    Pay for config / json files for my corexy printer build.
    67
    5.6k
      deckingman @Stevo
      @stevo My approach is to always keep and maintain the configuration files on my PC. Then if I need to, I edit the PC based files and upload them to the Duet. That way, I always have a working backup should anything go amiss with the SD card.
      Any text editor can be used to edit the files - notepad++ is one that I use (it's free).
      Stevoundefined 1 Reply Last reply Reply Quote 0
      • Stevoundefined
        Stevo @deckingman
        @deckingman
        OK thank you
        • Stevoundefined
          Stevo @Veti
          @veti
          Thank you
            Phaedrux Moderator @deckingman
            @deckingman said in Pay for config / json files for my corexy printer build.:
            I think @Phaedrux must be short of caffeine
            More like toddler induced sleep deprivation.
            • Stevoundefined
              Stevo
              Afternoon all,
              I have edited all the files as mentioned in the previous comments,
              When looking down on the printer with the two steppers controlling x and y at the bottom the tool head travels in both negative's axis direction to the bottom left.
              I have purchased a genuine V3 BL touch and would like to connect this to the Duet WIFI 2 next.
              After looking at other posts i have more doubts than when i first looked lol.
              So without doing something i will regret i don't need to physically break any connections on this version of sensor or add resistors.
              But i need to add a Gcode to set the correct voltage for the sensor ?
              Scachiundefined 1 Reply Last reply Reply Quote 0
              • Scachiundefined
                Scachi @Stevo
                @stevo said in Pay for config / json files for my corexy printer build.:
                Have you read the link deckingman has mentioned ? -> https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
                Quote from the Movement Section: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section
                For a CoreXY or H-Bot machine, RepRapFirmware assumes that the motor connected to the X motor output moves the head in the +X and +Y directions when it runs forwards, and that the Y motor moves the head in +X and -Y directions when it runs forwards.
                Then test for the correct X motor movement by sending these commands from the console:
                G91
                G1 S2 X10 F3000
                If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, turn the power off and swap the X and Y motor
                Read the whole section again and run each command to test if everything moves in the direction it should
                • Vetiundefined
                  Veti
                  it sound like you are still in cartesian mode rather than corexy mode.
                  for bltouch see this guide
                  https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
                  • Stevoundefined
                    Stevo
                    I have followed Mark Rehorst's (thank you Mark) how to set up core xy origin and Endstops article origin is at Alpha motor all positive movement is in the direction of the top right pulley.
                    The tool homes back to the Alpha motor.
                      deckingman @Stevo
                      @stevo Do you have a problem with the motion or not? - I'm a bit confused because it sounds like it's doing what it should do..
                      To be clear, if you command an X positive move, the print head moves from left to right in your diagram and there is no movement in the Y direction. Yes or no? If no, what happens when you command an X only positive move?
                      Conversely, if you command an X negative move, the head moves from right to left and there is no movement in the Y direction yes or no?
                      And a Y positive move moves the head towards the back and there is no movement left or right. Yes?
                      • Stevoundefined
                        Stevo @deckingman
                        @deckingman Yes it ticks all the boxes Veti mentioned in still appeared to be in cartesian mode guess its my poor description lol
                        Thank you
                        • Vetiundefined
                          Veti
                          please post your config.g so we can have a look at what you configured so far.
                          • Stevoundefined
                            Stevo
                            This is where I'm up to so far.
                            Im in the process of adding the BLtouch wiring to the existing loom need to remove existing Z axis end stop.
                            ; generated by RepRapFirmware Configuration Tool v2 on Sun Jun 30 2019 12:38:00 GMT+0100 (BST)
                            M669 K1 ; Select CoreXY mode
                            M550 P"WILE E COYOTE" ; Set machine name
                            M552 S1 ; Enable network
                            ;*** Access point is configured manually via M587
                            M586 P0 S1 ; Enable HTTP
                            M586 P1 S0 ; Disable FTP
                            M586 P2 S0 ; Disable Telnet
                            M569 P0 S1 ; Physical drive 0 goes forwards
                            M569 P1 S1 ; Physical drive 1 goes forwards
                            M569 P2 S0 ; Physical drive 2 goes backwards
                            M569 P3 S1 ; Physical drive 3 goes forwards
                            M92 X80.00 Y80.00 Z1600.00 E420.00 ; Set steps per mm
                            M566 X900.00 Y900.00 Z30.00 E3000.00 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X6000.00 Y6000.00 Z144.00 E1200.00 ; Set maximum speeds (mm/min)
                            M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
                            M906 X800.00 Y800.00 Z2000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            M208 X-220 Y-220 Z0 S1 ; Set axis minima
                            M208 X220 Y220 Z660 S0 ; Set axis maxima
                            M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                            M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                            M558 P9 H15 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X32 Y2 Z2.5 ; Set Z probe trigger value, offset and trigger height
                            M557 X220:220 Y-220:220 S20 ; Define mesh grid
                            M140 H-1 ; Disable heated bed
                            M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                            M106 P0 S0 I0 F500 H-1 C"Part fan". ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            M563 P0 D0 H1 ; Define tool 0
                            T0 ; Select first tool
                            • Vetiundefined
                              Veti
                              just to double check you are running firmware version 2.03?
                              • Stevoundefined
                                Stevo @Veti
                                @veti Yes i am
                                • Vetiundefined
                                  Veti
                                  M669
                                  whats is the output if you issue M669 in the console.
                                    deckingman @Stevo
                                    @stevo One thing about your config.g that looks odd to me is that the steps per mm for Z look right for a metric lead screw but looking at your machine name, I'd have thought that you would be using Acme threads ☺
                                    • Vetiundefined
                                      Veti
                                      1600 is a lead screw 1 start 2mm lead.
                                      some people use them because it allows for 0.01mm layer height variation.
                                        deckingman @Veti
                                        @veti said in Pay for config / json files for my corexy printer build.:
                                        I know. I was making a joke when I saw the OP's machine name. You need to have watched the cartoons to know the significance of "Acme" though.......
                                          A Former User
                                          Should probably switch joke supplier;)
                                            deckingman @A Former User
                                            @bearer said in Pay for config / json files for my corexy printer build.:
                                            Yes, a joke never works when you have to explain it...........
