    Panel duet not working
    PanelDue
    paneldue duet wifi
    • Pradeepkumar
      Pradeepkumar last edited by Pradeepkumar
      I have connected the 7 inch panel to the duet 2 wifi board. It was working for few seconds later,it shows as connecting and when I switch off and turned it on it went blank alt text. Also the duet wifi (the latest version) I unable to see in the wifi signal from the board as well 😥.
      • A Former User
        A Former User last edited by
        Only thing I can add is that it seems that connecting means PanelDue isn't getting the expected response from the Duet Wifi; had the same thing happen due to the SD card not being recognized
        Same issue as this: https://forum.duet3d.com/topic/2646/cannot-initialise-sd-card-0-card-is-unusable/6
        With a functional SD card everything worked. Might I suggest connecting to USB and looking at the serial output from the Duet Wifi?
        • Pradeepkumar
          Thanks for your comment. I tired connecting it to usb with duet wifi 2 i am able to connect it to the network. But still the panel is not working.
          • Pradeepkumar
            I have updated the firmware in the panel it is working now, but i installed the PanelDue-5.0i-7.0i.bin. Is this the right version to use it along with duet 2 wifi (latest version). Seems like the setting are not the same.
            • aidar
              aidar last edited by
              Look at https://github.com/dc42/PanelDueFirmware/releases . It starts with "Choosing the correct firmware binary" .
