sd card size
758
  • undefined
    Monster Delta
    is there a maximum capacity for the micro SD? for instance could i dd a 128gb card or higher?
    undefined 1 Reply Last reply 18 Mar 2024, 17:14 Reply Quote 0
    • undefined
      UnderDoneSushi
      I switched to a 32gb sandisk which has worked well. It just has to be formatted correctly which is on the Duet Dozuki and is different than the included microSD card. I would save your money and not go for a 128gb card, its overkill. Especially if you use Google drive or Dropbox.
      • undefined
        Monster Delta
        I've got a few 128gb lying around or i'd have to swap one out from somewhere
        • undefined
          T3P3Tony administrators
          The SD card subsystem is SD 2.0 - that supports SDHC cards but not SDXC.
          That means the limit is 32 GB.
          www.duet3d.com
          • undefined
            Monster Delta
            ok great thanks
            • undefined
              DonStauffer @Monster Delta
              This post is deleted!
              • undefined
                DonStauffer @T3P3Tony
                @T3P3Tony I'd also like to know if there's a maximum SD card size for PanelDue.
                undefined 1 Reply Last reply 18 Mar 2024, 17:15 Reply Quote 0
                • undefined
                  jay_s_uk @DonStauffer
                  @DonStauffer the same as mainboards, so 32GB
                  undefined 1 Reply Last reply 18 Mar 2024, 17:33 Reply Quote 0
                  • undefined
                    dc42 administrators @jay_s_uk
                    For anyone interested, the issue is that FAT32 only supports up to 32Gb. Larger capacity SD cards use EXFAT format but that's subject to Microsoft patents.
