    Duet Maestro skipping layers while printing
    Duet Web Control
    duet maestro troubleshooting
    1.1k
    • oliofundefined
      oliof
      Please share your config.g, a config-override.g if you have one and an example gcode file
      • jacobsundlesundefined
        jacobsundles
        Thank you. I'll do that in just a few.
        I also just recieved a new error code after homing the printer.
        The error code reads that there is a java script error and that it disconnected the duet board. I will send a screenshot with my next message that includes the g.codes
          jacobsundles
          Alright, here's the gcodes , except the backup gcode, and the picture of the new javascript error. Thanks so much for you help.
          0_1563647079305_config.g
          0_1563647122748_CFFFP_f094a0f4-815f-4efa-8e16-e975c668113f.gcode
            jacobsundles
            The JavaScript error code showed up again, but this time it showed up right after I tried to disable the mesh bed leveling.
            • oliofundefined
              oliof
              Also try running M122 and copy the output here. If the web interface doesn't run reliably, try connecting with YAT or pronterface.
                jacobsundles
                M122
                RepRapFirmware for Duet 2 Maestro version 2.02RC5(RTOS) running on Duet Maestro 1.0
                Board ID: 08D8M-9T8A2-MQNSS-6J9D2-3SD6R-967GY
                Used output buffers: 3 of 20 (18 max)
                Static ram: 21236
                Dynamic ram: 96988 of which 0 recycled
                Exception stack ram used: 420
                Never used ram: 12428
                Tasks: NETWORK(ready,456) HEAT(blocked,1300) MAIN(running,3672) IDLE(ready,200)
                Owned mutexes:
                Last reset 00:47:24 ago, cause: power up
                Last software reset at 2019-07-16 13:02, reason: User, spinning module GCodes, available RAM 12468 bytes (slot 3)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                Error status: 0
                Free file entries: 10
                SD card 0 detected, interface speed: 15.0MBytes/sec
                MCU temperature: min 34.6, current 34.7, max 35.1
                Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: standstill, read errors 0, write errors 0, ifcount 15, reads 871, timeouts 0
                Driver 1: standstill, read errors 0, write errors 0, ifcount 15, reads 871, timeouts 0
                Driver 2: standstill, read errors 0, write errors 0, ifcount 15, reads 871, timeouts 0
                Driver 3: standstill, read errors 0, write errors 0, ifcount 11, reads 871, timeouts 0
                Driver 4: standstill, read errors 0, write errors 0, ifcount 8, reads 871, timeouts 0
                Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 871
                Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 871
                Date/time: 2019-07-20 11:48:46
                Slowest loop: 3.82ms; fastest: 0.07ms
                I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                Scheduled moves: 7, completed moves: 7
                Bed compensation in use: mesh
                Bed heaters = 0, chamberHeaters = -1 -1
                Heater 0 is on, I-accum = 1.0
                Segments left: 0
                Stack records: 3 allocated, 0 in use
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                lcd is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 69.93ms; fastest: 0.02ms
                HTTP sessions: 1 of 8
                Interface state 5, link 100Mbps full duplex
                • oliofundefined
                  oliof
                  Can you run M122 directly after the layer skips happen, before you got emergency stop?
                  • oliofundefined
                    oliof
                    Also, you're running an unsupported 2.02 rc release,ake sure you update to 2.03
                      It looks like your firmware and DWC are a bit out of date or mismatched. Please try updating everything to the 2.03 release.
                      https://github.com/dc42/RepRapFirmware/releases/tag/2.03
                      You should be able to simply upload this zip file as is to the settings page: https://github.com/dc42/RepRapFirmware/releases/download/2.03/Duet2Firmware-2.03.zip
                        jacobsundles
                        Thanks. I'll update a little later today and give that a shot.
                        Here is the M122 code that appeared after the same issue.
                        M122
                        Used output buffers: 3 of 20 (20 max)
                        Static ram: 21236
                        Exception stack ram used: 380
                        Never used ram: 12468
                        Owned mutexes:
                        Last reset 00:19:20 ago, cause: power up
                        Error status: 4
                        Free file entries: 9
                        SD card longest block write time: 63.0ms, max retries 0
                        MCU temperature: min 24.0, current 38.2, max 38.3
                        Supply voltage: min 23.0, current 23.2, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: standstill, read errors 0, write errors 0, ifcount 12, reads 46375, timeouts 0
                        Driver 1: standstill, read errors 0, write errors 0, ifcount 12, reads 46375, timeouts 0
                        Driver 2: standstill, read errors 0, write errors 0, ifcount 12, reads 46375, timeouts 0
                        Driver 3: standstill, read errors 0, write errors 0, ifcount 10, reads 46376, timeouts 1
                        Driver 4: standstill, read errors 0, write errors 0, ifcount 8, reads 46379, timeouts 0
                        Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 46386
                        Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 46386
                        Date/time: 2019-07-20 14:55:27
                        Slowest loop: 4581228.50ms; fastest: 0.06ms
                        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 130, MaxWait: 737781ms, Underruns: 0, 0
                        Scheduled moves: 594, completed moves: 594
                        Heater 0 is on, I-accum = 0.9
                        Heater 1 is on, I-accum = 0.2
                        Segments left: 0
                        === Network ===
                        Slowest loop: 4581228.50ms; fastest: 0.02ms
                        • Vetiundefined
                          Veti
                          there was a problem in the 2.02 firmware with time keeping that caused layer shifts.
                            dc42 administrators @Veti
                            @veti said in Duet Maestro skipping layers while printing:
                            That issue was in some 2.02RC and earlier releases. I fixed it before the 2.02 stable release.
                            • Vetiundefined
                              Veti
                              @dc42 said in Duet Maestro skipping layers while printing:
                              yes. he is using 2.02RC5, which was affected.
                                jacobsundles
                                Awesome. You guys have been a great help. I'll respond today or tomorrow after I've updated it. Thank you again.
                                  jacobsundles
                                  It's working better than ever. Guess it just needed a firmware update.
                                  Thanks a bunch for your fast and professional help. Even though the solution was simple, i likely wouldn't have ever fixed the issue since I was at the end of my rope. So, thanks again.
