    5-axis 3D printing
    3D Printing General Chat
    10
    27
    5.0k
    • DocTruckerundefined
      DocTrucker
      Probably rotation of the nozzle about x and y axis for conformal printing or repair onto non-planar surfaces such as rollers/cylinders.
      • fmaundefined
        fma
        Hi Harald,
        Some months ago, came the idea to build a 5 axis machine, mainly to print BB-8 panels, which are pure sphere portions.
        My idea was to tilt the bed along X and Y. If I could have a tilt radius equal of the panel radius, the nozzle could remain static (so, it would not be a 5 axis machine!). But it is not easy to do, as the bed would collide the Z axis. So, using a shorter tilt radius would still require to move the head.
        On the slicer side, my idea was to print planar parts, and have a specific kinematic to map the plane onto the sphere. This is not ideal, beause I loose precision when I go off center (or, to be more precise, the planar part does not have all the informations, as parts far from the center have to be stretched to map onto the sphere).
        So, I'm very interested to follow your devs on the slicer, but I have no clue how a slicer works 😕
        PS: I didn't start to work on the mechanic yet. I had a quick look at RRF firmware, but the kinematic model for CoreXY machines has changed, recently, so I have to dig again.
        PS2: tilting the head would work too, but seems more complicated...
        Frédéric
        • haraldschmidtundefined
          haraldschmidt @Veti
          @veti
          Hello veti,
          the 4th axis is a rotation axis which rotates the Panel.
          The 5th axis is to swivel the Panel.
          • Vetiundefined
            Veti
            did you have a look at linuxcnc?
            http://linuxcnc.org/docs/devel/html/motion/5-axis-kinematics.html
            • DallasHundefined
              DallasH
              I currently program 5 axis vertical milling machines XYZ+A&B axis rotary trunnion A is +or- 999 degrees, B is +or- 120 degrees. I see no reason why you could not use 5 axis CNC software to generate your G code, I use both Surfcam and Edgecam. both have fully integrated customizable Post Processor generators.
              • fmaundefined
                fma
                CNC and 3D printing does not uses same tools... For example, CAM softwares don't know how to manage bridges or so.
                I don't think driving the 5 axis is a problem; it's more a matter of a clever slicer to take advantage of additionnal axis.
                Frédéric
                • fmaundefined
                  fma
                  You should see that:
                  https://www.reddit.com/r/3Dprinting/comments/bs7dml/first_tests_using_our_5_axis_printer_slicing_done/?sort=new
                  Frédéric
                  • zaptaundefined
                    zapta @haraldschmidt
                    @haraldschmidt said in 5-axis 3D printing:
                    getting a self-made 5-axis 3D Printer work at my University.
                    What's your goal? Being able to print shapes that can't be printed on a regular 3D printer? Any example?
                    • Marco Bonaundefined
                      Marco Bona
                      Look autodesk powermill additive 2019/2020 with netfabb strategies.
                      It should be able to handle 3 + 2 axis interpolations for print
                      • fmaundefined
                        fma
                        I started to work on a pseudo 5 axis 3D printing stuff. This is a work in progress, but I share it so you may give me some advices 😉
                        Frédéric
                        • fmaundefined
                          fma
                          As you can see on the wiki page, the idea is to map a portion of sphere onto the plane: this part works fine, and I can have the part sliced the usual way¹.
                          Now, I need to implement the kinematic. My first idea was to post-process the G-Code file, and transform the X/Y/Z coordinates to X/Y/Z/A/B coordinates with a Python script. But it is not that simple, as the additionnal bed rotations make the kinematic non linear 😕 So, the only way is to implement that in the firmware.
                          Some months ago, I started to look in the CoreXY code, but I'm wondering if it would not be easier to build a 6 axis Delta or Stewart platform... Delta kinematic is already implemented, with all the segmention stuff, and adding 3 axis is maybe easier than tweeking the CoreXY code to make it segmented. A 6 axis Delta is maybe also easier to build than a 2 axis bed rotation.
                          David, what do you think? Would it be hard to extend the 3 axis Delta kinematic code to a 6 axis kinematic?
                          Any advice welcome.
                          ¹ BTW, I made some tests with my sphere_to_plan mapper, and found that slicing the portion of sphere mapped to plan uses much less filament : on my little test part, I found 3m40 vs 4m12 ; this is 17% less, and this is done without support for the sphere! If my Python code is correct, this is an argument to develop 5 axis 3D printers.
                          Frédéric
                            Marco Bona
                            Sorry but I don't understand what you want to do with xyzab.
                            At most you can exchange a linear axis with a rotary one.
                            I've been working on 5-axis milling machines for several years and what you say doesn't make any sense
                            • fmaundefined
                              fma
                              The goal is to print a sphere as if it was a plan. A/B axis are bed (or hotend) tilt along X/Y, and are used to ensure the hotend is always normal to the sphere at the printing point.
                              Once the STL file of the sphere is mapped to the plan (which works fine) and sliced, the X/Y coordinates of the G-Code describe the sphere of the original stl file. The firmware should then convert these X/Y coordinates (which the printer still see as a plan) to new X/Y/Z/A/B coordinates to re-create the sphere in the printer space.
                              Frédéric
                                deckingman @fma
                                @fma Have you thought this through? You'll need to tilt the head, not the bed. Otherwise the part will fall off. To start the sphere, the print head will need to be tilted and positioned such that it is inside the sphere which could be difficult if the part is solid. If you start with the head outside the sphere, then the head will need to be below the bed. Half way up the sphere, you'll need to switch the head from inside to outside.
                                • fmaundefined
                                  fma
                                  There is no problem to tilt the bed +-35°, the part won't fall, as it is very thin compare to its width. I've seen people putting their (small) printer upside down while printing!
                                  The sphere will be printed from outside, this way:
                                  BB-8 panel
                                  The bed rotations would be inside the sphere, more or less at the flat bed height (flat bed which won't exist anymore). So, the hotend have to raise while the bed tilts.
                                  BTW, I plan to make a sphercial bed, so there is no need for supports. This bed can be 3D-printing, and by adding a raft for each print, can be re-used several times, giving very good adhesion.
                                  Frédéric
                                    A Former User
                                    One concern with rotating the part might be that you loose (or vary) the force of gravity to help squish the layers as well, but if parts fall off then bed adhesion might be worth looking into in any case.
                                    • fmaundefined
                                      fma
                                      I don't think gravity plays a big role in layer adhesion; it is more a matter of temperature and speed... And this part will have no strenth on it, so even if layer adhesion is bad, this is not a problem. The goal is 1) save time and filament 2) give a nice finish 3) have fun while designing the printing process 😉
                                      Frédéric
                                        A Former User
                                        When printing in a xy plane as you will be doing its at least a constant force, I'm just relaying some of the stuff I've read with regards to "true" 5-axis printing.
                                        • fmaundefined
                                          fma
                                          If I use a tilting bed, the hotend remains vertical. But it would be more fun to build a dedicated 6 axis Delta, if David can implement the kinematic 😉
                                          Frédéric
                                            deckingman @fma
                                            @fma But your illustration is for a slice of the upper part. If you want to print the lower part and keep the tool at 90 degrees to the print surface at all times, you'll have to print the lower half with the tool inside the sphere. Because if it's outside the sphere then it will need to be below the bed. So you'll never be able to print a solid sphere - only a hollow one. For the first half, you'll need to keep tilting the bed until it reaches 90 degrees (at which point the part will likely fall off). After the half way point, you'll have to move the tool to the outside then tilt the bed back in the opposite direction.
