    Duet maestro and weirdness on start gcode
    1.5k
      Perhaps you need to add G90 before the move to go out of the printing area to make it an absolute position move and then back to G91 for a relative move to draw the prime line.
      • Agniusmundefined
        Agniusm
        The thing is it was working fine. I still have duet wifi(eth now) with the same script and it works fine.
        • Agniusmundefined
          Agniusm @clearlynotstef
          @clearlynotstef said in Duet maestro and weirdness on start gcode:
          Post your config.g
          ; Configuration file for Duet Maestro (firmware version 1.21)
          M550 P"Scrappy" ; Set machine name
          M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M584 X0 Y1 Z2:4 E3 P3 ; two Z motors connected to driver outputs 0, 1, 2 and 4
          M671 X40:287 Y21:21 S5 ; leadscrews left and right
          M569 P0 S0 ; Drive 0 goes forwards
          M569 P1 S0 ; Drive 1 goes forwards
          M569 P2 S0 ; Drive 2 goes forwards
          M569 P3 S0 ; Drive 3 goes forwards
          M569 P4 S0 ; Drive 3 goes forwards
          M92 X98.66 Y78.54 Z396.04 E417.61 ; Set steps per mm X99.25 Y79.0
          M566 X400 Y400 Z12 E150 ; Set maximum instantaneous speed changes Jerk (mm/min) buvo Z24 E300
          M203 X12000 Y12000 Z1000 E1200 U6000 ; Set maximum speeds (mm/min) Z800
          M201 X600 Y600 Z100 E5000 ; Set accelerations (mm/s^2) Z200
          M906 X800 Y800 Z700 E750 I5 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S10 ; Set idle timeout
          M208 X0 Y-30 Z0 S1 ; Set axis minima
          M208 X310 Y209 Z220 S0 ; Set axis maxima
          M558 P4 I0 F400 X0 Y0 Z0 T12000 ; Set Z probe type, the dive height + speeds
          G31 P500 X23 Y6 Z0.566 ; Set Z probe trigger value, offset and trigger height
          M557 X35.5:239.5 Y10.5:209 S102:99 ; Define mesh grid
          M574 X1 Y1 Z2 S1 ; Define active low and unused microswitches
          ; M591 D0 P2 C4 S1 ; Filament runout
          ; M556 S79.95 X-0.1 Y0.5 Z0.55 ; Axes compensation
          M143 S350 ; Set maximum hotend temperature to 350C
          M143 H0 S120 ; Set maximum bed temperature to 130C
          M305 P1 T100000 B3950 C0 R2200 ; Set thermistor + ADC parameters for heater 1 Nozzle
          M305 P0 T100000 B3950 C0 R2200 ; Set thermistor + ADC parameters for heater 0 Bed
          M307 H1 A435.6 C127.3 8.8 B0 ; Use PID on extruder heater use M303 gain 435.6, time constant 127.3, dead time 8.8, max PWM 1.00, calibration voltage 12.0
          M307 H0 A80.2 C399.8 D2.2 B0 ; Use PID on bed heater use M303
          M570 H1 P10 T20 S160 ; Heater fault settings
          M106 P2 S0 L255 F500 T45 H1 ; Hotend fan, on at 45C M106 P1 T45 S0.7 H1:2
          M106 P1 S0 I0 F500 H-1 ; Part cooling fan
          ; M106 P2 S0 I0 F500 H-1 ; LED lights
          M563 P0 D0 H1 F1 ; Define tool 0
          ; LCD
          M918 P1 E4 ; enable lcd
          • Vetiundefined
            Veti
            post the actual start code of a generated gcode file.
            the slicer will insert additional commands at the beginning.
            Agniusmundefined 1 Reply Last reply Reply Quote 0
            • Agniusmundefined
              Agniusm @Veti
              @veti here is the beginning of the gcode:
              ; external perimeters extrusion width = 0.42mm
              ; perimeters extrusion width = 0.42mm
              ; infill extrusion width = 0.50mm
              ; solid infill extrusion width = 0.42mm
              ; top infill extrusion width = 0.42mm
              ; first layer extrusion width = 0.42mm
              M107
              G28 W ; home all without mesh bed level
              G0 Z70 F500 ; get head above bed to keep it cool
              M106 P1 S255 ; Turn on fan
              M140 S75 ; set bed temp
              M104 S180
              M190 S75 ; wait for bed temp
              M104 S180
              G28 W ; home all without mesh bed leveing
              G29 S0 ; mesh bed leveling
              M106 S0 ; Turn off fan
              M104 S235 ; set extruder temp
              M109 S235 ; wait for extruder temp
              G1 Y0.0 F5000 ; go outside print area
              G92 E0 ; reset extrusion distance
              G1 X70.0 E9 F1000 ; intro line
              G1 X140 E12.5 F1000 ; intro line
              M572 D0 S0.07 ; Pressure advance
              ; Filament gcode
              G21 ; set units to millimeters
              G90 ; use absolute coordinates
              M83 ; use relative distances for extrusion
              G1 E-1.00000 F2100.00000
              G1 Z0.250 F9000.000
              ; PURGING FINISHED
              G1 X130.316 Y151.203
              G1 E1.00000 F2100.00000
              M204 S1000
              G1 F900
              G1 X183.884 Y151.203 E1.95815
              G1 X183.884 Y164.498 E0.48600
              G1 X130.316 Y164.498 E1.95816
              G1 X130.316 Y151.263 E0.48380
              G1 X130.682 Y151.569 F9000.000
              G1 F900
              G1 X183.518 Y151.569 E1.93137
              G1 X183.518 Y164.131 E0.45921
              G1 X130.682 Y164.131 E1.93137
              G1 X130.682 Y151.629 E0.45702
              G1 X131.049 Y151.935 F9000.000
              It does not contain full G1 Y0 X2 Z0.5 F7000 ; go outside print area command with set x coordinate but since i added it, has same outcome.
              dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @Agniusm
                @agniusm said in Duet maestro and weirdness on start gcode:
                Why the W parameter?
                • Agniusmundefined
                  Agniusm @dc42
                  @dc42 It was from prusa start script but its not there now. No change still. Probably had no effect anyway.
                    Phaedrux Moderator @Agniusm
                    I say again, it looks like you're missing G90 and G91 commands here. G1 Y0 makes no sense in the context of a relative move. But the next movements are to extrude a prime like, which would require a relative move.
                      What firmware versions are your Duet WiFi and Duet maestro running?
                      Are there any error messages on the GCode Console when this happens?
                      • Agniusmundefined
                        Agniusm
                        Maestro on 2.02RC5. My duet wifi(eth now) runs 2.03 but it have never done that but start script is almost the same.
                        I have not noticed any errors in the gcode console but i will keep an eye.
                        It finishes mesh bed compensation, and then sort of glitches 1mm or so and stays at that last spot
                        • Agniusmundefined
                          Agniusm
                          here is the video:
                          https://youtu.be/Eaedp-ZMEvg
                          I have updated to 2.03 and still same.
                          • Vetiundefined
                            Veti
                            you never answered Phaedrux post about switching to absolute positioning for those moves.
                            • Agniusmundefined
                              Agniusm @Veti
                              @veti I dont know why would it be different as my duet wifi works ok with the same script.
                              P.S. OK. I have figured it out.
                              I have placed my move to the fron of the bed before these:
                              M104 S[first_layer_temperature] ; set extruder temp
                              M109 S[first_layer_temperature] ; wait for extruder temp
                              and now it works
                              • Agniusmundefined
                                Agniusm
                                Case closed;
                                • Agniusmundefined
                                  Agniusm
                                  Re-opened. Looks like it does it random. I don't know what is happening. Whenever i sliced with the new start script it went and did how it suppose to. Now prints finished and i started same file again and it again remained at the back of the bed and purged mid air.
                                  • Vetiundefined
                                    Veti
                                    as Phaedrux has said multible times in this thread, you need to make sure that when the code is executed it needs to be in absolute positioning . so add the correct G90 and G91 commands to your code.
                                    • Agniusmundefined
                                      Agniusm @Veti
                                      @veti do i need to add it just for that move or the whole start script?
                                      • Vetiundefined
                                        Veti
                                        try with a G90 at the beginning
                                          deckingman @Agniusm
                                          @agniusm By way of explanation, a relative move such as G1 X10, Y10 will move the print head by 10mm positive in both the X and Y directions. Whereas in absolute mode, that same G1 X10 Y10 will move the print head to the position which is 10mm in both X and Y from the homed position (usually 0,0).
                                          So for example if the print head started at X50 , Y60 then relative G1 X10 Y10 will move the print head another 10mm in each direction and it will end up at X60 Y70. But in absolute mode starting with the print head in that same position of X50 Y60 that same G1 X10 Y10 command will move the print to X10 Y10 so it will move minus 40mm in X and minus 50mm in Y.
                                          In actual fact, all moves have to be relative to some point in space. So absolute moves mean go to an XY position relative to the homed position. Therefore it follows that if the homed position hasn't been established, then any absolute moves aren't going to work properly.
                                          In summary, use relative to move by an amount, use absolute to move to a position (relative to the homed position).
                                          Agniusmundefined 1 Reply Last reply Reply Quote 2
                                            Phaedrux Moderator @Phaedrux
                                            @phaedrux said in Duet maestro and weirdness on start gcode:
                                            So the snippet above would become
                                            G90 ; absolute positioning
                                            G1 Y0 X0 F5000 ; go outside print area
                                            G91 ; relative positioning
