    Marlin ABL Vs Duet ABL
    936
    • npm1undefined
      npm1
      whats a better version, or more stable/ reliable version of ABL
      Or what are difference if any
      which firmware did you have a better experience on
      how would one go about installing Marlin 2.0 on the duet hardware
      Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
        T3P3Tony administrators @npm1
        @npm1
        Not sure about marlin. on Duet bed levelling supported by a z probe has been a mainstream feature for a long time and is stable.
        I am not sure if Marlin 2.0 supports the SAM4 processors yet however you will find you get a better experience from RRF which is designed from the ground up tow rok on 32 bit processors. That is not knocking marlin - it just has the hangover of supporting all the old 8 bit stuff as well.
        • rodekundefined
          rodek
          As one who used Marlin, I purchased my first DuetWifi a couple years ago and I would not go back to Marlin, all 3 of my printers at home are DuetWifi, so I maybe a little bias.
          Also this forum is a great wealth of knowledge.
          • CHANGE3D GmbHundefined
            CHANGE3D GmbH
            I used both and will definitely stick with the Duet ABL! 😉
            The possibility to save a heightmap of your headbed alone is a big reason. This makes it possible to probe your bed just once and then load the saved heightmap before every print. Saves a lot of time and is much more convenient.
            The ABL itself works great and stable, I can really recommend it.
            Best,
            Markus
            www.change3d.ch
            info@change3d.ch
            • lodgerundefined
              lodger
              I have used both Mesh ABl and Standerd ABL on Marlin,
              Mesh on marlin is very simplier to Duets,
              Though its only really gcode based. At least we have DWC for better bed map management.
              and of cause Duet is my choose..
              • oliofundefined
                oliof
                Marlin 2.0 has changed a lot to support 32bit boards due to their HAL isolating the CPU peculiarities. Their support for32bit boards is on par with the one for 8 bit boards (and some of those 32bit boards are now available at competitive prices compared to the 8bit boards).
                As far as I know, there has not been made an effort of porting Marlin to SAM4E based boards, so Duet boards are RRF exclusives.
                As far as I know, Marlins bed leveling has a limit in the number of points used for mesh leveling which is lower than the one for RRF (if one exists). I don't know if that has practical implications though.
                  Phaedrux Moderator @oliof
                  @oliof said in Marlin ABL Vs Duet ABL:
                  if one exists
                  441 I believe. https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Define_the_mesh_size_and_spacing
                  • oliofundefined
                    oliof
                    Hah, I never tried more than 400 (-: (200x200mm with a 10mm distance between each point). ISTR the limit on Marlin is around 150.
