    Duet Wifi unable to upload files
    1370
    • d33b
      d33b last edited by
      Been dealing with this problem for a long time, and trying to troubleshoot from other posts but I've given up and have no idea where else to go. I've done every single fix anyone has ever offhandedly mentioned.
      I am completely unable to upload anything to my Duet anymore. This problem has gradually grown from being non-existent at first, to slow upload speeds, to intermittently causing issues, to being completely unable to upload anything anymore. I've tried every firmware combination imaginable, and every web control version.
      Pretty sure my hardware is just broken, not sure what else I can possibly try.
      Here's my M122:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta3 running on Duet WiFi 1.02 or later
      Board ID: 08DDM-9FAM2-LW4SD-6JKFA-3S46P-K3XHW
      Used output buffers: 1 of 20 (8 max)
      Static ram: 25632
      Dynamic ram: 93836 of which 396 recycled
      Exception stack ram used: 268
      Never used ram: 10940
      Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3816) IDLE(ready,196)
      Owned mutexes:
      Last reset 00:06:10 ago, cause: power up
      Last software reset at 2019-03-28 14:41, reason: User, spinning module GCodes, available RAM 12752 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 8.7ms, max retries 0
      MCU temperature: min 39.5, current 39.7, max 43.0
      Supply voltage: min 13.3, current 13.4, max 13.5, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2019-03-29 11:50:07
      Cache data hit count 1340612078
      Slowest loop: 10.68ms; fastest: 0.07ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      Bed compensation in use: none
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
      Segments left: 0, aux move: no
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 42.06ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 5c:cf:7f:ee:61:e8
        WiFi Vcc 3.36, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 12896
        WiFi IP address 192.168.1.85
        WiFi signal strength -46dBm, reconnections 0, sleep mode modem
      and my M39
      SD card in slot 0: capacity 62.21Gb, free space 31.44Gb, speed 20.00MBytes/sec, cluster size 64kb
      I'm using a high quality, high class SD card currently. I've tried using tons of different SD cards of various sizes and speeds and nothing fixes this problem.
      • JamesM
        JamesM last edited by JamesM
        I believe the max acceptable size for an SD card on the Duet is 32gigs and it looks like you are using a 64 gig card so I believe a smaller size card may be needed.
        https://forum.duet3d.com/topic/9069/sd-card-size
        • d33b
          d33b last edited by d33b
          Its formatted to 32gb, there's no way the Duet could possibly care. I believe the reasoning behind 32gb max is because anything past that won't allow you to do FAT32 which I have done here.
          Also, I've tried that solution to no avail 😞
            What are the symptoms when you try to upload a file?
            • d33b
              d33b last edited by
              Steps to recreate my problem would be:
              1. Click upload&start
              2. Select file
              3. Dialog appears, shows some small amount of file instantly uploaded when using Google Chrome, then immediately freezes. If I use Edge, it never even upload the first chunk instantly.
              4. Timeout, upload gives up and throws error
              The strangest thing is that it seemingly randomly might let me upload a file every once in a while. Sometimes it even behaves for a while. Its been behaving pretty well after making this post, even though I changed nothing. I'm sure the problem will come back though.
              • bot
                bot last edited by
                Are there any potential sources of radio interference during the times the uploading doesn't work? Do you live in an apartment building? Is their wifi congestion in the area? Microwaves or 2.4Ghz wireless phones being used? Are there many people in your own house using the same wifi network?
                *not actually a robot
                d33b 1 Reply Last reply Reply Quote 0
                  Please test writing to the SD card by sending M122 P104. You can optionally add an S parameter to specify the file size in Mb, default 10.
                  Also please update your WiFi firmware (DuetWiFiServer) to 1.22 or 1.23. Your M122 report shows that you are running 1.21.
                  • d33b
                    d33b @bot last edited by d33b
                    @bot said in Duet Wifi unable to upload files:
                    No interference, and the ESP8266 is basically within 2 meters of the router. I even tried using a WiFi extender to basically make a network entirely dedicated to the print which did nothing.
                    @dc42 said in Duet Wifi unable to upload files:
                    I've tried every firmware you've mentioned here and none worked. I tried rolling back since the problem has only gotten worse over time. 1.22, 1.23, and 1.21 are all the same.
                    M122 Results: SD write speed for 10.0Mbyte file was 2.62Mbytes/sec
                      Please update DuetWiFiServer to 1.22 or 1.23, then confirm using M122 that the update succeeded:
                      WiFi -
                      There is a known issue in 1.21 that causes problems with a small number of routers.
                      • d33b
                        d33b @dc42 last edited by
                        WiFi -
                        Ok I have updated back to 1.23. The problem randomly stopped happening sometime last night as it normally does, maybe by some act of god it won't come back.
                          If/when the problem comes back, a WireShark trace of a failed upload may help diagnose the reason.
                          d33b ElmoC 2 Replies Last reply Reply Quote 0
                          • d33b
                            d33b @dc42 last edited by d33b
                            Good idea, I'll have to try that next time. Appreciate the help and have been in love with my Duet for almost 2 years now! Thank you
                            • ElmoC
                              ElmoC @dc42 last edited by
                              @dc42 This is almost a year old, but I am now having this issue. I cannot upload files to my Duet WiFi from PrusaSlicer any more, but was in the past. I have changed routers and seeing that 1.21 had issues with some routers, I'm thinking it may be similar. It also fails when using the Upload button in the web interface. It doesn't fail at the same location.
                              How do you do a WireShark trace?
                              Firmware Electronics: Duet WiFi 1.02 or later + DueX5
                              Firmware Version: 2.03 (2019-06-13b2)
                              WiFi Server Version: 1.23
                              Web Interface Version: 1.22.6
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
                              Board ID: 08DGM-917DA-G4MS8-6J1F2-3S06R-T9THB
                              Used output buffers: 3 of 24 (8 max)
                              Static ram: 25680
                              Dynamic ram: 94148 of which 416 recycled
                              Exception stack ram used: 320
                              Never used ram: 10508
                              Tasks: NETWORK(ready,524) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,3748) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:07:10 ago, cause: software
                              Last software reset at 2020-01-14 17:21, reason: User, spinning module GCodes, available RAM 10372 bytes (slot 0)
                              Error status: 0
                              SD card longest block write time: 6.0ms, max retries 0
                              MCU temperature: min 34.6, current 34.8, max 35.6
                              Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 5: standstill, SG min/max not available
                              Driver 6: standstill, SG min/max not available
                              Driver 7: standstill, SG min/max not available
                              Driver 8: standstill, SG min/max not available
                              Driver 9: standstill, SG min/max not available
                              Date/time: 2020-01-14 17:28:29
                              Cache data hit count 1688952282
                              Slowest loop: 8.35ms; fastest: 0.07ms
                              === DDARing ===
                              Heater 1 is on, I-accum = 0.0
                              Segments left: 0
                              === Network ===
                              Slowest loop: 81.74ms; fastest: 0.00ms
                              • WiFi -
                                WiFi firmware version 1.23
                                WiFi MAC address
                                WiFi flash size 4194304, free heap 20080
                                WiFi IP address 192.168.1.197
                                WiFi signal strength -67dBm, reconnections 0, sleep mode modem
