    BlTouch installed fine, but fails mid mesh
    575
    • DocCox
      DocCox last edited by DocCox
      I received my Duet from filastruder the other day - everything but the BLTouch and AC heated beds working correctly
      Firmware is 2.02, most recent version of the blTouch, I've followed all the setup guides and the probe correctly homes and responds/reports. When I start my mesh level the probe travels and responds normally until about the 7th location where it fails to re-deploy and crashes into the bed. Any idea what's going on here? I've replaced the probe and wiring with a 2nd one I have around - same results at the same place.
      I have increased the dive height to 35, slowed the probe process way down to 60, etc
      • DocCox
        Here is a short video mid mesh level where it fails
        BlTouch Failure
          Can you post your config file?
          Firmware 1.21 is really old at this point. Time to start thinking about updating to 2.02.
          DocCox 1 Reply Last reply Reply Quote 0
          • DocCox
            DocCox @Phaedrux last edited by DocCox
            @phaedrux Sorry, trying to do 10 things at once earlier tangled in wires. Firmware is 2.02, I will update the original post if I can
            From Settings -> General
            WiFi Server Version: 1.21
            Web Interface Version: 1.22.6
            From Settings -> Machine Properties
            Z-Probe
            Type:Unknown (9)
            Trigger Height:1.5 mm
            Trigger Value: 50
            Current Value: 0
            From config.g
            NETWORK SECTION REMOVED
            M92 X80.00 Y80.00 Z800.00 E408.80 ; Set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
            M906 X800.00 Y800.00 Z800.00 E800.00 I70 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X400 Y400 Z500 S0 ; Set axis maxima
            M574 X1 Y1 S0 ; Set active low and disabled endstops
            M558 P9 X0 Y0 Z1 H10 F100 R0.2 T6000 A5 B1 ; Set Z Probe to type Switch or Digital output where Z probe connector is used. Used for z only
            G31 P50 X35 Y-7 Z1.50 ; Set Z probe trigger value, offset and trigger height z was .82
            M307 H7 A-1 C-1 D-1 ; Disable heater 7 on PWM channel for BLTouch
            M557 X20:380 Y20:380 S20 ; Define mesh grid
            M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
            M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P0 S1 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 S"Nozzle" D0 H1 ; Define tool 0
            ; Automatic power saving
            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
            From homeall.g
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v2 on Fri Mar 01 2019 12:49:15 GMT-0700 (Mountain Standard Time)
            G91 ; relative positioning
            M98 Pdeployprobe.g ; deploy mechanical Z probe
            G1 S1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000 ; go back a few mm
            G1 S1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G90 ; absolute positioning
            G1 X-15 Y27 F6000 ; go to first bed probe point and home Z
            ;G91 ; relative positioning
            ;G1 S2 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
            M98 Pretractprobe.g ; retract mechanical Z probe
            from homez.g
            ; homez.g
            ; called to home the Z axis
            G1 X-15 Y27 F6000 ; go to first probe point
            From deployprobe.g
            ; deployprobe.g
            ; called to deploy a physical Z probe
            ; generated by RepRapFirmware Configuration Tool v2 on Fri Mar 01 2019 12:49:14 GMT-0700 (Mountain Standard Time)
            M280 P7 S10 I1
            From retractprobe.g
            ; retractprobe.g
            ; called to retract a physical Z probe
            M280 P7 S90 I1
            From bed.g
            ; bed.g
            G29 ; probe the bed and enable compensation
              The pin in your probe looks bent. Maybe it's just the angle of the video, but it doesn't seem straight.
                Send the BLTouch command to put it into test mode where it continuously deploys and retracts the probe. See if it can keep doing it for a while. I'm betting that eventually it gets stuck.
                • DocCox
                  @phaedrux how do I put it in a continuous test mode?
                  This one is bent, the other one is brand new. They're both genuine per the key on them and both having the issues 😞
                    M280 P7 S120 I1
                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                      https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                      • DocCox
                        @phaedrux you're a great help, I really appreciate it.
                        The probe ran without issue for 10 minutes before I called it. I decided to try again while moving the x axis back and forth and at almost the exact same point it failed to probe. The little blue light dimmed slightly.
                        I swapped in the true probe, and repeated the test and it happened again, almost the exact same spot.
                        With your help I'm convinced it has to be wiring related. Tomorrow it's going to get a new wiring harness that's 2 meters without any extensions
