    Can I use relative pos by +/-?
    • pro3d
      pro3d last edited by
      If I in start code want some relative movement (XYZE)
      • Can I write G1 XYZE+(randomnumber) rather than doing G91 and G90 in every other line?
      so:
      G1 XYZE random lines....
      Then
      G1 E+5 to extrude 5 more mm
      instead of
      G91
      G1 E5
      G90
      V-King 3D Printer - All Wheels and Belts Running Smooth on the Rails!
      R&D - Developer/Engineering Designer - V-King 3D Printers
      https://vkingprinter.com/
      • deckingman
        deckingman @pro3d last edited by deckingman
        @pro3d G91 will set relative positioning and all G1 commands after that will be executed as relative moves until a G90 command changes the positioning to absolute. Thereafter, all G1 moves will be executed as absolute positioning until a G91 command changes it back to relative. Be aware that to switch the extruder between relative and absolute, you need to use M83 and M82. Does that answer your question?
        pro3d 1 Reply Last reply Reply Quote 0
        • pro3d
          pro3d @deckingman last edited by
          @deckingman
          My badly stated question was if I could just use [XYZE]+[nr] instead of switching back and forth between relative and absolute just by using the +/- sign in the command line
          deckingman dc42 2 Replies Last reply Reply Quote 0
          • deckingman
            @pro3d Ahh, I see. AFAIK that's not possible.
              dc42 administrators @pro3d last edited by
              @pro3d said in Can I use relative pos by +/-?:
              @deckingman
              No you can't. Commands such as G1 X-10 already have a defined meaning, i.e. move to X coordinate -10. Similarly, G1 X+10 means the same as G1 X10.
