepping most cases, because the microstepping will be reduced automatically during high-speed moves.
      8. Standstill current reduction, which will allow higher motor currents to be used when the motors are moving.
      9. Auto-park of motors when power is lost. This will help prevent motors getting out of sync when multiple motors are used to drive a single axis.
      10. Axis hysteresis compensation.
      11. Better support for laser cutters.
      12. Better support for CNC machines.
      13. Automatic advance of changes in the colour mix when using a mixing hot end. See deckingman's blog.
      14. Support for powering off during a print, then resuming it when the printer is powered up again.
      15. Support for PanelOne 20x4 text displays, or possibly 12864 mono graphics displays.
      16. Feed-forward temperature control to predict the effect of turning the print cooling fan on or increasing the extrusion rate, and therefore reduce the temperature fluctuation.
      17. Filament and printing time odometers.
      18. Ability to update PanelDue firmware via the web interface.
      [Added the following at 15:36]
      19. Ability to wait for cool down before turning off ATX power.
      20. Ability to control an electronics cooling fan thermostatically based on CPU temperature and driver overheat warning.
      Anything else? I know a few other suggestions have been made, but I can't remember them all, so please feel free to repeat suggestions you have already made.
      audryhomeundefined 1 Reply Last reply Reply Quote 0
      • elmoretundefined
        elmoret
        • jmg123undefined
          jmg123
          14
          15
          I have one of my Duets wired up to a CNC machine at the moment, though it requires a lot of messing about to from Fusion 360 to actually milling something with the Duet. I can help test stuff out though.
          My other suggestion would be support for MQTT, to allow the duet to signal other things with it's status, e.g. current temperature, finished printing etc. With this it would be possible to do stuff like turn off plugs, turn on lights or send text messages when a print had finished.
          • InSanityundefined
            InSanity
            Let's not forget auto power off of ATX supply after cool down of hot end option. Priorities really are going to vary widely from user to user. #7 for example wouldn't gain me a thing, someone using a delta on the other hand might love it.
            19, 3 ,6, 15, 20, 11, 12, 1
            Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
            • appjawsundefined
              appjaws
              On a coreXY printer it is very important that the 2 belt tensions are the same. I was wondering if this can be indicated somehow by comparing the power needed to move each of the XY motors and either then relying on the user to mechanically adjust the tension or better still compensate automatically by adjusting the power of the motors, of course this would only be effective if the tensions of the 2 belts were very close in the first place.
              appjaws - Core XYUV Duet Ethernet Duex5
              firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
              Ormerod 1-converted to laser engraver, Duet wifi
              OpenSCAD version 2024.03.18
              Simplify3D 5.1.2
                @(In)Sanity:
                I've just added that as #19. I also added #20 which I had forgotten about.
                  @appjaws:
                  Unless one of the belts is over-tight or extremely loose, I don't think it would be possible to use the stall detection to compare the belt tensions.
                  Can you devise a test print that would show up any asymmetry in the movement?
                  • yngndrwundefined
                    yngndrw
                    In no particular order:
                    6. Live monitoring of TMC2660 driver - Including live position updates as they move, rather than just at the end of the move
                    12. Better support for CNC machines - I've not tried the Duet with my CNC machine, but from what I've seen there's nothing to handle spindles. It would also be nice to have a little hardware module to convert the PWM output to a 0-10V output for the spindle speed
                    • Dougal1957undefined
                      Dougal1957
                      David
                      1, 2, 6, 7, 12 is my vote?
                      • Simspeedundefined
                        Simspeed
                        5, 4, 9, 7, 13 My four new Z motors arrived so I'll soon be ready to implement #5.
                        Custom C-Beam H-Bot - Hard mount 560mm x 800mm MIC 6 bed plate - 3mm PEI print surface- 120v mains silicone bed heater (3 zones) - 800mm Z axis - polycarbonate enclosure - (4) .09° Nema 23s (Z) - .09° Nema 17s (XY) - Bondtech extruders - E3D Cyclops hotend, 24V power supply
                        • deckingmanundefined
                          deckingman
                          My personal preference would be 1, 13, 16, 17, 20.
                          • 3dprinting meatheadundefined
                            3dprinting meathead
                            would that square up the x axis to the bed? like for an i3, probe z at left and right, and then move each z motor independently to make the x axis parallel to the points probed?
                            If this question is too off topic, just disregard.
                            If I can learn it, than anyone can learn it.
                            • roboduetundefined
                              roboduet
                              1. WiFi server, specially FTP support. I'm missing it after moving from Duet 0.6
                              3. Logging.
                              7. Dynamic microstepping to switch from x16 interpolated mode.
                              15. Support for 12864 displays.
                              16. Better temperature control
                              XX. Automatic firmware update from web interface (download firmware directly from internet, check md5 or sha hash and update if hashsum is ok). Plus check for updates button in DWC.
                              • tomasfundefined
                                tomasf
                                19
                                20
                                16
                                  3dprinting meathead
                                  14
                                  8
                                  • hairy_kiwiundefined
                                    hairy_kiwi
                                    3. Logging… of Temperature values also?
                                    15. Support for PanelOne 20x4 text displays, or possibly 12864 mono graphics displays. Especially if useful/required for controlling a machine away from its usual WiFi network?
                                    5. True bed levelling... The 2 z-motor solution would be sufficient for my current setup.
                                    1. Reworked WiFi server code... Not sure I understand the limitations of the current code base well enough, but anyway.
                                    • Huguesundefined
                                      Hugues
                                      …And a filament monitor support based from rotary encoder
                                      • caphectorundefined
                                        caphector
                                        I'd love to see support for the Prometheus-style multi-filament hot ends as well. Both Prometheus and Prusa have made them. They retract filament when it's not in use and then advance the alternate filament. I think the only big change would be to filament movement distances.
                                        • demonio669undefined
                                          demonio669
                                          • Allow M117 to send message via email
                                          • start and stop printing macros (o allow to send email when the print begins and ends)
                                          • tomwang256undefined
                                            tomwang256
                                            18 - i accidently broke off my usb connector on the paneldue 😞
