    Can't connect to Duet2Wifi on Mac
    1.1k
      A Former User
      permissions?
      • keithundefined
        keith
        Ok, Now I'm getting a screen that scrolls the same thing over and over.
        WiFi module is idle
        WiFi reported error: no known networks found
        WiFi module is idle
        I type in M115 i get:
                                                              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                                                  ok
                WiFi module is idle
        It won't stop scrolling and I it will not take any more commands
          A Former User
          maybe its easier to remove the sd card, and add your wifi stuff to the config.g file and put the card back in the duet?
          keithundefined 1 Reply Last reply Reply Quote 0
          • keithundefined
            keith @A Former User
            @bearer
            Already tried that using Atom. I've tried Chrome and Firefox
              A Former User
              Scrolling sounds like the board is reset for some reason, see if it behaves the same without the sd card when you run it. Could be worth trying to re-flash the firmware after that, but given that it shouldn't be necessary you may want to hold off on that.
              • keithundefined
                @bearer
                Hmm, got it connected. Haven't got a clue how. But it's connected.
                  A Former User
                  Change powersupply by chance?
                  Anyways, all that ends well and all that 👍
                  • keithundefined
                    @bearer
                    Same power supply. New 24v Meanwell. I just unplugged and replugged everything in about a half dozen times. Have no idea what finally got it working. Oh well. All's well and all that..
                    • Vetiundefined
                      Veti
                      did you have the psu and usb connected at the same time?
                      see
                      https://duet3d.dozuki.com/Wiki/USB_ground_loops
                      • keithundefined
                        keith @Veti
                        @veti
                        No. Just the board plugged into the USB.
                          A Former User
                          Could be the USB port and/or cable was unable to supply enough power to let the board start up; if it started working after you had the config on the SD card and with the 24v supply that would make sense. But I'll stop beating a dead horse now
                          • keithundefined
                            keith
                            Back to not being able to connect to the Duet2Wifi on Mac
