    NON Wifi Duet 0.85 with dual z motors?
    3.1k
      deckingman
      ….and with a tab of some sort positioned in the right place and covered in something reflective, you can use the same probe for X (and/or Y) homing too. This is how it was done on the RRP Mendel.
      • botundefined
        bot
        @Atomic3D:
        OK, so series would be connecting the 2 stepper motors together into one connection? sorry I am new to printer electronics and such.
        Hold on, what do you mean by 2 motors together into one connection? Make sure you understand the difference between series and parallel, because by simply putting the wire of each motor into the same slot on the connector would be parallel, and not series.
        See this: http://www.instructables.com/id/Wiring-Your-Z-Stepper-Motors-in-Series/
        *not actually a robot
        • Atomic3Dundefined
          Atomic3D
          Well that is beyond my skill level, I suck at soldering and also manipulating small wires with my eyesight is horrible. I can build a printer with no issue I have built 2, I know very basic limited electronics, enough to get by. So I guess I need to find a different board for my printer I want to build instead I want to make a omerod style printer or mayne add a second z axis with a belt system.
            T3P3Tony administrators
            Hey Atomic. No requirement for soldering, it's just wiring the plug differently. Rather than both reds, both blacks etc you wire so the current goes through 1 motor coil, then the other then back to the board.
            The instruction above gives an example
            However there are some other examples on Google. I will add something to the documentation when I am not on my phone.
            • StephenRCundefined
              StephenRC
              You could get something like this to make the connections: http://www.digikey.com/product-detail/en/on-shore-technology-inc/ES1000-12DSFB/ED3006-ND/2720753
              Cut off the current connectors a few inches from the connector on the motors and use the terminal block with one of the cutoffs to wire them together without any solder, to connect the motors to the Duet.
              • Atomic3Dundefined
                Atomic3D
                @StephenRC:
                How exactly would I use that connector? I am not grasping the concept. So how would the wires connect? there is really no clear info for those who are trying to learn basic electronics, does each color wire get connected together? all I see is a small board that you have to make and that's all I get from it. Is there a pre-made thing I can use?
                  StephenRC
                  What I linked to is a terminal block, it lets you connect wires without soldering.
                  This style is easier to see how they work: http://www.digikey.com/product-detail/en/molex-llc/0387700104/WM5761-ND/362488
                  • Atomic3Dundefined
                    Atomic3D
                    So further looking at pictures, I am assuming that wires from motor one go into motor 2 and then out of motor 2 to a connector?
                      StephenRC
                      Not all the wires from motor 1 go through motor 2. Interesting, googling a wiring diagram that works for a 3d printer isn't all that easy.
                      This should help: http://rigidtalk.com/wiki/index.php?title=Z-Axis_Stepper_Motor_-_Series_Connected_Splitter_Board#Why_Series.3F
                      • Atomic3Dundefined
                        Atomic3D
                        @StephenRC:
                        I really appreciated it. So all i need to do is connect the wires shown in the diagram? And use the connector you listed to connect the in the order shown?
                          Here http://m.imgur.com/gallery/JwKg3uj is a wiring diagram that uses a terminal block. You can buy a terminal block in the electrical section of a DIY store (home improvement store in the US).
                          • Atomic3Dundefined
                            Atomic3D
                            Here is a question, how come I cant convert one of the extruder port for a second motor?
                              Look up the M584 command in the gcode wiki at RepRapFirmware.org.
                              • Atomic3Dundefined
                                Atomic3D
                                Ok, I sorta get that, thanks for pointing me in the right direction. So as long as that command doesn't exist than it will map how I set it up. Merry xmas dc42.
