No response from YAT after sending command
@phaedrux OK, thanks ...... phew I got there at last
I'll play about with it now and if I still can't achieve connection I'll set it up the way you suggested earlier.
Thanks pal ! you're a star .... and you too David !
@phaedrux Should the Gateway be set to 0 with M554 P0.0.0.0 as well ?
I think the gateway would still be your router IP
If you are using DHCP to get the IP address then it will automatically get the gateway address that way too.
@dc42 ok now I am puzzled. The config.g commenting says make the next two lines 0 for DHCP, which is the IP M552 and Gateway M554, so which is right. What should I enter in Gateway? I currently have 0.0.0.0 and it's connecting.
My response was just based on the notes from the gcode wiki for setting the gateway. Go with DC42s response. which I think means that regardless of what you specify for the gateway in config.g if your IP address is set to 0.0.0.0 to get a DHCP address, the gateway will also be set via DHCP, so you don't have to worry bout it.
Yep, se what you mean. OK, as I have it at 0 now I'll leave that and let the DHCP sort it out.
