    Recovery after "Emergency Stop"
    1277
    • Yonkiman
      Yonkiman last edited by
      I'm making good use of the "Emergency Stop" button as I sort out motor assignments and polarities on my new CoreXY. To recover, I have to press the reset button on the Duet Wifi, wait a few seconds, and refresh my browser.
      Is that the normal procedure? Wasn't expecting to have to press reset, though it's hardly a big deal.
      Firmware Version: 1.17e (2017-02-10)
      WiFi Server Version: 1.03 (ch fork)
      Web Interface Version: 1.14a
      • iDevelo
        iDevelo last edited by
        I had this issue until I upgraded the firmware to 1.18.
        • T3P3Tony
          If you are hitting the emergency stop button on the web interface it sends the commands M112 and then M999 which causes a software reset. Refreshing the browser window (or pressing the connect button, top left) should connect back to the Duet without the hardware reset button needing to be pressed
          www.duet3d.com
          • Yonkiman
            @iDevelo:
            Where'd you get 1.18? The latest on git (https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Stable) seems to be 1.17.
            • Yonkiman
              @T3P3Tony:
              Not for me. No matter how long I wait after an emergency stop, when I refresh the browser the interface says it's connected, but it isn't. Nothing happens when I try to Home an axis, and when I try to edit .g files it says "Connect to your Duet to display System files". Everything's fine after a reset. Running Chrome 56.0.2924.87 (64-bit) on Windows 10.
              • T3P3Tony
                Odd that may be a difference between 1.17 and 1.18
                www.duet3d.com
                • DjDemonD
                  DjDemonD last edited by
                  Yeah mine doesn't always reset without a hardware reset buts not a big problem.
                  Yonkiman - try https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Edge
                  For edge firmware.
                  www.precisionpiezo.co.uk
                  • Yonkiman
                    @DjDemonD:
                    That worked! After an emergency stop I just have to wait 5-10 seconds (no reset, no refresh) and everything is working normally.
                    Thanks!
                    • iDevelo
                      @T3P3Tony:
                      Yeah Tony. It just shows as halted in DWC with 1.17 latest for some reason. With 1.18 it works as it should.
                      • T3P3Tony
                        Thanks for the clarification, I just never noticed that before!
                        www.duet3d.com
