    Replaced hot end and now get vssa fault
    2.4k
    • chriskimbrundefined
      chriskimbr
      I Bought this hot end...
      Long Distance 0.4mm 3D Printer Extruder - Silver 0.4MM
      https://us.gearbest.com/3d-printer-parts/pp_613785.html?wid=1433363
      Replaced hot end and now get vssa fault check thermistor wiring error.
      What do I do?
      Duet2wifi latest firmware.
      Fuse on board looks fine
      • Vetiundefined
        Veti
        check the resistance of the thermistor with a multimeter
        chriskimbrundefined 1 Reply Last reply Reply Quote 0
          chriskimbr @Veti
          @veti how?
          • Vetiundefined
            Veti
            set your multimeter to ohm and put one probe of the multimeter in each of connector plugs of the thermistor
            • Vetiundefined
              Veti
              just making sure the thermistors is normally in the heater block?
                chriskimbr @Veti
                @veti the thermistor is in block when i power on yes.
                I assume i check ohms on thermistor with it out?
                Do i choose auto, kohms or Mohms?
                With thermistor out and multimeter on ohms auto i read 106.1
                With multimeter at Mohms i read 0.104
                  chriskimbr @chriskimbr
                  @chriskimbr Is this a good reading or a bad reading?
                  I don't know much about electronics. Please advise.
                  • Vetiundefined
                    Veti
                    @chriskimbr said in Replaced hot end and now get vssa fault:
                    100k is about right for the thermistor
                    what is the temperature reading when you turn on your duet?
                    chriskimbrundefined 2 Replies Last reply Reply Quote 0
                      chriskimbr @Veti
                        chriskimbr
                          chriskimbr @Veti
                          @veti see pics
                          bed is 24 degrees but hot end is 2000.C which is fault.
                          • Vetiundefined
                            Veti
                            do replace the connector with a proper molex plug.
                            check that there is no connection between the thermistor and the heater block/heater element.
                              chriskimbr
                              @veti Are you saying replace the connector to the thermister e-temp 0 ?
                              What is a correct Molex connector for it?
                                chriskimbr
                                I replaced the stock Tronxy X5SA hot end with the v6 clone above.
                                Ohm reading for new thermistor is 106.
                                Would these settings above need to change for the next thermistor / hot end?
                                Would this be causing the VSSA fault reading 2000.0C ?
                                config.g file section for
                                M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                                ;M305 P1 R4700 T100000 B4388 ; set E0 thermistor parameters
                                • Vetiundefined
                                  Veti
                                  the correct connector came with the duet. its the 2 pin one.
                                  where did you get those values from?
                                  no the cause for that is faulty wiring or a blown vssa fuse.
                                    chriskimbr
                                    @veti
                                    Is this the correct connector?
                                    Regarding my setting...
                                    Got the settings from someone else with same printer.
                                    What needs to be changed?
                                    • Vetiundefined
                                      Veti
                                      but you switched the thermistor. you need the settings that fit your thermistor.
                                      you can calculate the values from the thermistor table that you hopefully got with the hotend.
                                        chriskimbr @Veti
                                        @veti The hot end with thermistor came with no documentation.
                                        • Vetiundefined
                                          Veti
                                          then you prob need to either
                                          • measure the resistance at 50 and 240 degrees using a calibrated temperature sensor.
                                          • buy a thermistor with documentation
                                          • live with inaccuracies that could range around 40 degrees
                                            chriskimbr @Veti
                                            @veti Im going to get a cheap hot end and thermistor from local store to test and see if im having same problem.
                                            from what your telling me , i need to look at thermisor table and set the 'C' value ?
