    Five bar parallel Scara
    My Duet controlled machine
    10
    61
    9.8k
    • bondusundefined
      bondus @JoergS5
      @joergs5, please do. We need a joint repo to work from, we should set up a common fork after that. I poke around in the code at times, it's not complete, yet.
      I did a push today of my local changes to my repo at https://github.com/bondus/5barscara/tree/master/rrf. Mostly cosmetic changes, but something important might be hiding in there. If we had a joint repo I will behave, commit more often and add proper comments 🙂
      • JoergS5undefined
        JoergS5 @bondus
        @bondus I will test your code corrections with my printer at the weekend and will make the PR then (maybe I should do it for RRF3 only, what do you mean? *)). I will add some unit testing of the most imporant methods. I have gathered some ideas to avoid backlash, so no need to correct the firmware in this regard as I planned to do.
        *) if we work and test with only one version of RRF, effort to develop further will be lower, deployment easer, and RRF3 is the future anyway. If someone wants to use it in 2.03, it's easy to downport.
        • bondusundefined
          bondus
          The fancy new rod holders made no difference for the ripples. They made the tower quite a lot stiffer and they look good 🙂
          The ripples are pretty high frequency and keeps going for a long while, not much dampening.
          This print is in shiny black to show all flaws and held at a very specific angle to see the ripples, prints generally look good.
          • JoergS5undefined
            JoergS5 @dc42
            @dc42 @bondus I made a PR #297 now into v2-dev. The files compile ok, the PR should only contain the two files .h and .cpp of the kinematic. Please include into your main RRF. I am sure there are bugs or improvements left, so there will be updates.
            bondus, I changed a few of the methods to be the same signature as the original methods, because they were overridden methods. I hope I didn't break your code. (I saw now that the changed methods are due to changes between v2 and v3)
            bondusundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • bondusundefined
              bondus @JoergS5
              @joergs5, Sweet!
              After some battling with the RRF build (the build environment is quite fragile) I got it building and running. It works perfectly fine.
              I never managed to get v3 running properly. After some workarounds with the homing issues I got it moving. But it refused to print any gcode files, it did nothing after starting a gcode file.
              • JoergS5undefined
                JoergS5 @bondus
                @bondus I will try RRF3 after finishing my printer build. First priority is to build the optical encoders for the endstops with ESP32-CAM (I will use the mechanism for Z axis also), then as stiff arms as possible. I will try dry plain bearings with plastic surfaces at the sliding surface. PTFE (teflon) has lowest friction, nylon a bit worse (but easier to 3D print).
                • oliofundefined
                  oliof
                  @JoergS5 slightly offtopic, but: would the optical encoder based endstop also work on a traditional SCARA arm?
                  • JoergS5undefined
                    JoergS5 @oliof
                    @oliof yes, it will work with all actuators which rotate. The advantage is that the endstop can be approached from both sides and can tell the absolute angle at any time. I will write a documentation for diy steps and software.
                      dc42 administrators @JoergS5
                      @joergs5 said in Five bar parallel Scara:
                      v2-dev is no longer used, it was for the initial development of RRF 2.0. The branch used for firmware 2.x is now the dev branch. So that is there your PR should be targeted.
                      • JoergS5undefined
                        JoergS5 @dc42
                        @dc42 I am confused now. Which branch shall I use for the PR. Or other proposal: I implement it for RRF 3 dev branch and withdraw the PR 297. When you finished your Duet 3, I will be ready for the RRF3 PR.
                          @joergs5, yes a PR for RRF3 on the v3-dev branch would be good, if you have tested it.
                          • JoergS5undefined
                            JoergS5
                            @dc42 I will change to RRF3 and correct the bug we found. Good luck with your Duet 3, I am very curious what it will be like!
                            • bondusundefined
                              bondus
                              @JoergS5, @dc42. I should give RRF3 another go to get five bar scara going. But me and Eclipse have a decade long battle that never settles.
                              • JoergS5undefined
                                JoergS5 @bondus
                                @bondus That's good news if you can test RRF3.
                                I am used to use Eclipse for Java, but I am often confused by the eclipse behaviour. Especially at RRF I am confused by the different setting for the different hardware and the error message that pop up here and there for some .h files not being compilable. I understand why David has it in the code, but my Eclipse tells me about errors, because a grayed file cannot be compiled or found.
                                I thought about a fork and throw out all those RADDS, Duet 085 and other hardware which is not relevant for my hardware. And I would like to throw out Delta, heatbed calibration code to have the pure logic in the code which I need, and to understand the code. But it's a lot of work, and then I have to synchronize somehow.
                                • bondusundefined
                                  bondus
                                  I woke up my old printer and gave it a new fancy 300x200mm machined bed.
                                  Only to realize why I have not used it very much. Straight lines are not always straight when printed. It is not made with the precision needed for an arm like this.
                                  I need to properly measure all the arm lengths and homing angles and put them into the firmware and all should be fine.
                                  • JoergS5undefined
                                    JoergS5
                                    Nice build, @bondus. I thought about calibration for my printer also. Ich will go the other way: meassure the results for a given configuration and then calculate back what the dimensions of the arms are.
                                    E.g. move to 0,0 and 300,300 with Gcode and then check what abbreviations of the expected positions are. Calculate back the true arm lengths and actuator angles. I hope this will give some corrections of other errors also (hinge movements, arm bending e.g.)
                                    bondusundefined 1 Reply Last reply Reply Quote 0
                                    • bondusundefined
                                      bondus @JoergS5
                                      @JoergS5 said in Five bar parallel Scara:
                                      I tried an approach like that a while back but never got it working, it should work in theory, so it was my execution that was wrong.
                                      There are 7 unknowns that might need adjusting: The length of each of the five "bars" and the two homing angles. You will need quite a few measurements to get a single solution to the adjustment equation.
                                      Now with a bigger, and very flat, bed I also noticed that the head does not move in a perfect plane, it's about 0.3mm higher at the left and right edges compared to the middle. The quick and dirty solution is to add a bed probe, or I could start looking for non-perpendicular angles on the machine.
                                      • JoergS5undefined
                                        JoergS5 @bondus
                                        @bondus My ideas for better Z accuracy are (sorted by cost, cheapest and easiest first):
                                        • counterweights at the other side of all hinges at the opposite side of the arms (leverage law or ball bearings could produce your 0.3 mm differences)
                                        • hinges supported with two arms each vertically, so the hinges are more precise
                                        • hinges with metal material
                                        • bondusundefined
                                          bondus
                                          @JoergS5, I really think that some critical parts of the arm should be machined. Tiny errors in precision in the parts holding the proximal arms are amplified further out. Possibly you could make some clever parts where you could tune it by tightening/loosening different bolts. This is not unique for this kind of robot arm, any arm moving by rotating a join will have the errors amplified. Linear rails are far easier to use.
                                          My design with the whole arm assembly moving up and down on the z-axis is tricky to design. There is very little room to place screws from the lower part to the upper part, to preload the bearings. The large pulleys and the goal to keep the arms rotation range as big as possible does not make it easy. The current version is far from ideal.
                                          I am working on a better version, but every time I start fusion I lose a day. It's very mesmerizing to 3D CAD.
                                          I installed an old precision piezo to measure the Z error properly. I had one of the the old crummy versions with a drilled piezo element laying around. It still works fine.
                                          I can see that the arms lifts the actuator the further out the actuator is. It's not due the tower being at the wrong angle, or the weight of the arms bending it down. Some other angle(s) are wrong. It's a complicated machine 🙂
                                          It's officially spring here now, at least on my balcony. The bulbs from last year are flowering. 😄 spring.jpg
                                          Phaedruxundefined JoergS5undefined 2 Replies Last reply Reply Quote 1
                                            Phaedrux Moderator @bondus
                                            @bondus Holy crap, is that a flower? It's the dead of winter here. I feel like I haven't seen colours like that in ages.
