    Heater Fault Pause Time
    570
    • wdenkerundefined
      wdenker
      We have a large format printer 1000x600x600 and print got 5 days in and had a heater fault due to wear in a thermistor wire. It paused but we didn't check in time to fix and resume. Any way to change the timeout setting? It is currently defaulted to 600 seconds but we tend to not check on it only every couple hours. So 10 minutes we would have to have really good timing if something like this occured.
      www.bd3dcustoms.com | BD3DCUSTOMS Supercube
        deckingman @wdenker
        @wdenker I don't understand how that would help. For sure you could change the time anomaly setting in M570 (not sure what the maximum is) but that's only how long after the fault occurs that action is taken. If your heater fails but you don't check for two hours, then the print is lost in any case.
        wdenkerundefined 1 Reply Last reply Reply Quote 0
        • wdenkerundefined
          wdenker @deckingman
          @deckingman Why would the print be lost after 2 hours? Time is irrelevant in my case. As long as I can get the thermistor wire repaired so it can heat again I wouldn't have any issues.
            A Former User
            I think I would focus on preventing it rather than fixing it. Use flexible silicone wiring and cable chains, replace wiring before it breaks based on past failures?
            • wdenkerundefined
              wdenker @A Former User
              @bearer yes but I also want a backup in case it does happen. Rather than loosing it all together. Prevention is key but being able to pickup from where it left off would be nice.
                A Former User
                Just to clarify are you talking about the hotend or heated bed here?
                Would a notification help? There are some threads on the forum that deal with monitoring and alerting.
                • wdenkerundefined
                  wdenker
                  Notifications would be great didn't know that was a thing.
                    A Former User
                    I haven't looked at it in detail, but most seem to monitor the serial port or poll the Duet over the network and use some sort of push notification etc. So an external microcontroller or raspberry pi would be needed.
                    Think this is one of the better threads, but if you search the forum you'll find more resources. https://forum.duet3d.com/topic/11088/notifications-upon-start-pause-finish-of-print
                    wdenkerundefined 1 Reply Last reply Reply Quote 1
                    • wdenkerundefined
                      @bearer Which at that point I may as well setup repetier server and a camera as well. Use it's push notifications, webcam, print queue and whatever else I can utilize which eliminates the need for using a duet.
                        deckingman @wdenker
                        @wdenker said in Heater Fault Pause Time:
                        Heater fails - hot end cools - under extrusion starts - hot end continues to cool - extrusion stops altogether but print continues - filament gets chewed - then jams = ruined print.
                        • wdenkerundefined
                          wdenker @deckingman
                          @deckingman no heater fault happens quick enough none of that happens and then pauses. Which in a paused state I can correct the issue and resume.
                            deckingman @wdenker
                            @wdenker I'm sorry but you are making too many contradictory statements for me to have any understanding of what it is you want to do, or what you perceive the problem to be.
