    Attempt to move motors when VIN is not in range DWC shows 0.5V
    vin not in range
    8
    50
    2849
    • Magnusjen
      Magnusjen last edited by Magnusjen
      Board is still showing 0.5 V in DWC so motors still refuse to move.... I have made a short sum of what is checked and tested as the latest comment.
      Hi guys,
      I got my Duet 2 Wifi yesterday and started setting it up, got past the wifi setup and all this worked fine.
      I then had some issues with my end stops but found the help here, I had wired it wrong. But my motors were running fine.
      Today after work and other stuff, I wanted to finalise the setup. So I homed the motors again just to reafirm that it was working. After this I wanted to fix the issues I have had with the fans, I have been using the always on plugs to test the fan connection. There is one of my fans I just cannot get to work but it should work okay still.
      So, I start up the printer and it says that it is not homed.. Odd, but when I press "homex" it says "Attempt to move motors when VIN is not in range" and it says this for whichever motor I try to talk with.
      Furthermore, now in the upper left hand corner the printer says "off"
      Did I kill my printer with a wrong wiring of fans?
      Br/
      Magnus
        What is the reported VIN in the DWC?
        What do you see if you run M122?
        Are you VIN terminals tightly screwed down?
        What LEDs are lit on the edge of the board?
        • Magnusjen
          Unsure what DWC is in the context?
          The VIN terminals er screwed down tight
          I see green (3,3V) , red (5V) and blue ...
          I have switched it now to USB to interact via USB instead
          M122 reads as:
          6:52:18 AMM122
          Error: G0/G1: insufficient axes homed
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
          Board ID: 08DGM-917DA-G4MSD-6J1F8-3SD6T-KSU7B
          Used output buffers: 3 of 20 (7 max)
          Static ram: 25524
          Dynamic ram: 98568 of which 0 recycled
          Exception stack ram used: 360
          Never used ram: 6620
          Tasks: NETWORK(ready,648) HEAT(blocked,1232) MAIN(running,3868) IDLE(ready,200)
          Owned mutexes:
          Last reset 00:01:13 ago, cause: power up
          Last software reset at 2019-03-12 22:17, reason: Unknown, spinning module Platform, available RAM 6320 bytes (slot 2)
          Software reset code 0x40b0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0042380f BFAR 0xe000ed38 SP 0x20001eac Task 0x5754454e
          Stack: 004450eb 004450ea 41000000 f8000000 4016afff 00000000 00000000 3e178897 3e1cd04f 41880000 3e3a3335 3e638e3a 423d19d1 00000000 476e5600 37d33333 3c113333 60000000 3fe22666 60000010 00449abb 00000001 0040607f
          Error status: 0
          Free file entries: 10
          MCU temperature: min 29.8, current 41.3, max 41.5
          Supply voltage: min 0.4, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
          Driver 0: ok, SG min/max not available
          Driver 1: ok, SG min/max not available
          Driver 2: ok, SG min/max not available
          Driver 3: ok, SG min/max not available
          Driver 4: ok, SG min/max not available
          Date/time: 2019-03-13 06:52:17
          Cache data hit count 177085076
          Slowest loop: 4.89ms; fastest: 0.06ms
          I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
          Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 239, MaxWait: 62618ms, Underruns: 0, 0
          Scheduled moves: 2, completed moves: 2
          Bed compensation in use: none
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 14.03ms; fastest: 0.00ms
          Responder states: HTTP(4) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is running
            WiFi firmware version 1.21
            WiFi MAC address cc:50:e3:0d:27:75
            WiFi Vcc 3.42, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 16280
            WiFi IP address 10.44.0.21
            WiFi signal strength -55dBm, reconnections 0, sleep mode modem
            Socket states: 0 2 0 0 0 0 0 0
            DWC in this context is the Duet Web Control. The web interface you connect to. The machine status box shows the current VIN.
            The M122 results will be more informative if you gather it right after the problem has occured.
            Magnusjen 2 Replies Last reply Reply Quote 0
            • Veti
              Veti last edited by
              @magnusjen said in Attempt to move motors when VIN is not in range:
              you have no 12V or 24V. so when you try to move the motors they wont move.
              • Magnusjen
                Magnusjen @Phaedrux last edited by
                @phaedrux ah! Right will look after work when i get WiFi connection again.
                • Magnusjen
                  @veti the data is useless... I pulled it while it was connected with USB. I will pull better data in about 8 hours.
                  • Magnusjen
                    @phaedrux
                    So! I am home from work now, and I plugged in the DUET to my Ender 3 power supply which supplies 24 V (I just checked with my Multimeter and it confirms that part.
                    The DWC interface says I have 0.5V and the M122 prompt says the same.. For shits and giggles I looked at the fan pins and they also say 24V. I have had issues with my hot end fan not working when I plug it into the board so that is my next issue after getting the board to function again.
                    3:49:47 PMM122
                    Used output buffers: 3 of 20 (15 max)
                    Static ram: 25524
                    Exception stack ram used: 288
                    Never used ram: 6692
                    Owned mutexes: WiFi(NETWORK)
                    Last reset 00:01:22 ago, cause: power up
                    Error status: 0
                    MCU temperature: min 36.7, current 37.6, max 37.6
                    Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0, power good: no
                    Date/time: 2019-03-13 15:49:46
                    Cache data hit count 297248498
                    Slowest loop: 1.80ms; fastest: 0.06ms
                    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                    Segments left: 0
                    === Network ===
                    Slowest loop: 175.35ms; fastest: 0.08ms
                    • WiFi -
                      WiFi flash size 4194304, free heap 15056
                      WiFi signal strength -50dBm, reconnections 0, sleep mode modem
                    • Veti
                      Veti last edited by
                      check the fuses if it is blown
                      Magnusjen 1 Reply Last reply Reply Quote 0
                      • Magnusjen
                        Magnusjen @Veti last edited by
                        @veti I just checked the fuses with my multimeter, they all read 24 V
                        • Veti
                          Veti last edited by
                          you measure a fuse by measuring the resistance across it while its out of the socket.
                          • Magnusjen
                            Magnusjen @Veti last edited by Magnusjen
                            @veti Huh? But then there is no current to the fuse?
                            Edit: doh... ignore this
                            Danal 1 Reply Last reply Reply Quote 0
                            • Magnusjen
                              @veti Sorry mate, my bad... I took them out and checked them one by one and they are all fine.
                              • Danal
                                Danal @Magnusjen last edited by
                                Correct. Measure resistance, not voltage or current. Should be zero for a good fuse.
                                In fact, measuring 24V across a fuse that is IN CIRCUIT is a strong hint that the fuse is "blown". Meaning open. Meaning no current able to pass through. If you think about a good fuse IN CIRCUIT, it should read very, very, very close to zero V 'across' the fuse, because a good fuse is not 'blocking' anything, i.e. not blown. So the 'voltage drop' across the fuse is (almost) nothing.
                                • Danal
                                  Danal @Magnusjen last edited by Danal
                                  "Good" as in "Zero Ohms"? (When out of circuit)
                                  • Magnusjen
                                    Magnusjen @Danal last edited by
                                    @danal Was to slow, I took them out and looked at resistance across and they all hit zero
                                    • Danal
                                      Perfect... then they are OK.
                                      Hmmm.... DWC still shows just 5V?
                                      • Magnusjen
                                        @danal Yes still shows 5V, I even pulled out the fans just for ease of work with the board.
                                        • Danal
                                          With USB UNPLUGGED, and 24V reading across the pins on the green connector that is circled, which lights are on?
                                          • Magnusjen
                                            @danal
                                            Power in is in the correct spot Check
                                            Power reading across reads as 24V check
                                            USB not plugged in Check
                                            Wifi Blue light check
                                            3.3V green light check
                                            5V red light check
                                            VIN blue light check
                                            Z,Y, X stop red lights check
                                            • Danal
                                              Interesting....
                                              Just as a final check of inputs and fuses, take a VOLTAGE reading across the two red circles (heater E0 VIN and ground on the big green VIN itself), with USB unplugged and 24V in on.
                                              Should read 24V. Probably will. Still, with that confirmation, we can move on.
                                              • Magnusjen
                                                @danal Reads 24V indeed mate 😕
                                                I really appreciates the help! It happend quite sudden, I had the motors working and homed and when I had been working on wiring the fans (with the board turned off) it started with that error.
                                                • Danal
                                                  Danal last edited by Danal
                                                  EDIT: My memory failed me. I've removed the illustration so as not to lead anyone astray.
                                                  The three pin connector nearest the big green VIN power in screw terminals should be blank.
                                                  Magnusjen 1 Reply Last reply Reply Quote 1
                                                  • Magnusjen
                                                    @danal jumper??? There never was a jumper there on my board.
                                                    • Danal
                                                      Yeah, just realized, I was thinking of a different jumper. They are correct the way you describe, empty.
