    Can't connect to Duet2Wifi on Mac
    1.1k
      A Former User
      maybe its easier to remove the sd card, and add your wifi stuff to the config.g file and put the card back in the duet?
      keithundefined 1 Reply Last reply Reply Quote 0
      • keithundefined
        keith @A Former User
        @bearer
        Already tried that using Atom. I've tried Chrome and Firefox
          A Former User
          Scrolling sounds like the board is reset for some reason, see if it behaves the same without the sd card when you run it. Could be worth trying to re-flash the firmware after that, but given that it shouldn't be necessary you may want to hold off on that.
          • keithundefined
            @bearer
            Hmm, got it connected. Haven't got a clue how. But it's connected.
              A Former User
              Change powersupply by chance?
              Anyways, all that ends well and all that 👍
              • keithundefined
                @bearer
                Same power supply. New 24v Meanwell. I just unplugged and replugged everything in about a half dozen times. Have no idea what finally got it working. Oh well. All's well and all that..
                • Vetiundefined
                  Veti
                  did you have the psu and usb connected at the same time?
                  see
                  https://duet3d.dozuki.com/Wiki/USB_ground_loops
                  • keithundefined
                    keith @Veti
                    @veti
                    No. Just the board plugged into the USB.
                      A Former User
                      Could be the USB port and/or cable was unable to supply enough power to let the board start up; if it started working after you had the config on the SD card and with the 24v supply that would make sense. But I'll stop beating a dead horse now
                      • keithundefined
                        keith
                        Back to not being able to connect to the Duet2Wifi on Mac
