    IR Trigger height suddenly changed a lot
    IR Height Sensor
    934
    • JKaechler
      JKaechler last edited by
      I had a print running overnight, and it went to the noodle fail. After that event the trigger height of my ir probe went from Z1.66 to Z4.85.
      I see no physical damage to the probe, and while the plastic coating on the capacitor in between the IR bulbs and the IR sensor did get torn at one point, that happened months ago and has had no effect on performance.
      The probe triggers at values over 500, which is expected. Its like nothing is wrong, except that the trigger point suddenly moved. Any ideas?
        Phaedrux Moderator @JKaechler last edited by
        What was the cause of the noodle fail? Did the print head come into contact with the print and maybe jostle it loose?
        • JKaechler
          I have been looking for exactly that. I cant find anything wrong. The print had a layer shift, i could see a blob that hung up the nozzle enough that it was then airprinting the supports and it was all spagetti time after that. But that did not seem to make the nozzle, hotend, mount, or sensor loose. At the moment i have recalibrated to this new larger offset and I am going to see if a print works fine with it in this state. But it sure seems wacky.
          • JKaechler
            Here we are printing with a recalibrated z offset of Z4.956
            This is the same part, after i resliced it and double checked all my settings. Hopefully it works. Its a 9 hour print.
              Have any of the IR components at the bottom edge of the sensor board become contaminated with filament?
              JKaechler Billsrf 2 Replies Last reply Reply Quote 0
              • JKaechler
                JKaechler @dc42 last edited by
                i never thought of that. what is a safe way to clean them? I dont think there is actually plastic stuck on there, but there was contact between the sensor and some heated up molten plastic. I could see how some kind of contamination would cause a difference in refraction on either emitter or receiver and make it trigger at wrong height
                  You can clean them using a cotton bud moistened in isopropyl alcohol.
                  • Billsrf
                    Billsrf @dc42 last edited by
                    @dc42 I have encountered a problem much like this. My machine has been flaw less for the last 1000 hrs of print time. I went to start another print this morning and the IR sensor triggers at 20mm above where it is supposed to be. I tried the recalibrate and i get nothing but error messages. I am stumped, I did not do any updates or change any settings.0_1553533624827_Current set up.JPG 0_1553533638033_Probe set.JPG 0_1553533692452_g code error.JPG 0_1553533768486_config 3-25-19.g
                    www.dpp3d.com , pellet fed large format 3d printers
                      Phaedrux Moderator @Billsrf last edited by
                      @billsrf Have you tried cleaning the sensor as DC42 suggests above?
                      Billsrf 1 Reply Last reply Reply Quote 0
                      • Billsrf
                        Billsrf @Phaedrux last edited by
                        @phaedrux yes, i even change the sensor and getting the same results. No matter where it is at, it moves 10 mm down towards the build surface and stops.
                        • JKaechler
                          For what its worth, I also cleaned the sensor and got essentially no change. After further testing I have also found that the sensor is making increasingly large errors as well. Basically i have to watch the first bit of the first layer and baby step it a bit to get it right each time.
                          • Billsrf
                            Billsrf @JKaechler last edited by
                            @dc42 , @jkaechler yes exactly! now when i run HOME.ALL, it moves to the center, dives 10mm , the sensor triggers at 200 mm from the build surface. This is crazy. it has been perfect for 1000= hours now i cant figure it out. reloaded firmware and config.g same thing again.2_1553547133616_homeall.g 1_1553547133616_config 3-25-19.g 0_1553547133615_homez.g
                              Is your IR sensor the older sort with through-hole phototransistor and IR diodes, or the new sort with surface mount ones? If it's the older sort, then you have probably had a collision and one of those components has been bent into a different position. If it's the newer sort, then perhaps it has developed a fault.
