    Can't connect to Duet2Wifi on Mac
    1.1k
    • Vetiundefined
      Veti
      did you run it in a terminal?
      what happens if you just put in ls?
      if it cant find ls then you mac path variables might be wrong
      see
      http://osxdaily.com/2018/05/24/command-not-found-mac-terminal-error-fix/
      • keithundefined
        keith
        ok, now all I get is
        ls /dev/tty.*
        /dev/tty.Bluetooth-Incoming-Port
        no USB
        • Vetiundefined
          Veti
          after you connect the duet run the command dmesg.
          what do the last few lines say?
          keithundefined 1 Reply Last reply Reply Quote 0
          • keithundefined
            keith @Veti
            @veti IOConsoleUsers: gIOScreenLockState 1, hs 0, bs 0, now 0, sm 0x0
            loginwindow is not entitled for IOHIDLibUserClient keyboard accessloginwindow is not entitled for IOHIDLibUserClient keyboard accessLogiMgrDaemon is not entitled for IOHIDLibUserClient keyboard accessIOConsoleUsers: time(0) 0->0, lin 1, llk 0,
            • keithundefined
              keith
              i installed a usb driver. Now I'm getting
              screen /dev/tty.usbmodem14241
              [screen is terminating]
              The screen pops up then says: Sorry, could not find a PTY then it terminates.
              • Vetiundefined
                Veti
                https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                you are missing the baudrate
                If you get an error, Sorry, could not find a PTY. unplug the USB, plug it back in and try again.
                • keithundefined
                  keith
                  screen /dev/tty.usbmodem14241 115200
                  Same thing happens with the baud rate.
                    A Former User
                    permissions?
                    • keithundefined
                      keith
                      Ok, Now I'm getting a screen that scrolls the same thing over and over.
                      WiFi module is idle
                      WiFi reported error: no known networks found
                      WiFi module is idle
                      I type in M115 i get:
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
        ok
                              WiFi module is idle
                      It won't stop scrolling and I it will not take any more commands
                        A Former User
                        maybe its easier to remove the sd card, and add your wifi stuff to the config.g file and put the card back in the duet?
                        • keithundefined
                          keith @A Former User
                          @bearer
                          Already tried that using Atom. I've tried Chrome and Firefox
                            A Former User
                            Scrolling sounds like the board is reset for some reason, see if it behaves the same without the sd card when you run it. Could be worth trying to re-flash the firmware after that, but given that it shouldn't be necessary you may want to hold off on that.
                            • keithundefined
                              @bearer
                              Hmm, got it connected. Haven't got a clue how. But it's connected.
                                A Former User
                                Change powersupply by chance?
                                Anyways, all that ends well and all that 👍
                                • keithundefined
                                  @bearer
                                  Same power supply. New 24v Meanwell. I just unplugged and replugged everything in about a half dozen times. Have no idea what finally got it working. Oh well. All's well and all that..
                                  • Vetiundefined
                                    Veti
                                    did you have the psu and usb connected at the same time?
                                    see
                                    https://duet3d.dozuki.com/Wiki/USB_ground_loops
                                    • keithundefined
                                      keith @Veti
                                      @veti
                                      No. Just the board plugged into the USB.
                                        A Former User
                                        Could be the USB port and/or cable was unable to supply enough power to let the board start up; if it started working after you had the config on the SD card and with the 24v supply that would make sense. But I'll stop beating a dead horse now
                                        • keithundefined
                                          keith
                                          Back to not being able to connect to the Duet2Wifi on Mac
