    Pressure Advance killing extruder motor
    25
    2.5k
      With such a high gearing ratio, you don't need much torque but you do need low inertia and high speed. So I suggest choosing a motor with low inductance, modest torque, and a high ratio of holding torque to rotor inertia. Run it close to its rated current (e.g. 85%).
      gnydickundefined garisundefined 2 Replies Last reply Reply Quote 0
      • Edgars Batnaundefined
        Edgars Batna @garis
        @garis said in Pressure Advance killing extruder motor:
        Perhaps I haven't used a sufficiently high magnifying glass to understand what defects I should be observing or tolerating. My printing experience is limited and just now I am reprinting a few parts to upgrade the originals I printed for my Hypercube now that it is working.
        You need to use a magnifying crystal ball, preferably with Christmas decorations within the ball.
        For the XY motors this is of concern but for the extruder I could imagine some/much of this resonance would be absorbed by the plastic, and perhaps some under extrusion if steps were missed. For a stepper with 2,600 steps that is likely to be of minor concern???
        At 40:1 there's basically no resistance whatsoever on the motor end to absorb anything, so there is just the rotor.
        • gnydickundefined
          gnydick @dc42
          @dc42 thanks. Can you give an example of what qualifies as those suggestions? low inductance, modest, torque, high ratio of holding torque to rotor inertia?
          • garisundefined
            garis @dc42
            @dc42 My pancake has more than enough torque @ 30:1. What is the reason to use high current?
              dc42 administrators @garis
              The reason to use a motor current close to the rated maximum is to provide enough torque to overcome the inertia of the rotor, because high gearing means you need high acceleration.
