    Can't connect to Duet2Wifi on Mac
    1.1k
    • keithundefined
      keith
      screen /dev/tty.usbmodem14241 115200
      [screen is terminating]
      Same thing happens with the baud rate.
        A Former User
        permissions?
        • keithundefined
          keith
          Ok, Now I'm getting a screen that scrolls the same thing over and over.
          WiFi module is idle
          WiFi reported error: no known networks found
          WiFi module is idle
          I type in M115 i get:
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                                                    ok
                  WiFi module is idle
          It won't stop scrolling and I it will not take any more commands
            A Former User
            maybe its easier to remove the sd card, and add your wifi stuff to the config.g file and put the card back in the duet?
            keithundefined 1 Reply Last reply Reply Quote 0
            • keithundefined
              keith @A Former User
              @bearer
              Already tried that using Atom. I've tried Chrome and Firefox
                A Former User
                Scrolling sounds like the board is reset for some reason, see if it behaves the same without the sd card when you run it. Could be worth trying to re-flash the firmware after that, but given that it shouldn't be necessary you may want to hold off on that.
                • keithundefined
                  @bearer
                  Hmm, got it connected. Haven't got a clue how. But it's connected.
                    A Former User
                    Change powersupply by chance?
                    Anyways, all that ends well and all that 👍
                    • keithundefined
                      @bearer
                      Same power supply. New 24v Meanwell. I just unplugged and replugged everything in about a half dozen times. Have no idea what finally got it working. Oh well. All's well and all that..
                      • Vetiundefined
                        Veti
                        did you have the psu and usb connected at the same time?
                        see
                        https://duet3d.dozuki.com/Wiki/USB_ground_loops
                        • keithundefined
                          keith @Veti
                          @veti
                          No. Just the board plugged into the USB.
                            A Former User
                            Could be the USB port and/or cable was unable to supply enough power to let the board start up; if it started working after you had the config on the SD card and with the 24v supply that would make sense. But I'll stop beating a dead horse now
                            • keithundefined
                              keith
                              Back to not being able to connect to the Duet2Wifi on Mac
