    Larger Terminals For Heaters
    Hardware wishlist
    • yngndrw
      yngndrw last edited by
      The standard ones come with the little white ferrules (0.5mm2 I believe), but these are too small for the standard E3D heater cartridge (24V, marked as 25W but more like 40W) wires - The light blue ferrules (Next size up - 0.75mm2 I believe) fit the wires but are a very tight fit into the terminals. Also both sizes of ferrule need to be cut down be a couple of millimeters as the terminals are too short.
      If I wasn't using a proper crimper that did a square crimp, I doubt I'd even be able to force them into the terminals at all.
      • T3P3Tony
        Thanks for pointing this out, e3d must now use slightly thicker wires. We will look at getting short 0.75mm ferrules as those fit well into the 3.5mm terminals ( but the standard lenght ones do need to be cut down after crimping).
        www.duet3d.com
